It's my VX922 again - AC line noise?
  • Sparky
    High voltage
    • Jan 2007
    • 234
    First off, my VX922 that I repaired a while ago is still working just fine
    EXCEPT, I noticed that when I have it powered on with display, it causes my computer speakers to have a low-toned hum to them. This only happens when it is actually displaying an image. If it is in standby, or off but plugged in, it doesn't do it. Seems to be in sync with the backlight turning on.
    If I have it unplugged from the computer, it still causes the hum in the speakers for the moment that the display shows "No signal" on the screen, before it goes to standby and gets quiet. So it isn't causing the noise through the DVI somehow, it has to be coming from the AC line.
    I just noticed this recently as I use it as a spare 2nd monitor that I use occasionally.
    So... I'm thinking I'm gonna take it apart again and look at it, but do any of you gurus here have a suggestion as to what what would cause that to happen and what I could try to do to fix it?
  • PlainBill
    • Feb 2009
    • 7034
    Re: It's my VX922 again - AC line noise?
    The first question to ask is 'Is it something it's putting on the AC line, or is the noise being picked up by the audio input to the speakers?' Running the power cords for both the monitor and the speakers to separate filtered power strips (ideally with each power cord passing through a ferrite bead) would tend to filter out any garbage on the power lines. Or you can try keeping the audio cable to the speakers as far away from the monitor as possible.
    PlainBill
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      The transformer windings in LCD inverters will sometimes develop a loose winding causing a hum or 'singing'.
      I've heard of it getting so loud it can be heard through walls.
      Sometimes it goes away after a while, sometimes not.
      Mann-Made Global Warming.
      - Dr Seuss
      • Scenic
        o.O
        • Sep 2007
        • 2642
        also noticed this on my Belinea 101910 (which seems to be identical to some Viewsonic model .. can't remember which one. 19" 1280x1024 with MVA Panel and the FSP 035 PSU/inverter).
        sometimes i get a humming noise in my speakers (seperate ones. not the integrated 0.2W beepers), and other times there's absolutely nothing.
        haven't figured out WTH is causing this. it's humming again in the speakers right now, yesterday there was nothing.. strange
        • lucky13
          • Aug 2007
          • 412
          If you replaced with good quality, low ESR caps the first time around, then there isn't too much can go wrong with the power board.
          If you have spare CCFL lamps, you can also swap them in to troubleshhot the source. I once came across a set of lamps that are arcing inside.
          • MegaZAC
            Onkyo TX-SR805 noise in one channel
            by MegaZAC
            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
            There's some logic behind it. As soon as I select an input I get only left...
            04-23-2025, 10:09 PM
          • courtcircuit
            Philips HTS8000 home cinema noise problem
            by courtcircuit
            Hello
            I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
            Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
            Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
            I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
            Removed each of tyhe boards
            02-08-2025, 08:22 AM
          • cubytus
            Samsung UN50TU8000FXZC shows thin horizontal green line when warm
            by cubytus
            Hi to all,
            I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
            I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
            Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
            01-10-2024, 01:26 AM
          • TrueSword88
            Kogan - KALED65XU9220STB - Blue Vertical Line
            by TrueSword88
            Hi all.
            I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
            The line just happens to coincide with the end of COF and start of the next COF (attached).
            The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
            Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
            Hoping to fix...
            05-05-2023, 04:28 PM
          • tony359
            by tony359
            11-28-2023, 05:18 AM
