Draytek Vigor 2960n
  • tehmatix
    • Nov 2012
    • 174
    Draytek Vigor 2960n
    Hi, I have this router with an issue: I can't connect with network cable or wireless, is permanent restarting, power led and USB2 led flashing. Any ideas
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Draytek Vigor 2960n
    Yes. Take the top off and post photos of inside.
    • tehmatix
      • Nov 2012
      • 174
      Photos
      • cpt.charlie
        • Sep 2013
        • 270
        • Spain
        Do you have any USB device connected? if not, try a hard reset and connect just the router with a pc using a cable.
        BTW, check the power adapter just in case.
          • 31077
          that's a nice build.
          i also suspect it could the the psu.
          • seanc
            • Nov 2008
            • 1319
            I use lots of these for work. They usually only die due to the PSU failing, unless lightning fries them via the DSL line.
            • tehmatix
              • Nov 2012
              • 174
              Watch on this video
              https://www.youtube.com/watch?featur...&v=L7KuujKV2WI
              • tehmatix
                • Nov 2012
                • 174
                I made a hardware reset, and I don't have any usb device connected in usb port. Thanks
                • cpt.charlie
                  • Sep 2013
                  • 270
                  • Spain
                  Try with a different PSU.
                  • tehmatix
                    • Nov 2012
                    • 174
                    I already tried with different psu.
                    • cpt.charlie
                      • Sep 2013
                      • 270
                      • Spain
                      Any overheating component? if you have proper tools, try to reflash the firmware (using an external programmer)
                      • tehmatix
                        • Nov 2012
                        • 174
                        Re: Draytek Vigor 2760n
                        I already check capacitors on the board. All components it seems to work normal , no overheating. Which tools I need to make firmware upgrade ?
                        • tehmatix
                          • Nov 2012
                          • 174
                          CPU Lantiq PSB80910 El V1.2. Is a small memory on bottom MX25L2006E. This device contains the firmware?
                          • cpt.charlie
                            • Sep 2013
                            • 270
                            • Spain
                            Most likely the firmware is stored at the toshia tsop chip TC58NVG0S3ETA00 (128Mb chip) and the MX25L2006E is used to keep some parameters like mac address, serial number..... unles you have acces to the tools i wouldn't bother.
                            Look like this device can be controlled with console commands, maybe you could connect via console and perform a firmware reset or maybe a remote firmware upgrade, check the manual.
                            • tehmatix
                              • Nov 2012
                              • 174
                              I found on the board 4 pins for serial console ( +3,3V , Rx , Tx , Gnd).
                              I made a connection with laptop using hyperterminal software and a simple interface. I svae this log:
                              ROM VER: 1.1.4
                              CFG 05
                              Vigor2760-DrayBoot-v1.3.4
                              CLOCK CPU 500M RAM 250M
                              DRAM Size: 128 MB
                              NAND Flash: VID=0x98, PID=0xd1, Toshiba NAND 128MB 3.3V
                              Bad block table at page 65472 (ver=01)
                              Bad block table at page 65408 (ver=01)
                              WarmBoot: 0x1448008
                              Run DrayOS...
                              Boot DrayOS~~
                              nand_read_skip_bad 1: off 0x00d00000 read failure, try again (0)
                              nand_read_skip_bad 1: off 0x00d00000 read failure, try again (1)
                              nand_read_skip_bad 1: off 0x00d00000 read failure, try again (2)
                              Go~~
                              Modes: __STDC__ 32-bit mwDWORD==(unsigned long)
                              mwROUNDALLOC==4 sizeof(mwData)==24 mwDataSize==24
                              statistics: now collecting on a line basis
                              ============= Memwatch Auto Self Test =============
                              Normal Free...DETECTED
                              Double Free...DETECTED
                              NULL Free.....DETECTED
                              Wild Free.....DETECTED
                              Underflow.....DETECTED
                              Overflow......DETECTED
                              Unfree 1......DETECTED
                              Unfree 2......DETECTED
                              ALLc range: [0x811D678C:0x82AD778B](size=26218495 bytes)
                              Linear malloc range: [0x833855B0:0x87EFF000](size=79141456 bytes)
                              !!! Maxi malloc size =79141440 (st=833855c0, end=87eff000)!!!!
                              ifx_system_init() in:<6>CPU revision is: 00019556 (MIPS 34Kc)
                              Lantiq xDSL CPE VR9
                              Reserving memory for CP1 @0xa7f00000, size 0x00100000
                              <6>Lantiq CGU driver, version 1.1.27, (c) 2001-2011 Lantiq Deutschland GmbH
                              <6>Lantiq ICU driver, version 3.0.1, (c) 2001-2011 Lantiq Deutschland GmbH
                              mips_hpt_frequency = 250000000, counter_resolution = 2
                              <6>IFX DMA driver, version ifxmips_dma_core.c:v1.0.17
                              ,(c)2009 Infineon Technologies AG
                              Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
                              Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
                              <6>Infineon Technologies DEU driver version 2.0.0
                              <5>IFX DEU DES initialized (multiblock).
                              <5>IFX DEU AES initialized (multiblock).
                              <5>IFX DEU SHA1 initialized.
                              <5>IFX DEU MD5 initialized.
                              <6>gptu: misc_register on minor 255
                              ifx_gptu_init: line=960, done!!
                              <6>Lantiq SSC driver, version 2.2.6, (c) 2001-2011 Lantiq Deutschland GmbH
                              <6>Lantiq SPI flash driver, version 1.1.9, (c) 2001-2011 Lantiq Deutschland GmbH
                              <6>NAND device: Manufacturer ID: 0x98, Chip ID: 0xd1 (Toshiba NAND 128MiB 3,3V 8
                              -bit)
                              <7>Bad block table found at page 65472, version 0x01
                              <7>Bad block table found at page 65408, version 0x01
                              NAND: 128 MiB
                              <6>ifx_pcie_rc_class_early_fixup: fixed pcie host bridge to pci-pci bridge
                              <7>PCI: Setting latency timer of device 0000:00:00.0 to 64
                              <6>Lantiq PCIe Root Complex driver, version 1.5.3, (c) 2001-2011 Lantiq Deutschl
                              and GmbH
                              PCI: Enabling device 0000:01:00.0 (0000 -> 0002)
                              <7>PCI: Setting latency timer of device 0000:01:00.0 to 64
                              === pAd = 83bc9140, size = 764064 ===
                              <-- RTMPAllocTxRxRingMemory, Status=0
                              RTMPAllocAdapterBlock: BeaconTxWI = 0x83bd4da8, BeaconOffset = 0x83bd4dc0
                              <-- RTMPAllocAdapterBlock, Status=0
                              MacValue=0x53920223, CSRBaseAddress=0xBC000000
                              Efuse Size=0x2d [2d0-2fc]
                              RtmpEepromGetDefault::e2p_dafault=1
                              RtmpChipOpsEepromHook::e2p_type=1, inf_Type=5
                              efuse_probe::bUseEfuse = 1
                              NVM is EFUSE mode
                              Not Fiber WAN: 0, 0
                              IFX SWITCH API, Version 1.1.7.2
                              Switch API: PCE MicroCode loaded !!
                              PHY0/1 addr(0x11/0x13)
                              <3>GPHY FW load for A2x !!
                              GPHY FIRMWARE LOAD SUCCESSFULLY AT ADDR : 0x770000
                              etc
                              I don't know which software to use for make an upgrade and how to put the cpu in ''upgrade mode''
                              Thank you
                              • cpt.charlie
                                • Sep 2013
                                • 270
                                • Spain
                                Does the message repeat over and over? if not, it is not rebooting. There are a few messages about bad blocks, this could be the problem, maybe erasing the chip and writing the firmware again may fix it, if not you also have to replace the chip but of course you need an external programmer.
                                • tehmatix
                                  • Nov 2012
                                  • 174
                                  Do you think is this toshiba chip TC58NVG0S3ETA00 with some problem ?
                                  • tehmatix
                                    • Nov 2012
                                    • 174
                                    When I press reset button and turn on , the router expect firmware from Lan port
                                    ROM VER: 1.1.4
                                    CFG 05
                                    ROM VER: 1.1.4
                                    CFG 05
                                    DRAM Size: 128 MB
                                    WarmBoot: 0x1048008
                                    start upgrade
                                    Enter TFTP Server F/W Upgrade Mode
                                    Internal phy(GE) firmware version: 0
                                    TFTP Server IP: 192.168.1.1
                                    • tehmatix
                                      • Nov 2012
                                      • 174
                                      Yes , this message is repeating on the loop
                                      • cpt.charlie
                                        • Sep 2013
                                        • 270
                                        • Spain
                                        Is the router acting like an TFTP server? Can you connect to it? if not you could start a local tftp server with the firmware on it, the router may try to read the file and start a programming process, btw contact with draytek support, they may be kind enought to explain how to set properly the server or at least tell the name of the file that the router is expecting.
                                        • double_DD
                                          Why does my ISP router hate my "homemade" power supply??
                                          by double_DD
                                          It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                          So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                          For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                          07-12-2025, 03:09 AM
                                        • madan1
                                          Unbricking Vigor AP
                                          by madan1
                                          Good day.
                                          I'm posting this to help other people.
                                          If you have a Vigor AP with some kind of a software issue or just with an unknown admin password and disabled reset button, here is how you can flash a fresh firmware.
                                          Download the firmware from the vigor's website and extract it somewhere.
                                          Download TFTPD64 or other tftp client with file push.
                                          Connect to the unit with an ethernet cable and set your client IP address to 192.168.1.10 (just not .1 or .2).
                                          Start TFTPD64, go to tftp client tab. Select the server interface with the above IP and...
                                          06-18-2025, 02:32 PM
                                        • tommy97
                                          MacBook A1932 & A2337 MDM - Permanent solution?
                                          by tommy97
                                          we're getting quite a lot wiped A1932 & A2337 from scrap with MDM (Remote management), we'd like to find permanent solution to remove it without CPU swap as it gets not economical, I found iremove.tools website which offer permanent solution, however if they got shut-down i believe laptops would also get locked? Does anyone have any knowledge about this service & about any other possible method?
                                          06-18-2025, 02:43 AM
                                        • shadow666
                                          Router Xiaomi M4A Gigabit
                                          by shadow666
                                          hello
                                          i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                                          Mi Router 4A Gigabit Edition
                                          ROM CHIP is 16 MB
                                          i attached picture of motherboard​...
                                          11-30-2024, 03:49 PM
                                        • EasyGoing1
                                          UPNP, "Standards" and hardware that implements it
                                          by EasyGoing1
                                          I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                                          One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                                          So I decided to implement UPNP...
                                          07-16-2022, 07:12 PM
