Synology DS1520+ no power
    • 30955
    Re: Synology DS1520+ no power
    if you know the voltage and current and package type you can just look up an equivelent at rs or cpc/farnell or rapid
    • H1ghl4nd3r
      • Jun 2020
      • 39
      I would have to double check and make sure that it's the correct paperwork as I have seen some being misleading.
      But may be an idea to start looking at a few of the company's you mentioned I knew of 2
      I'm just waiting on the solder wick so I can clean and remove the 1 side of the SK34C chip
      • H1ghl4nd3r
        • Jun 2020
        • 39
        It is something to look into, I spoke with the guy selling the chips and he says they are the same model, but with the Chinese you have to be sure as it’s a nightmare trying to return everything, plus can take up to a month to get the chips.
        The solder I ordered got lost in the post and only yesterday a replacement was dispatched, so hoping today or tomorrow I will get the solder so I can find out for sure, it’s frustrating at times waiting
          • 30955
          i get solder from CPC
          • H1ghl4nd3r
            • Jun 2020
            • 39
            Sorry been away for a while due my wife’s mother passing away, wasn’t easy due to wife being polish and we live in the uk
            Anyway I have ordered a batch of sk34c and I upgraded my setup, wasn’t good enough for what I need to do
            Workstation with a blower, previous was just a soldering machine, also a few other things I won’t bore you with.
            Also looking at repairing iPads and iPhones also got a thermal imager for finding shorts on chips v’s manually checking each 1, also got a laminate machine and bubble machine for the screens up to 15’
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              03-31-2024, 02:12 PM
              07-01-2024, 06:34 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
            • CMCM
              Russound CA4 Power Supply Repair
              by CMCM
              Hello Everybody,
              Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
              Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
              The outputs marked 12v and 20v are all measuring only 1v.
              The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
              The capacitors physically look clean (no bludgesor leaks) and...
              07-03-2025, 01:12 PM
