Gateway FPD1976w / LE1936 Problem
  • bigtex2712
    • 15
    #41
    Re: Gateway FPD1976w / LE1936 Problem
    So you figure if I just replace that one the problem will be solved?
    • retiredcaps
      • Apr 2010
      • 9271
      #42
      The logic board requires 5V DC. It then uses the voltage regulators to convert that to other voltages (like 1.8, 2.5, 3.3V DC) to feed the other components. So if 3.3V is required and the components are only getting 1.42V, then quite a bit of the circuitry is not going to come on and work at all.
      These voltage regulators are called jelly bean parts because they are found everyone and made by a lot of people. If you have junk boards, you may be able to reuse an old one as a test (assuming the used one is good).
      --- begin sig file ---
      --- end sig file ---
      • bigtex2712
        • 15
        #43
        Actually, I just came across something. I went to go retest the AS1117L-33 prong 2 and initial when I plugged power into it, the reading was a 3.2V but after about 2 minutes it dropped down to 1.4V again. I would have to assume that this definitely means the component is bad.
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          Voltage regulators are spec'd to +/- 1%. So
          3.3 x 1.01 = 3.333
          3.3 x 0.99 = 3.267
          This is why it is so important to have an accurate multimeter with fresh batteries (as previous posts).
          So if 3.2 means 3.20V, that is still out spec.
          • bigtex2712
            • 15
            #45
            Well yes I understand that, but the thing is the voltage drops after about 2 minutes from that normal output down to 1.42V.
            • cadillacman
              • Feb 2011
              • 524
              #46
              I just got one of these. Plugged in, blue power lamp just flashes. press power, still just flashes, with an input still jut flashes the lght.
              THese have some " su'scon" caps (haha) and i have two obiously bad ones. c509 is a 220uf/35v that is bulged, and c818 is a 1000uf/10v that is bulged. I believe i will recap this and post the results.
              • killian6pk
                • Apr 2010
                • 502
                I found one of these monitors in the recycle box plugged it in and nothing. No LED or picture. I opened it up and found two bulged caps. Replaced all caps & put the boards back on the display and hooked up both power and VGA.
                Gateway splash screen shows up followed by a bar with red green and blue sections. Then the monitor goes blank. The blue LED lights up and stays solid until the screen blanks at which time the LED turns orange. The on/off button will turn the monitor off and on and I get a repeat of the description above.
                Before putting the power board back together with the video board and screen I checked the two fuses which were good and the voltage on the large cap (173v) and the bridge rectifier also (173vac) I tried checking voltage at the connector between the PB and Video board. I could not get a reading on the two 5v pin or on/off pin or the other pin (brightness) (6 total) last one is ground all read in the mv range and those readings were bouncing around.
                Any ideas on what I should look for next?
                Have you ever stopped to think and then forget to start thinking again?
                As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
                • killian6pk
                  • Apr 2010
                  • 502
                  I took the LCD screen off and plugged in the power board and video board to AC. The connector between the two boards now reads:
                  VCC5v = 5.13v
                  VCC5v = 5.13v
                  Grnd
                  Brightness = 3.29v
                  On/Off = 3.23v when on
                  Grnd.
                  On video board Voltage Regulators
                  U103
                  AS1117L-33
                  Leg 1 = 0.0v
                  Leg 2 = 3.3v
                  Leg 3 = 5.13v
                  U104
                  AS1117L-18
                  Leg 1 = 0.0v
                  Leg 2 = 1.80v
                  Leg 3 = 5.13v
                  U103/104 appear to be ok, is that right?
                  Any ideas as to what to look for next?
                    OK, the inverter backlights circuit since it is getting the correct voltages for BL_ON and the Dimming from the logic board so the backlights should stay on.
                    The inverter transformer has 2 pins on the output side, what resistance do get at those 2 pins (use 2K Ohm scale)?
                    • killian6pk
                      • Apr 2010
                      • 502
                      T501
                      Pin 7&8
                      0.605
                      T502
                      Pin 7&8
                      0.607
                      My DMM is Auto Ranging
                        OK, they are fine, so need to look at the drive circuits next.
                        What DC voltage do you have at the two legs of C817?
                        • killian6pk
                          • Apr 2010
                          • 502
                          The reading was 14.79 vdc.
                            OK, you are getting B+ to the inverter section, next we need to look further in the inverter section, I will need to trace out the connections on the bottom side of the board.
                            BTW, can you read the P/N on those two 8-PIN MOSFET's, we will need to check the Source and Drain resistance.
                            • killian6pk
                              • Apr 2010
                              • 502
                              Ok I will get them to you tomorrow.
                              • killian6pk
                                • Apr 2010
                                • 502
                                This is the link to the datasheet on the Mosfets: http://pdf1.alldatasheet.com/datashe.../AP9971GD.html
                                Which pins do you want me to check for resistance?
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4464
                                  • Italy - Milan
                                  #56
                                  Budm you are trying to troubleshoot a 2 sec. to black problem but he said "Gateway splash screen shows up followed by a bar with red green and blue sections", i don't think this behavior is normal, Killian: can you watch in a dark room with a torch pointed at the screen and mon. switched on and hooked to a running pc if you see a dark picture? Use black and white pic or high contrast.
                                  • killian6pk
                                    • Apr 2010
                                    • 502
                                    Currently I have it apart testing components for Bud. I will put it all back together and check to see if I have anything on the display screen.
                                    • killian6pk
                                      • Apr 2010
                                      • 502
                                      Bud,
                                      I took a resistance reading On U501 S1-D1 = 1.80 Kohms
                                      On U502 same pins = 7.95 Kohms
                                      Do want any other pins checked?
                                        "Gateway splash screen shows up followed by a bar with red green and blue sections. Then the monitor goes blank" The word BLANK means black screen with no backligts or backlights on but no image on the screen, it sounds to me the backlights go out.
                                        "The blue LED lights up and stays solid until the screen blanks at which time the LED turns orange" This one sounds like the monitor goes into standby made due to lack of signals from running PC. Please clarify.
                                        The MOSFET's readings, since they are dual MOSFET's what are the readings of S2-D2?
                                        • killian6pk
                                          • Apr 2010
                                          • 502
                                          U501 Pin S2 - D2 = 7.92 Kohms
                                          U502 Pin S2 - D2 = 7.89 Kohms
                                          Bud,
                                          What I said in Post #47 is what is happening. I have not checked yet for video without backlights, because I have had the boards seperated to check for what you wanted.
                                          EDIT: Bud I realize now that what you are saying is that I have described two seperate problems. As I said above I did not check for a picture without backlights, but I will put the boards and screen back together and check to see if I have a picture.
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
                                          • Gibon378
                                            Problem with stopping audio and video for no reason
                                            by Gibon378
                                            PC Specs:
                                            • CPU: Ryzen 5 1600
                                            • GPU: GTX 1080 Palit JetStream
                                            • MOBO: ASRock ab350 PRO4
                                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                            • PSU: XFX 650W (don't remember what model)
                                            • OS SSD: ADATA SP920
                                            • OS: Windows 10 21H2
                                            Problem description:
                                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                            11-19-2022, 09:41 AM
                                          • perzyk23
                                            Lenovo T580 - LCD Panel problem - error 0288
                                            by perzyk23
                                            Good morning,
                                            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                            10-25-2024, 12:42 AM
                                          • lazaro.089
                                            Asus Zephyrus M16 / GU603ZW problem
                                            by lazaro.089
                                            Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                                            CPU: Core i9-12900H
                                            Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                                            Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                                            The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                                            08-26-2025, 06:33 PM
