Dell 2007WFP Won't Power On
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell 2007WFP Won't Power On
    Originally posted by pedro
    The USB board obviously produces a regulated +5V from the 19V supply. Is it a possibility that THAT is the supply for the logic board, and NOT the 19V? If they are going to use 3-terminal linear regs for 3.3v etc on the logic board, that would make sense.
    I'm sure it is. There appear to be four bucking regulators on the USB card. This is definitely an older design; I came across something similar on a Viewsonic VP211B; on that monitor the power supply put out about 18Vdc; the bucking regulators and the USB hardware were on the signal card.
    PlainBill
    • alexanna
      • Mar 2010
      • 1346
      #82
      I have a 2007 WFP that I am going to be working on today, the only problem it has is with one of the back lights. Initially when I was testing this on the bench I neglected to have the USB board attached, and of course the monitor would not work, so like pedro and PlainBill state it plays an important role in generating the other voltages.
      If you need to know what any of the good pin or component voltages on the USB board are let me know.
      • alexanna
        • Mar 2010
        • 1346
        #83
        Is F19 good on the USB board?
        • retiredcaps
          • Apr 2010
          • 9271
          #84
          I knew something about this design was different. Having a dead monitor work hasn't helped otherwise it would be easy for me to get the voltage readings off each pin connector.
          --- begin sig file ---
          --- end sig file ---
          • croket
            • Oct 2011
            • 18
            #85
            Next, what are the voltages on each of the 12 pins connecting the signal card to the USB card?
            There are 4 regulators you have indicated have 19V on two pins. What are the part numbers of those 4 ICs?
            Last, what is the part number of U2 on the USB card. What is the voltage on the three pins?
            PlainBill
            Retiredcaps I re-tested with the USB board disconnected but had the same results.
            I've uploaded some additional pics, one shows the bottom side of the usb board indicating the pins getting voltage,(took the picture first then plugged the board in ) the other is the U2 chip. The 4 IC's with 19v are part# J598.
            I'm trying to be as detailed as possible with pictures guys , but if its too much I'll tone it down. I figured pictures tell a thousand words!
            Thanks for jumping in on this Plainbill and Pedro.
            • croket
              • Oct 2011
              • 18
              #86
              Yes F19 gets 19v in and 19v out
              • PlainBill
                • Feb 2009
                • 7034
                I for one appreciate the detailed pictures. It makes it a lot easier if I can SEE what the part number is, and it makes it a lot easier if I can say 'What are the voltages on pins 9 and 15 of U3 and U4?' rather than have to download a picture, load it into Paint, circle ICs, and ask what the part number is.
                Which brings us to the next step. What are the voltages on pins 9 and 15 of U3 and U4? Does 19 volts appear on any of the pins of the white connector on the left side of the USB board? What connects to that connector?
                Briefly, these boards are a step back from what I was expecting. U3 and U4 are dual pulse width controllers. The J598s are 2SJ598, a P-Channel FET.
                PlainBill
                • croket
                  • Oct 2011
                  • 18
                  #88
                  On both U3 and U4, Pins 9 show 18v and pins 15 show 0v. The connector at the end of the board is for the actual USB ports (2 ports mounted on a small board with 4 small caps). That connector reads 0v on all 8 pins.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    What are the voltages on every pin of U3? U3 and U4 are the controllers for the DC-DC converter. As closely as I can determine, for some reason the gates of the J598's are not being driven.
                    PlainBill
                    • croket
                      • Oct 2011
                      • 18
                      #90
                      I've uploaded another picture detailing the leg voltage on U4, U3 also has the same voltage.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        OK, I'm going to have to figure out how to get a real live TL1451 to measure.
                        PlainBill
                        • alexanna
                          • Mar 2010
                          • 1346
                          #92
                          Here are some measurements I took on my board,
                          The inverter is not installed so there is very little load.
                          The row of 'g' fuses all have 5.12v
                          U3 and U4 have almost exactly the same pin voltages.
                          • croket
                            • Oct 2011
                            • 18
                            #93
                            Alexanna, if you power up just the logic board (with out the usb board) which pins have voltage & what do they read?
                            • alexanna
                              • Mar 2010
                              • 1346
                              #94
                              I will re-check a little later to make sure,but i think every thing is dead without the USB pulged in.All of the tests were done without the small USB board installed.
                              • alexanna
                                • Mar 2010
                                • 1346
                                #95
                                Without the USB hooked up I see 19v on the black and brown wires at the logic board
                                on pin #9 of the 12 pin conector to the USB right about .5v
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  If we are interpreting things correctly, crocket's board should be providing power to the signal card whenever the power supply is plugged in. The USB jacks will not have power unless a device is plugged into them.
                                  PlainBill
                                  • alexanna
                                    • Mar 2010
                                    • 1346
                                    #97
                                    It can get confusing; I will call the USBs big and small.
                                    The small board doesn't have to be installed for the big board to generate voltages for the signal board.
                                    However 5 volts is on the row of ‘G' fuses going to the connector for the small board.
                                    • croket
                                      • Oct 2011
                                      • 18
                                      #98
                                      Ok so your logic board is getting the same voltage on the pins as mine without the big USB board attached, so its safe to say the problem is isolated to the USB board. I don't get the 5v at the 'G' row.
                                      PlainBill, sounds like your on to something with the gates not opening.
                                      • alexanna
                                        • Mar 2010
                                        • 1346
                                        #99
                                        It has to be on the USB board
                                        There is a row of fuses that look to protect the circut going to the small usb conector,they have a 'G' stamped on them.
                                        Have you measured the voltages on the pins of the J598s?
                                        • croket
                                          • Oct 2011
                                          • 18
                                          #100
                                          Yes I did measure all 4 the j598s, I get 19v to both the legs on all them. The row of fuses stamped with "G" have no voltage getting to them.
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Mark01
                                            Dell Optiplex 7490 AIO - red power led after flash
                                            by Mark01
                                            Hi guys,
                                            This is my first post! 🚀
                                            I have no idea what I’m doing, but I’m learning by trial and error.
                                            I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                            07-04-2025, 12:54 PM
