ESR-1221N Dissembly
  • Yatti420
    • Mar 2008
    • 130
    ESR-1221N Dissembly
    ESR1221N Dissembly
    1 x Jackon 16v 1000uF
    1 x Gemcon 6.3v 470uf
    Comes with switching power supply (not checked).. Inspected the router board.. Looked fine as this is a new router no recap planned yet.. It looks like Jackon and Gemcon both had problems in the past.. I wonder how these will hold up.. This is a micro router/case so needs mini caps... I have camera phone pictures to follow..
    1 screw under sticker needs to come out.. If you can't loosen top case tabs use an old credit card where the lan ports are.. On the side without antennae..
    See ya,
  • lti
    • May 2011
    • 2545
    Re: ESR-1221N Dissembly
    I've never seen bad Gemcon caps. Actually, I've never seen those outside of that Japanese cap manufacturer database.
    I would replace the Jackoff cap, but I don't think people consider them to be that bad. I replace as many of them as I can because I've seen so many fail.
    • Yatti420
      • Mar 2008
      • 130
      Thanks for the info.. I might just recap it for fun.. It's only 2 caps anyways..
      • shadow666
        Router Xiaomi M4A Gigabit
        by shadow666
        hello
        i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
        Mi Router 4A Gigabit Edition
        ROM CHIP is 16 MB
        i attached picture of motherboard​...
        11-30-2024, 03:49 PM
      • EasyGoing1
        UPNP, "Standards" and hardware that implements it
        by EasyGoing1
        I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
        One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
        So I decided to implement UPNP...
        07-16-2022, 07:12 PM
      • hinisa
        Xiaomi router freezes at boot after re-capping
        by hinisa
        I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
        When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
        After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
        Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
        07-08-2023, 05:58 AM
      • spleenharvester
        Synology MR2200ac mesh router, UART connection - login details?
        by spleenharvester
        This particular unit powers up, LEDs behave normally, but broadcasts no SSID, will not mesh with any other routers. Plugging in an ethernet cable from a Windows laptop results in "unidentified network" with an autoconfigured IP address and no response to pinging 192.168.1.1.
        I was able to log into serial/UART by connecting the 6-pin header to the GPIO on a Raspberry Pi Zero W (GND to GND, TxD to RxD, RxD to TxD, no connection between +3.3V as it is supplied on both sides) using Minicom, command:
        Code:
        sudo minicom --baudrate 115200 --device /dev/ttyS0
        09-02-2024, 01:19 PM
      • filippia1981
        Starlink WiFi router firmware of the HR1211 IC
        by filippia1981
        Hi, I would like to ask if someone has the firmware of the HR1211 IC of the Starlink WiFi router in order to program a new IC
        The diagnosis showed that this IC is shorted and need to be replaced with the right firmware. I cannot find the firmware
        kind regards
        Ioannis Balouktsis
        06-17-2024, 11:38 AM
