Synology DS1520+ no power
  • H1ghl4nd3r
    • Jun 2020
    • 39
    I have a synology DS1520+ Here and just over a week ago when I tried to turn on the nas there was no power going to it, so I thought it was the power supply so I found a replacement (original power supply £80)
    I received the power supply a couple of days ago and finally got 5minutes to myself to plug it in a and test it, but again no power going through, when I plug in the power supply the green led light on the power supply goes off, and when I disconnect it the green led comes back on?
    Could this be the same issue that plagued the Synology DS1515+ models?
    • 30965
    Re: Synology DS1520+ no power
    sounds like something is shorted out.
    • SluggerB
      • Aug 2020
      • 747
      • US
      stj is right, sounds like a short or something else drawing to much power, and the power supplies protection circuity is kicking in
      Open it up and look for anything obvious. Then follow the power rails and start testing the transistors along that path and see if one of them failed. That was the issue with a amplifier I had that was doing the same thing.
      • H1ghl4nd3r
        • Jun 2020
        • 39
        Thanks for the reply guys.what you both said makes sense.
        I have attached pictures of the whole brake down process on this nas, it has twice as many screws of a 1515+
        Reason for so many pics is there is no real info on this model yet so thought it may help others down the line.
        I can’t see anything out of place on either side of motherboard, my wife’s puppy managed to get a hold of my multimeter and so I need to get a replacement today hopefully otherwise I have to order 1.
        Also I changed the bios battery last time as well
          • 30965
          check that big diode - d10 first
          • H1ghl4nd3r
            • Jun 2020
            • 39
            Ahh this 1 highlighted, thought it was something else for a couple of minutes
              • 30965
              yes, that.
              i think it's across the power to protect from reverse polarity.
              • H1ghl4nd3r
                • Jun 2020
                • 39
                I managed to find a multimeter when I had to stop in B&Q for a new surge protector power supply, attached a pic of what I got.
                Also the chip number is SK34C, there is a g03 in front of it but it could be batch number, I have found the data sheet for it here
                https://datasheetspdf.com/datasheet/SK34C.html
                Any idea what I should expect? as I'm going to strip it back down when I get a chance
                  • 30965
                  your just looking for something shorted.
                  • CapLeaker
                    Leaking Member
                    • 8065
                    Or resistors that are open / or way out of speck.
                    • H1ghl4nd3r
                      • Jun 2020
                      • 39
                      Thanks guys, I completed the test and thought it was better to video and show rather than try to explain it
                      I have uploaded the video of it here
                      https://ulozto.net/file/oKIu3FjNTuNd...ufAKWmZGOwZt==
                        • 30965
                        i'll wait for the transcript
                        • H1ghl4nd3r
                          • Jun 2020
                          • 39
                          1st time I got 0003, when I switched probes I was getting 0002 and the final try numbers fluctuate, then drop to 0001 within a couple of seconds
                          Just retried and now I get 0001 and 0000 on both sides
                            • 30965
                            then it may be bad,
                            but you wont know till you unsolder aleast one end and test again.
                            • H1ghl4nd3r
                              • Jun 2020
                              • 39
                              Originally posted by stj
                              then it may be bad,
                              I have been looking around and can't find any SK34C in the UK, I don't mind popping half the chip off but might be an idea to find a replacement part as well.
                              Also is it better to remove the side where there is a strip a triangle and 2 squares?
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Inject voltage and see what gets hot. Also I did as google and there's people claiming open circuit resistors in this unit causing this not short. See how much power is being drawn from the mains when the device is connected. Does anything get hot ?
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Hey im in telford too, bring it to me
                                  • H1ghl4nd3r
                                    • Jun 2020
                                    • 39
                                    I did wonder if there was a possibility that there was no voltage going into the chip, the multimeter only gives a small amount of power, but my knowledge is limited
                                    When u say Inject voltage do you mean plug in the power supply into the mother board and see if anything gets hot?
                                    Also how do I see how much power is being drawn from the mains when the device is connected, I don’t have anything to test that.
                                    Shame I’m down south to you in Wales
                                      • 30965
                                      melt the solder at one end of the diode and slip a blade or sheet of card under it to isolate it from the pad.
                                      • H1ghl4nd3r
                                        • Jun 2020
                                        • 39
                                        I finally get some time to myself and the 1 thing I don’t have that I need is solder wick, and I didn’t realise this until I stripped down the Nas and setup the soldering kit
                                        I managed to get the excess off but for the last part, I’m going to need the solder wick to clean up the bit that still holding the side of the chip and want to do it properly
                                        If it isn’t the problem I can solder it back down, and if it is the problem finding a chip to replace it, only place I have found them is on eBay but only in batches of 50 from china, so that’s around a month wait
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • CMCM
                                          Russound CA4 Power Supply Repair
                                          by CMCM
                                          Hello Everybody,
                                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                          The outputs marked 12v and 20v are all measuring only 1v.
                                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                          The capacitors physically look clean (no bludgesor leaks) and...
                                          07-03-2025, 01:12 PM
