First Timer looking for Help! DELL E176FPf
  • jimmy2x2x
    • May 2010
    • 7
    Hello, I have been given this Dell E176FPf 17" lcd
    It has the classic backlight switches off after a couple of seconds problem.
    I have done a visual inspection of the components to the best of my (very limited) ability, and it seemingly looks OK
    Where do I start diagnosing this?
    I dont have a strong electronics background, but would love to fix this monitor!
    Many thanks
    Your knowledge of scientific biological transmogrifications is only outmatched by your zest for kung-fu treachery
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: First Timer looking for Help! DELL E176FPf
    Su'scon are known crap caps. i'd replace them all (except the 100uF 450V primary filter cap as those rarely fail)
    according to this thread (*click*) the caps are most likely gone high-ESR without showing signs of failure, and a resoldering of the board (especially the transformers) could help.
    • jimmy2x2x
      • May 2010
      • 7
      Thanks, what is a good brand to replace the Su'scon caps with?
      • Wrog
        • Oct 2009
        • 472
        Step 1: Post images using the forum guidelines. Please resize the ones on tinypic.com so they don't mess up the thread width. Nice pics, by the way!
        Step 2: Replace all caps except for the fat one on its side (450v one). If you need help picking out replacements, make a list of each cap you want to replace, including make, series, dimensions and values and someone will translate them into a usable list to order. Don't forget to include your location in your profile, so places to buy them can be suggested as well.
        After that, troubleshooting steps take different paths and may require some basic equipment (DMM or VOM).
        • jimmy2x2x
          • May 2010
          • 7
          I cant seem to get the resize to stick in tinypc grrrr
          Could a mod please edit the OP to include the pics as attached thumbnails pls?
          Profile updated to include my locale
          01 Su'Scon 220uf 25V SG 105ºC 0538(V)
          02 Su'Scon 220uf 25V SG 105ºC 0540(V)
          03 Su'Scon 10uf 50V SG 105ºC 0538(V)
          04 Su'Scon 470uf 25V SG 105ºC 0540(V)
          05 Su'Scon 470uf 25V SG 105ºC 0540(V)
          06 Su'Scon 1000uf 25V SG 105ºC 0544(V)
          07 Su'Scon 47uf 16V SG 105ºC 0540(V)
          08 Su'Scon 680uf 16V SG 105ºC 0539(V)
          09 Su'Scon 47uf 16V SG 105ºC 0540(V)
          10 Su'Scon 47uf 16V SG 105ºC 0540(V)
          11 Su'Scon 47uf 16V SG 105ºC 0541(V)
          12 Su'Scon 47uf 16V SG 105ºC 0540(V)
          13 Su'Scon 4.7uf 16V SG 105ºC 0540(V) (might 4.7uf be a printing error?)
          14 Su'Scon 47uf 16V SG 105ºC 0541(V)
          15 Su'Scon 47uf 16V SG 105ºC 0540(V)
          Close up of Cap #13
          Map
          • jimmy2x2x
            • May 2010
            • 7
            Shopping list format, sorted by uF values
            47uf 16V SG 105ºC 0540(V) x5
            47uf 16V SG 105ºC 0541(V) x2
            470uf 25V SG 105ºC 0540(V) x2
            • Wrog
              • Oct 2009
              • 472
              Farnell UK has an excellent filtering system for choosing equivalent caps: Farnell UK. Choose the electrolytic types with a cap tolerance of 20%. ESR and lifetime can be left blank to default to all in the category. Be sure to make a note of the dimensions to ensure they will fit (especially the height; check the diameter if its in a crowded area)! One of the favorites that is recommended a lot is the Panasonic FC or FM series.
              List of good vendors and series to use as replacements: Recommended cap replacements.
              • jimmy2x2x
                • May 2010
                • 7
                Many thanks, I will get those ordered now
                • Wrog
                  • Oct 2009
                  • 472
                  I forgot to mention that sometimes you won't be able to get everything in the same vendor and series -- it's OK to mix and match! It's also OK to go up in voltage but never down (for example, substituting a 25V cap for a 16V cap, provided it will still fit).
                  • EGuevarae
                    • Nov 2008
                    • 1336
                    I was about to do some suggestions but you seem to have all under control here ...
                    Only think is I'm more familiar to Panasonic FM or FC....
                    • ASUS ROG Maximus IX Code
                    • Intel Core i5-7600K 3.8GHz
                    • Windows 10 Pro x64
                    • GeForce GT1050
                    • Radio Fox
                      • Jan 2010
                      • 281
                      Radio Spares (RS) is also a good source for low ESR capacitors in the UK.
                      As mentioned above, my first choice is Panasonic FM, followed by FC. For some reason RS don't put FM in the title for their FM capacitors, they just call them "Al Electrolytic Cap", but if you click on one of these, the "product overview" or datasheet will show it as FM. http://uk.rs-online.com/web/search/s...uctNum=5261137
                      Also RS has no minimum order value. Farnell has a minimum order of £20 before VAT and postage. I dont know what Farnell's delivery is like, but RS charge £4.95 (+VAT) & deliver next day, normally by DHL.
                      ________________________________________________
                      Invisible airwaves crackle with life
                      Bright antennae bristle with the energy
                      • jimmy2x2x
                        • May 2010
                        • 7
                        OK I have replaced all caps on the board, took my time and did a good job, everything is exactly like it was before - no change at all.
                        What should I be looking at next?
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Check T1 and T2 underside for dry/cold solder joints. If this is a Benq board OEM for Dell, many have suggested this could be an issue.
                          --- begin sig file ---
                          --- end sig file ---
                          • jimmy2x2x
                            • May 2010
                            • 7
                            I removed all the older solder from the underside of T1 and T2, resoldered - same again.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              If it isn't obvious, this is a classic example of the 'Two Seconds to Black' problem. Now we have to figure out why the inverter controller is shutting things down.
                              I have marked up one of the pictures; I would like several more to make the circuitry easier to view.
                              1. A picture that includes all the area to the left of the black line in the attached picture. Rotate the board so the picture will be in landscape orientation
                              2. A picture covering the same area, but of the back of the board.
                              3. If you can do it, pictures of the back side of the board showing only the area around each transformer - the area outlined in orange.
                              Also, there is probably a 16 pin IC on the back of the board in the inverter area. What is the part number?
                              PlainBill
                              • EGuevarae
                                • Nov 2008
                                • 1336
                                Completely unrelated, but do you know that my avatar (Naked Snake/Big Boss), is based on your avatar (Snake Pliskin, from Escape from NY)?
                                • GeForce GT1050
                                • Solder Boy
                                  • Nov 2006
                                  • 178
                                  Took me awhile but I googled those TDK parts.. those are special transformers for the lamps.. looking at your photo each pair of lamp wires is attached to each one, so those may be at fault.
                                  Usually you'll see a pair of 2SC707 ( or similar) transistors in line with the lamps, but not on this monitor.
                                  http://pdf1.alldatasheet.com/datashe...CTSPW-054.html
                                  Hope this helps!
                                  www.bcrelectronics.ca
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • modd1uk
                                    Dell 5420 - First timer, messed it up, need help please.
                                    by modd1uk
                                    Hi guys
                                    Its my own fault, I'm just hoping somebody can help and the laptop isn't bricked.
                                    The BIOS chip is a 25rh256cxiq, I read it using neoprogrammer 2.2.0.10 but like a complete idiot didn't search the chip, it was set to the wrong chip, I read the BIOS, unlocked it, flashed the unlocked file and now the laptop is dead, won't even try to power on, only after I'd flashed it I realised the wrong chip was selected.
                                    How stuffed am I? Is there a way to flash a generic Dell Latitude 5420 BIOS so I'm not stuck with a dead paper weight?
                                    I have another...
                                    03-22-2025, 03:24 PM
                                  • master3112
                                    by master3112
                                    07-29-2025, 01:55 PM
                                  • F R 2568
                                    Dell Latitude 5420 does not start (no post) need help to find the reason why
                                    by F R 2568
                                    Hello all,
                                    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                    If the laptop is only connected to the AC adapter (battery removed):
                                    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                    The power/battery...
                                    01-08-2025, 05:45 AM
                                  • diamon
                                    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                    by diamon
                                    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                    Pictures of these boards:
                                    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                    Dell...
                                    02-28-2024, 12:51 PM
