Dell U2718Q, horizontal lines. second opinion welcome
  • vulubalulu
    • Jun 2023
    • 8
    • Atlantis
    I have never seen an issue such as this one. horizontal lines across the monitor in a consistent manner. I am really interested to get to the bottom of this and I'd value any input from the community.
    There are three separate PCB parts attached to each other. They function as SMPS, backlight driver and main board.
    I checked the all three blue PCBs: SMPS outputs 19V, PWM controller + mosfets without anomalies, main board has 3V, 5V, 10.5V and 19V present. Crystals output the right clockspeed. This is to be expected as the monitor turns on.
    I haven't explored at the green PCB (TCON board?) too much as there is an IC malfunctioning. Once it reaches 150, somewhere a safety mechanism is triggered and the monitor image 'restarts'. (think degaussing CRT monitors). The longer i let it run the more frequent it restarts. Putting a thermal pad on the IC stops it from restarting. There are two more transistors that get very hot, I am guessing that the SiW ic is heating up the other.
    There is no datasheet I could find but I took a couple measurements and what stood out to me are the waveforms of the 8 clk pins. 1-6 look normal and 7 and 8 are outliers. This is my first week owning an oscilloscope, I have no clue how to interpret it. I have already ordered a replacement chip in hopes that it will fix this issue. What else can I do here?
    It doesn't feel right that a bad clk signal can cause this much heat, can't find any shorts around SiW though.
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Guybrush
    Dell U3419W horizontal lines and flickering
    by Guybrush
    After watching too many electronics repair videos (but not monitors) I came across a dell monitor with flickering horizontal lines. I haven't purchased it yet so don't have much info, but from the video and pic do you think there is a chance of repair or is just simple panel damage?
    Seller claims; "but due to sun damage has some grey lines going through it"
    https://i.imgur.com/VpTcZFn.mp4
    Chris...
    10-23-2023, 06:17 PM
  • Ihandyrepair
    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
    by Ihandyrepair
    Hi guys
    I just started fixing 4k TV few months ago. so I am still learning a lot
    I got this tv from friend complaint is ghosting or horizontal lines on image.
    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
    then it started to show the ghosting white image.
    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
    it has 3 thin small boards at the bottom of the...
    12-05-2022, 04:18 PM
  • ggil44
    Sony XBR-65X750D Horizontal lines bottom of screen
    by ggil44
    Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
    05-30-2023, 07:51 PM
  • rstrube
    ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
    by rstrube
    Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
    Hi Everyone,
    I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
    Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
    11-23-2025, 01:37 PM
