Eizo ColorEdge CG277 power supply burned
  • REpairAT
    • Nov 2020
    • 142
    • Austria
    Got this monitor with a burned main track and diode, unable to identify. My feeling tells that this mysterious "MP2C5052" IC caused the damage, yet I'm unable to find any useful information about.
    The power supply model is "PCB-POWER 05A26240C1"
    Does anyone have either schematics or datasheet of this probably faulty IC?
    Thanks!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Eizo ColorEdge CG277 power supply burned
    This is a special part, I think your only hope is to buy one from the component distributors in China, or ask Eizo if they sell the board?
    The only data I was able to find is the attached document from the component manufacturer Fuji Electric.
    • R_J
      • 9535
      I found these:
      • REpairAT
        • Nov 2020
        • 142
        • Austria
        Thanks for your replies!
        I have the feeling that asking EIZO for a spare board sadly might be the only, valid option.
        BR,
        Ray
        • piipo
          • May 2015
          • 6
          • Bulgaria
          Hi, I have the same board with the same issue. How did you solve the problem? What is the main voltage in addition to the 5V rail? As if can't find parts, will swap the entire board with something that I have. Thank you
          • REpairAT
            • Nov 2020
            • 142
            • Austria
            Hi, I didn't solve it at all and gave back the monitor, as it is.
            • Bubz
              • Sep 2023
              • Sweden
              Hi!
              I'm currently trying to repair a CG277 with this exact same issue.
              Was in touch with a really great guy from Eizo (in Sweden), who informed me that:
              1. D044 and L041 are likely to be faulty. They are RB070M-30 and BLM41PG600SN1 respectively.
              2. Replacement power boards were surprisingly affordable through Eizo costumer support.
              • Bored repairs
                • Oct 2023
                I also have one of these.
                Thanks to Bubz I've found that D044 is short circuit.
                I also found that it is in just about the most awkward place on the board.
                I tried Eizo customer support (UK) but they absolutely refuse to sell a replacement board, they will however take it in for 'Inspection & repair' for £95 +VAT +parts!
                • Bubz
                  • Sep 2023
                  • Sweden
                  Bored repairs: I paid about half that, for a brand new, revised version power board, including new cables (as the revised power board had different connectors).
                  I've since received it, swapped the board, and can report the screen as fully working again.
                  • vf fa
                    In over my head
                    • Jan 2024
                    • 19
                    Funny enough. I'm trying to fix my CX270 which does sometimes work and the stops working after it warms up (but only if I restart it after it has already warmed up). And D044 gives me 0,002V in both directions.
                    After the painful desoldering of D044, I've found that it has cracked on the bottom side.
                    It now measures 0,4V in one, and OC in the other direction. I'm getting 0,002V when trying to measure via the exposed copper (where it cracked) on the bottom side.
                    Good thing Mouser got those for around 40 cents and minimum order amount of 1pc. I'll order 2.
                    Thanks Bubz your info really saved me here. No way I would have been able to find out what the part number was on mine.
                    I should mention though, that mine has neither any burn marks or other obvious failures. So there's that.
                    • vf fa
                      In over my head
                      • Jan 2024
                      • 19
                      Nevermind. I am an idiot. 0.002V on diode mode is the voltage from a short. Measuring the pads (with no diode installed) gives 0.002V. Because it is connecting somewhere else via the PCB.
                      Then again, it was damaged either way, so there's that.
                      See kids, these obvious oversights and mistakes happen, when you inhale to much soldering fumes.
                      Really banking on someone like CapLeaker to take a look at my thread. I'm a bit out of ideas.
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • JimBanville
                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                        by JimBanville
                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                        09-13-2023, 07:21 AM
                      • CMCM
                        Russound CA4 Power Supply Repair
                        by CMCM
                        Hello Everybody,
                        Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                        Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                        The outputs marked 12v and 20v are all measuring only 1v.
                        The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                        The capacitors physically look clean (no bludgesor leaks) and...
                        07-03-2025, 01:12 PM
