Security camera linking remotely to NVR
  • CapLeaker
    Leaking Member
    • 8219
    I've got already a 16 port NVR installed at a certain location. The building owner wants to add 4 IP cameras on a different building 500m away from the main building.
    My way going about is to install the cameras on the off site building, connect them to a 8 port POE switch, install a wifi bridge and plug that into that POE switch too. That should do the remote side. Easy.
    The main building should have the other end of the wifi bridge.
    Did any one try to hook a wifi bridge staight up to the NVR's camera POE port?
    I do know that usually the wifi bridge is hooked up to a switch together with the NVR's internet port. But why not connecting the bridge directly to the NVR's camera port?
    Never seen anything or anyone doing it that way.
  • diif
    • Feb 2014
    • 6978
    • England
    What NVR are you using that allows you to connect more cameras than ports, or are less than 12 cameras being used already?
    • CapLeaker
      Leaking Member
      • 8219
      Yeah, forgot to mention it's a Northern N2 16 port NVR. Only half of them are currently used, The plan of thought was to connect one end of the bridge right to the NVRs POE port where the IP cams hook up to. Never heard anybody doing it this way, but I thought it wouldn't hurt to try
      i squiggled something quickly up…
      • diif
        • Feb 2014
        • 6978
        • England
        I would think it is down to the software on the NVR, I was reading that something similar has been done using a hikvision NVR.
        You might need to set static IPs of the new cameras perhaps.
          • 31090
          do you have line-of-sight between the buildings?
          • CapLeaker
            Leaking Member
            • 8219
            Line of sight for the wifi bridge, yes. This should work for one remote cam for sure, interesting question is, does it also for 4 cams, because they end up on one port of the NVR.
              • 31090
              the recorder is going to have a hard limit based on cpu, ram etc.
              the port itself is probably fast enough - i presume it's gigabit.
              if not you may have to look into the stream bandwidth from each camera and if it's an option maybe drop the resolution or framerate
              • CapLeaker
                Leaking Member
                • 8219
                CPU, RAM on the NVR shouldnt be a problem. The NVR has 16 ports and with the 4 new CAMs it would be only having 12 in total. So there is room for 4 more CAMs after this expansion. I think the POE ports run on 100mbit.
                • ant3202
                  • Jun 2006
                  • 275
                  • Singapore
                  I had deployed on one site before, using ubiquiti, with parabolic antenna
                  most had raised a good point is LOS
                  normally my concern is lighting strike on the pole which can fry those connected devices, thus some sites we do this:
                  Main Office
                  Customer Network > Customer Network Switch > Fiber Media Converter > Fiber Cable > Fiber Media Converter > Power Injector > Parabolic Antenna
                  Remote Site
                  Outdoor Antenna > Power Injector > Fiber Media Converter > Fiber Cable > Fiber Media Converter > Customer Network Switch > Remote Site Network
                  so far I had observed from other setup from other vendors .. like they are using like,
                  engenius long range
                  https://www.newegg.com/global/sg-en/...9uNSTNYdPTcLJQ
                  mikrotik long range
                    • 31090
                    i'm not sure 100Mb is enough for 4 streams - maybe but it depends on the resolution and framerate
                    if it's compressed it will also depend on how much of the image is static and how much changes
                    • CapLeaker
                      Leaking Member
                      • 8219
                      Not worried about lightning as I got proper lightning protection. I did a few WiFi bridges before with zero problems that ran over 10 years on high points only to get replaced by me again in order to ged faster connections.
                      What I haven’t done yet is to put multiple cam streams down one wire straight to the switch POE part of the NVR. In theory it should work, unless the POE switch with its own router part cannot handle more than one IP per port.
                      • CapLeaker
                        Leaking Member
                        • 8219
                        Just got around to this again. I tested this configuration yesterday on the bench and this plan as in my post #3 didn't work out. The POE ports on the NVR do NOT allow multiple IP addresses on a single POE port. I could see all the cameras on the list, but only one was connected. I could select a different one, but then the first one got disconnected. Unplugging the connection from the bridge to the POE ports over to the internet side of the NVR through a network switch worked fine as kind having 4 cams through the wifi bridge and going to the NVR. Only problem with it is I need four 192.168..xxx.xxx addresses.
                        Other than that, it works perfect.
                        • CapLeaker
                          Leaking Member
                          • 8219
                          Well, after laying a total of about a 1000ft of shielded, direct burial CAT6 through the building for 4 cams and wifi bridging it to the main building where already a 16 port NVR exists, it works absolutely perfect. Challenges were the crazy 24 feet ceilings.
                          • Henryko
                            • Sep 2024
                            I haven’t tried connecting a WiFi bridge directly to the NVR’s camera POE port myself, but it seems like a reasonable experiment. Usually, the bridge goes to a switch with the NVR’s internet port, but connecting it straight to the POE port could work if it’s just for the cameras.
                            • CapLeaker
                              Leaking Member
                              • 8219
                              Well, it does and does not. It works if you do one camera. But the NVR is unable to assign more than one IP on the camera ports. That means if you put 4 cameras on the WiFi bridge and plug it into the NVR camera port all you get is one cam. The other 3 are there, but you can only connect to one at a time.
                              My NVR cam extension is getting even further extended soon. Interesting thing is that now the line gets extended another 300 ft with coaxial cable. So I need some MoCa 2.5 adapters. This thing is getting crazy!
                                • 31090
                                i just fixed an NVR - SWAN 8 input.
                                cpu fan had seized after 7 years of 24/7 running, not bad for a SUNON 40mm!!
                                also did a recap - it was full of crap as usual and replaced the thermal pad with MX4.
                                after new caps & fan - good as new if not better.
                                • CapLeaker
                                  Leaking Member
                                  • 8219
                                  Nice fix stj! I've done last year a Northern 32 cam input NVR that was 8 years old at that time. Replaced a few caps in the power supply and she is still working A1. Mine is a 8 input cam system, but I swapped the fans out for Noctua's from the get go, I wasn't going to have it listening to the fan noise. Works great! I had to reboot it once, but that was it.
                                    • 31090
                                    no fan noise on this, it uses a low rpm fan.
                                    probably why it lasted 7 years
                                      • Jul 2011
                                      • 6046
                                      Is there a workaround for this because I am following this post for knowledge and information about what can be done
                                      • CapLeaker
                                        Leaking Member
                                        • 8219
                                        Maybe a firmware update? Problem is that you can't put 16 cams on a 100Mbit LAN. However, 4 or 6 is no problem at all at that speed. The only thing that you can do is like I did. Put the NVR on a internet switch, put the Wifi bridge on the same switch, let the router assign IP's and pick up the CAMs from the LAN side with the NVR. I did assign static IPs to those cams on the LAN. Other than that it works perfect. Have it running like that for months now.
                                        Meanwhile I got another new project. Installing a full blown RX / TX ADSB system, the commercial version which requires a yearly license. Lets see how that goes. the other MOCA ethernet over coax expansion is on hold at the moment until I got this sorted.
                                        • Ross Kohler
                                          Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                                          by Ross Kohler
                                          I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                                          - There's no sign of any attempt to power on when pushing the power button.
                                          - No PSON signal is reaching the 24-pin ATX connector.
                                          - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                                          - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                                          - If I pull the Super IO S_SLPS#_R pin...
                                          04-16-2024, 09:36 AM
                                        • Roman555
                                          Asus H77 LGA1155 mainboard stopped working with Ivy Bridge CPUs
                                          by Roman555
                                          Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
                                          • Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
                                          • USB stick with MS-DOS can be loaded via F8 boot menu;
                                          • Other OSes won't load - hangs or goes reboot;
                                          • Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
                                          • An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
                                          What I've already done and it hasn't helped:
                                          • Cleared CMOS many times;
                                          • Flashed different versions of BIOS in a CH341 programmer;
                                          • Updated
                                          01-18-2024, 06:26 AM
                                        • Byte_76
                                          Gainward GTX 295 SLI Bridge
                                          by Byte_76
                                          I have a Gainward GTX 295 with two PCB's which has a broken SLI bridge ribbon cable. As a result, the card is entirely useless and I'd really like to fix it if possible.
                                          I've searched eBay and AlieExpress but haven't been able to find the part.
                                          I believe this same SLI bridge cable is used on the Nvidia 9800 GX2 and the GTX 295 which both have two PCB's.
                                          Can anyone help me on where to get a replacement SLI bridge cable please?
                                          05-10-2024, 03:07 AM
                                        • Steph.hen
                                          Bridge rectifier identification part number KPB305G
                                          by Steph.hen
                                          Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                          I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                          08-29-2024, 09:52 AM
                                        • pkslowk
                                          Debug Card Error Code and Solution
                                          by pkslowk
                                          Sr. Motherboard Debug Error Code Solution
                                          1 Intel 845 E9 Bios Related Problem
                                          2 Intel 845 D4 CPU Socket Related problem
                                          3 Intel 845 37 Bios Related Problem
                                          4 Intel 845 7C Bios Related Problem
                                          5 Intel 945GCPE 34 Bios Related Problem
                                          6 Gigabyte 845 2 Ram Related Problem
                                          7 IBM Server A6 A7 Ram Mismatch Problem
                                          8 Asus 845 29 CPU Related Problem
                                          9 Lenovo I946 97 C-Mos Jumper related
                                          10 Gigabyte 845 A0 CPU Related Problem
                                          11 Asrock G31M-VS D7 Bios Related Problem
                                          12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                                          01-28-2021, 12:51 PM
