Philips 190S LCD power problem
  • joeh
    • Jul 2011
    • 26
    #41
    Re: Philips 190S LCD power problem
    scuse me bill i test it in ohm and the digital tester says "1. " this is a bad functionality?
    • alexanna
      • Mar 2010
      • 1346
      #42
      A “1” on the left side of the display indicates the circuit is open or there is no connection between the 2 points you're measuring.
      If you see a 0 on the right side of the display that means there is no resistance in the circuit, that would be the reading you would expect to see with the 2 DMM leads touching.
      If you attach a picture of the transformer, He will be able to point to the pins you need to connect your leads to.
      • joeh
        • Jul 2011
        • 26
        #43
        Originally posted by alexanna
        A “1” on the left side of the display indicates the circuit is open or there is no connection between the 2 points you’re measuring.
        THIS IS THE TRANSFORMER cod. IT-E19-NB4004B
        tested side with 2 pin
        • PlainBill
          • Feb 2009
          • 7034
          Excellent. You measured the resistance between the two pins on the right end of the transformer. Set your DMM to the 2K Ohms range. If I read your initial measurement correctly, the ACTUAL resistance was about 550 ohms for the good transformer. Post a picture of the meter while you are making the reading.
          It isn't unusual for a winding to break. That would give you a reading of open. If the transformer is bad, they are available on eBay for $9.00, including shipping.
          PlainBill
          • joeh
            • Jul 2011
            • 26
            #45
            Thanks Bill, today i have replaced the faulty inverter with the new one and the monitor now lives again.
            • Proit
              • May 2012
              • Turkey
              #46
              Hi sir,
              i was test and no output 5 ,3.3,12 vdc and burned 6105,2103 and 7103 i was changed and no result and check PMW 8pins HV input and 19 VDC VCC 5 vdc
              • barista
                • Dec 2012
                • Belgium
                #47
                The CCFL backlight fails after 5 minutes, switching on/off and this will give me 5 more minutes
                The primary coil of the ccfl transformer measured a DC resitance of 450 ohms (not desoldered from board)
                I'have already replaced the Elcaps exept the 1000uf ( but they looks fine and measured the right val)
                It looks like i heave a thermal problem or my ccfl is failing
                How can i test the ccfl
                i can disconnect one ccfl pair and see what happens
                • selldoor
                  Slow Learner
                  • 7870
                  #48
                  You need to measure both secondary ( Not Primary) windings and compare them. I do not think that will be the problem if it stays on for 5 minutes.
                  Turn the brightness down and see if it stays on any longer.
                  It could be the ccfls or the wiring - do you have any spare bulbs or another monitor
                  or faulty laptop
                    I had worked on HP W XX series with bad lamp wirings, some of them be running for 3~4 hours before he baclights go out, found that the wires to the end of the lamps were just touching the lamp's end terminals, after heat up the wire will no loger make contact with the end of the lamp due to heat expansion. Fiex many of these HP W series from 17~22" all with the same failure.
                    You need to make at least two test lamps to verifiy the inverter board functions otherwise you will be spending lots of time try to figure out if you have lamp or board problem.
                    http://s807.photobucket.com/albums/y...HP/HP%20W1907/
                    http://s807.photobucket.com/albums/y...m/HP/HP%20W22/
                    Test lamps:
                    http://s807.photobucket.com/albums/y...g%20old%20CFL/
                    Bad lamps:
                    http://s807.photobucket.com/albums/y...klight%20lamp/
                    Example of the suggestion:
                    https://www.badcaps.net/forum/showth...130#post293130
                    • jetadm123
                      • 2169
                      #50
                      If you think you have a thermal problem, try accelerating the shutdown process using a blow dryer. Heat up various sections of the board to try and isolate the area that causing the shutdown.
                      • picturevalve
                        • Nov 2010
                        • 13
                        #51
                        It's 2016, and I've got a dead one of these with the T50P050.00 psu. Found the service manual here :
                        Mosfet 7103 s/c, 15v zener 6105 s/c, resistors 3117, 3154 ,3118, 3155 all high (all originally R51 or 0.51 ohm on my board), all electrolytics high esr except for 1000u 25v caps for some reason but all changed to be sure. Waiting for delivery of first 3 items to, hopefully, complete repair.
                        • picturevalve
                          • Nov 2010
                          • 13
                          #52
                          Forgot to say that NCP1203D60 current mode controller (7100) was also u/s.
                          All working again, would have been quicker to pay $20 for a new board.
                          But not so much fun.
                          • theone111
                            by theone111
                            3. Problem: TV shuts down
                            07-22-2024, 10:36 AM
                          • Duranitron
                            Asus x512dk rev 2.1 power on problem
                            by Duranitron
                            When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                            Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                            11-26-2024, 10:22 PM
                          • EazyBone
                            LG OLED55C9PUA power problem
                            by EazyBone
                            Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                            Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                            I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                            The power supply to t con is different story.
                            This...
                            06-23-2023, 07:43 AM
                          • Dr.d
                            Help please..Lenovo ideapad 5 14itl05 power and charging problem
                            by Dr.d
                            I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                            Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                            04-05-2024, 11:48 AM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
