DELL P2717H 27 inch white horizontal lines on screen
  • reaper422
    • Oct 2013
    • 13
    • bulgaria
    I have a problem with the Dell monitor whit LCD Panel MV270FHM-N20
    that starts with a normal picture but after three or four seconds of work, it starts to draw horizontal lines progressing from the bottom to the top.
    The power supply generates stable voltages.
    The power supply of the matrix is 5 volts, which is also stable.
    I don't think normal sounds can be heard from the LVDS board.
    After measurements are made on the test points on LVDS, the measurements are
    VGH 23.7v
    AVDDS 11.7v
    AVDD 11.7v
    VOFF -7.7v
    VGL 7.4v
    Vcom 4.7v
    And in my opinion a DC-DC converter with a very high operating temperature.
    Markings on it are, ER = 4C 334
    Оn the board is marked as - IC201
    Has anyone encountered anything like this, or does someone know the model of the IC?
    Thanks in advance.
  • lotas
    • Jan 2016
    • 4848
    • Russia
    Re: DELL P2717H 27 inch white horizontal lines on screen
    Er = 4c - er =xx - rt6801gqw (rt6801).
    • reaper422
      • Oct 2013
      • 13
      • bulgaria
      Thanks.
      I will order from aliexpress, and I will write if the repair has been successful.
      If it is convenient to ask, where can I find a description for this type of marking?
      • stefan222
        • Mar 2022
        • 4
        • Croatia
        I have similar Dell with the intermittent horizontal lines and the exact same IC is hot and produces weak hissing sound.
        Interested to know if the repair worked.
        • stefan222
          • Mar 2022
          • 4
          • Croatia
          Just wanted to let you know that there is a cheap and dirty repair for this problem.
          https://www.youtube.com/watch?v=O21ftJbbmr0
          I did it because I got the monitor for free and didn't wanted to put too much effort into the repair. Mine is P2317H and I removed the exact same resistors and surprisingly it works!
          Also, in comments there are people that talk about getting the lines back in a few months time. So it would be wiser to change the DC-DC chip.
          • reaper422
            • Oct 2013
            • 13
            • bulgaria
            Thank you for the information.
            The chips have arrived.
            After replacing the DC / DC converter, the foreign sound disappeared but unfortunately, the converter heats up again and after a few seconds more the lines return.
            • reaper422
              • Oct 2013
              • 13
              • bulgaria
              After a little more play I got to IC 102 after removing the resistors for VDD1 and VDD2.
              The vertical lines disappeared and the DC / DC converter stopped maintaining a high operating temperature.
              There are now several rows of horizontal lines at the bottom of the screen and some shivering on the screen that I can't capture in a photo.
              And again I come to the marking of the integrated circuit which I cannot decode.
              The marking is 2T = 3M 50J.
              • R_J
                • 9623
                Have you replaced the caps in the power supply? It may be similar to this https://www.edaboard.com/threads/mon...tripes.396774/
                • reaper422
                  • Oct 2013
                  • 13
                  • bulgaria
                  I changed them all today, but unfortunately there is no improvement.
                  • stefan222
                    • Mar 2022
                    • 4
                    • Croatia
                    Hello, maybe this could be of help (Take a look at the last post):
                    https://www.eevblog.com/forum/repair/dell-se2416h/
                    • questore
                      • Dec 2015
                      • 573
                      • csongrád
                      More likely you problem is VGH not reaching the Gates. Take a look at this video to try solving:
                      https://www.youtube.com/watch?v=4HFHpzSQfj0
                      • KontraStarK
                        • Oct 2022
                        • Украина
                        You fix this problem? I have the same
                        • offs3l
                          • Feb 2023
                          • 3
                          • spain
                          I have the same problem with my se2717h. My measurements are identical.
                          I have a hissing sound too but I am not sure it is from IC. Seeing that changing that not solved the problem with lines on screen, could it be s34 diode or a capacitor?
                          • offs3l
                            • Feb 2023
                            • 3
                            • spain
                            I have checked the diode but is ok. I get 5.7 at the gates. Is there any posibility to replace the tcon with another similar to recycle the led panel?
                            • thstuff
                              SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                              by thstuff
                              This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                              Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                              1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                              2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                              01-30-2023, 05:01 PM
                            • EazyBone
                              75r648 TCL 8K Mini LED White Horizontal Lines
                              by EazyBone
                              TV turns on, lights work sound works.
                              TV shows white/gray horizontal lines across the whole screen as shown in picture. TCON is getting 12v at fuses, VCC 12v.
                              First experience with 8k and mini LED. Does this picture tell you anything?
                              Apparently a "certified TCL tech" looked at this TV before I got it free and said it's a Tcon issue but said he couldn't be sure and wrote it off as a loss and they replaced for him.
                              Any tip or trick on where to start would be appreciated.
                              Going to research the lines. Also going to disconnect...
                              11-14-2023, 06:42 PM
                            • Guybrush
                              Dell U3419W horizontal lines and flickering
                              by Guybrush
                              After watching too many electronics repair videos (but not monitors) I came across a dell monitor with flickering horizontal lines. I haven't purchased it yet so don't have much info, but from the video and pic do you think there is a chance of repair or is just simple panel damage?
                              Seller claims; "but due to sun damage has some grey lines going through it"
                              https://i.imgur.com/VpTcZFn.mp4
                              Chris...
                              10-23-2023, 06:17 PM
                            • vulubalulu
                              Dell U2718Q, horizontal lines. second opinion welcome
                              by vulubalulu
                              I have never seen an issue such as this one. horizontal lines across the monitor in a consistent manner. I am really interested to get to the bottom of this and I'd value any input from the community.
                              There are three separate PCB parts attached to each other. They function as SMPS, backlight driver and main board.
                              I checked the all three blue PCBs: SMPS outputs 19V, PWM controller + mosfets without anomalies, main board has 3V, 5V, 10.5V and 19V present. Crystals output the right clockspeed. This is to be expected as the monitor turns on.
                              I haven't explored at the green PCB (TCON...
                              08-14-2024, 03:08 PM
                            • Themi
                              Dell XPS 13 9310 2 amber 4 white memory failure
                              by Themi
                              I have this laptop a dell XPS 13 9310
                              Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure​
                              I believe this is the spec from using micron tool to decode marking
                              Images of the ram
                              I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
                              Another...
                              11-24-2024, 09:06 AM
