weard network problem
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Problem was can't access Google Maps, Google News and Youtube. Found that the Network Address Translator thought 2 devices were addressing it. Solution was to reset Comcast modem and Netgear Ethernet Switcher. So not know a great deal on a NAT I am wondering why this got screwed up?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: weard network problem
    is it a modem and a network switch? no router? having a network switch on a MODEM and not a ROUTER will attempt to assign PUBLIC ip addresses to your device. Most ISP's only allow one or two public IP's. Having a router (NAT) lets you map the single public IP to several private IP's. If you're using just a switch and a modem with no routing, the different devices connected are going to fight for IP addresses, and it will only assign one or two at a time
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      So it is a Comcast modem connected with through the Ethernet to to a Belkin wireless Router and that wireless Router is they connected through its Ethernet to a Netgear SW. So the complete description is there is one input line into a Comcast modem which then is connected through the Ethernet to a Belkin wireless router that Router is then connected through it's Ethernet ports to two separate Ethernet switches, one switch for the tenants and one for the staff. If other machines are connected to the wireless router wirelessly I do not know.
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        It is not unusual for network devices to hang and need a power cycle once in a while.
          • 31283
          if the firmare is shit.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Hardware too. Even in higher scale gear.
              • 31283
              my TP-Link stuff never needs a reboot.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                nor linksys with DDWRT, or Asus with Tomato!
                Follow the white rabbit.
                • SteveNielsen
                  Retired Tech
                  • Jun 2012
                  • 2327
                  I can't say that I have any recent experience with any newer enterprise gear but when I was working in networks router reboots were required under certain circumstances every so often when errors accumulated too quickly and they basically ran out of RAM.
                  Home wifi routers I've used are not without issues, even using DD-WRT. ISP supplied modems also have a need to reboot once in a while in my experience.
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    I just wanted to know why it is happening, with this particular problem.
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      Is it a recurring problem?
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        I do not know as the problem happened about 4 days after they reprogrammed the computers, after I took one computer over. Then this problem went on for about one week before I figured out what happened. I then convinced the live in manager to open a lock door and restart both the switcher and modem. That took care of the problem, but I figure the problem should not happened in the first place.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          The problem shouldn't happen as many problems with computers shouldn't happen but they just do.
                          Belkin is cheap home kit and I know Netgear switches suffer from bad caps.
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            To me if this is the case then the people who design and program these devices need to get together and figure out the problem so they do not happen again. Just accepting that this is the case, to me, is not an answer. When I was a technician and a problem occurred we would inform the engineering department. The engineering department would determine if it was created by one or several different areas. If it was several areas they would take 3 engineers and solve the individual areas that created the problem so the problem did not happen again.
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              So with your information the problem would appear to be in the Belkin Router because the router is assigning the NAT. This makes sense because I heard the other Ethernet Switch for the staff which also is connected to this router was a having similar problems. The thing is I did not reset the Belkin Router. I just reset the modem and the Ethernet Switch and that cured the problem.
                                • 31283
                                if it happens again, just reset the modem and see if it fixes it.
                                a lot of cheap modems / routers have badly written firmware that slowly leaks memory until you have no free ram left.
                                the Linux based ones are usually fine, it's the ones with less flash that use operating systems like VxWorks that seem to be poorly written.
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  Stj I will try that if it happens again which I am sure it will. Usually problems don't go away by their selves.
                                  • SteveNielsen
                                    Retired Tech
                                    • Jun 2012
                                    • 2327
                                    Well, the modem and router are different devices in this situation. He said it was an NAT problem. The router does the NAT, not the modem. I'd reset the router.
                                    I agree that the Belkin router would be better running a Linux-based OS if for no other reason than giving a lot more control of the router, but it may not cure the real problem if it is due to a hardware flaw that cause the memory leak. I've used a Belkin wifi router running DD-WRT but it still needed rebooting now and again. Tweaking parameters to use less memory helps delay running out of memory but it does not prevent it.
                                      • 31283
                                      what are the makes and models of the equipment?
                                      maybe it can be flashed with http://openwrt.org/
                                      • keeney123
                                        Lauren
                                        • Sep 2014
                                        • 2536
                                        The thing is that I did not reset the router to cure this problem. I only reset the modem and the switch and left the router on. The problem came up as the NAT saw two devices addressing it and it said it could only be address with one device. I am not really sure what that means, but I can tell that was the problem. I do not know all of the model numbers in this case I would have to get the manager to open the door again and look at them. I wonder if the SSL could of cause this error in the NAT. This is what I noticed, but may not of caused the problem. I was sitting at one computer and the computer next to me began to beeping. A notice from Comcast came up on the screen saying they detected some illicit site. The notice was a page long and would not allow any computer functions on that computer. I reset the computer because I was tired of hearing the beeping sound. Seems to me after that happened then the problems occurred. Yesterday I had one guy that admitted to watching or trying to watch pornography on these computers. I told him that they know who is doing this as they can tell the time it happened and they have a camera that shows who is sitting ate what computer at what time. I do not understand why someone would want to watch pornography in a public place.
                                        • double_DD
                                          Why does my ISP router hate my "homemade" power supply??
                                          by double_DD
                                          It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                          So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                          For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                          07-12-2025, 03:09 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • davg
                                          Home network connection problem
                                          by davg
                                          I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                          03-06-2021, 07:13 AM
                                        • japlytic
                                          Maximum speed should be marked on network ports
                                          by japlytic
                                          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                          12-19-2024, 05:04 PM
                                        • Hondaman
                                          Hardware firewall to block ad servers?
                                          by Hondaman
                                          I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
                                          The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
                                          02-05-2025, 05:04 AM
