Physical security for wireless networks
  • japlytic
    • Oct 2005
    • 2086
    http://youtu.be/kRhyvRAUG6k
    This is one of the less-discussed wireless security issues, as far as I know.
  • slackwarerobert
    • Apr 2013
    • 13
    • Third World Dictatorship
    Re: Physical security for wireless networks
    Can the public get access to those cell jam paints? I seem to remember something almost like a paint for the walls, you turn it on and zap any signal from getting through. Never said if you can use it to paint outside of house, but that would do the trick. It is bad enough you have to mount small speakers to generate white noise on the windows to stop laser snooping.
    • japlytic
      • Oct 2005
      • 2086
      I believe if I approach the manufacturers about this problem, most (if not all) of them would put it in the "too hard" basket.
      • japlytic
        • Oct 2005
        • 2086
        Over two weeks ago I contacted Belkin with few hurdles; as I expected, it appears that Belkin has put this problem in the "too hard" basket.
        • exevolution
          • Aug 2013
          • 9
          • Not telling
          Physical security is the responsibility of the administrator/owner.
          If you allow someone physical access to your home router, a simple reset button can be enough to get access as most home ISPs use DHCP and most routers ship with no wifi password by default.
          That said this is a nice find, and I will continue to not use WPS
          • japlytic
            • Oct 2005
            • 2086
            All you need to do is get the WPS PIN and/or push the pushbutton for this function - as per the video, I extracted the wireless passphrase with those two methods - no special tools required!
            • Yatti420
              • Mar 2008
              • 130
              I disable UPNP.. WPS.. Anything that can be a vector for attack.. I've never used UPNP and it's now one of the biggest security concerns facing router/computer manufacturers..
              Edit: Not only do I disable on router I usually take out windows support aswell.. Somehow upnp server streams can still receive and still work oddly...
              This podcast sums it up nicely.. https://media.grc.com/sn/sn-389.mp3 ( Learned ALOT here https://www.grc.com)
              • NUKLEAR-SLUG
                • Jun 2013
                • 8
                Both of which still require physical access to the device. If someone has gained physical access to your hardware then you've already been compromised so while interesting this isn't really that much of a big deal.
                • LLLlllou
                  • May 2011
                  • 201
                  Exactly, it's hardly a security flaw. It's like saying there's a security hole because anyone with the wireless password can get access, or anyone can get access by plugging an ethernet cable into the router..
                  My front door has a security flaw, anyone with the key can get in.
                  • Yatti420
                    • Mar 2008
                    • 130
                    UPNP issues are far more scarier.. Zero authentication.. Lots routers (among other devices) are flawed.. D-Link fixed the DIR-655 .. I don't know about anything older however..
                    • japlytic
                      • Oct 2005
                      • 2086
                      Here's a story which could gain traction on this issue: http://crowdsupport.telstra.com.au/t...ght/true#M6375
                      • japlytic
                        • Oct 2005
                        • 2086
                        Gaining a bit more traction:
                        https://nakedsecurity.sophos.com/201...ur-own-crypto/
                        Recently, I made posts to Netgear, D-Link, Belkin and Linksys with the attached service bulletin; no response from Netgear with Belkin and Linksys looking into it, but D-Link said that they stand by their security features.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          This is all home kit, designed for the average consumer. It's not really an issue, if someone has physical access to your hardware it's game over anyway.
                          The kind of person that breaks into houses does not do it do get on my wifi but to steal my TV and shiny stuff. Any business being cheap and either using home kit or not employing a pro is asking for trouble.
                          The far smarter thing would be to access the router and change the DNS settings.
                          p.s. Linksys is owned by Belikin now.
                            • 30979
                            smart people dont use the router DNS.
                            some isp supplied Belkin-sys routers ignore the setting and use a hidden DNS server for tracking.
                            this was discovered a couple of months back when the server went down and people all over the u.s. and a couple of European country's couldnt get online and the ISP's couldnt work out why!!!
                            • Hondaman
                              • Sep 2008
                              • 1058
                              ...some isp supplied Belkin-sys routers ignore the setting and use a hidden DNS server for tracking.
                              Can you point us to more information about this? Can this flaw be made less serious? Can it be eliminated?
                                • 30979
                                all anybody knows is some models - probably isp-supplied use a fixed DNS and ignore the settings in the menu's
                                the DNS seems to be connected to the router manufacturer and not the isp's
                                (BTW. Nokia fones do this too.)
                                as for doing anything about it,
                                all i can say is try to replace the firmware:
                                https://openwrt.org/
                                http://www.dd-wrt.com/
                                http://www.gargoyle-router.com/
                                and use a NON-ISP DNS server.
                                http://www.opennicproject.org/
                                • japlytic
                                  • Oct 2005
                                  • 2086
                                  More traction on this issue: http://www.tomsguide.com/us/home-rou...ews-19245.html
                                  A visiting tradesperson could get the PIN number or push the WPS button.
                                    • 30979
                                    a lot of router default keys are atleast partly based on the mac address.
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      I was at a german restaurant and the company next door had an unpassworded AP. I connected, found a shared printer on a computer. got the driver, connected and printed out that they should secure their access point. I also pointed out that they had shared access to a bunch of access db's-customer list and their quickbooks file (albeit was passworded). Next week it had a password on it
                                      • japlytic
                                        • Oct 2005
                                        • 2086
                                        I found good search terms to find the physical security problem, being "Wi-Fi Protected Setup" and "physical security" - the issue is slowly but surely gaining traction.
                                          HP EliteBook 830 G6 + Pan/Tilt Home Security Wi-Fi Camera Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 830 G6 + Pan/Tilt Home Security Wi-Fi Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Pan/Tilt Home Security Wi-Fi Camera boardview and 830 G6 + Pan/Tilt Home Security Wi-Fi Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 07:50 PM
                                          HP EliteBook 850 G6 + Pan/Tilt Home Security Wi-Fi Camera Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 850 G6 + Pan/Tilt Home Security Wi-Fi Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G6 + Pan/Tilt Home Security Wi-Fi Camera boardview and 850 G6 + Pan/Tilt Home Security Wi-Fi Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP ProBook 430 G7 + Pan/Tilt Home Security Wi-Fi Camera Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G7 + Pan/Tilt Home Security Wi-Fi Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Pan/Tilt Home Security Wi-Fi Camera boardview and 430 G7 + Pan/Tilt Home Security Wi-Fi Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 08:10 PM
                                        • sikocan
                                          Lenovo X1 Carbon 9th Gen Black Screen
                                          by sikocan
                                          I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                                          SN: PF3G1REP
                                          MODEL: 20KW-00J1AU
                                          PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                                          Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                                          06-24-2025, 09:01 PM
