ACER AL2017.....not working...Led comes on....with-flashlight can see image
+ More Options
Posts
  • Welchs101
    • Sep 2008
    • 979
    I have an ACER AL2017 a friend brought over for me to look at. I am hoping to fix this monitor so that i can fix another monitor that i have been working on for a long time. This monitor has a power supply board very similar to the westinghouse power supply board shown in this thread
    https://www.badcaps.net/forum/showth...3&page=1&pp=20
    In this thread above caps, power-fets and fuse were replaced. I did the same.
    When i power on the monitor the lamps DO NOT COME ON.
    The green LED light does come on.
    Also, using a flashlight directed towards the screen, i can see the image.
    Its just that the lamps wont turn on.
    Note: I have checked the LAMPS using another monitor and they work fine.
    Sounds like an inverter problem but i am not sure how to isolat the problem.
    Any ideas on what to measure to figure this one out?
  • PlainBill
    • Feb 2009
    • 7034
    Re: ACER AL2017.....not working...Led comes on....with-flashlight can see image
    If memory serves, this board is notorious for shorted inverter transistors and a blown fuse. The fuse is a smt style on the back of the board - look for the M in the inverter area. Also, replace all electrolytic caps with the usual exception.
    PlainBill
    • Welchs101
      • Sep 2008
      • 979
      Yep, i already replaced the inverter , fuse and a few caps.
      • seanc
        • Nov 2008
        • 1319
        I think that board looks pretty similar to a board I have in my Viewsonic VX2235M (or similar model)
        • Welchs101
          • Sep 2008
          • 979
          ok. I looked up the model you suggested not much in the way of repair or troubleshooting info. But thanks.
          • seanc
            • Nov 2008
            • 1319
            Oops, it's VX2235WM, here's a good thread for pictures: https://www.badcaps.net/forum/showth...light=vx2235wm
            • Welchs101
              • Sep 2008
              • 979
              the original power mosfets that were in this board had shorts between two of the legs. The part number for the original power fets were "40T03GP". I read on the bad caps forum that an equivalent part to use for this was the following:
              http://search.digikey.com/scripts/Dk...863-NTP45N06LG
              The badcaps thread which mentioned this part equivalency is shown here:
              https://www.badcaps.net/forum/showthread.php?p=81893
              For this monitor i was asked to measure the resistance between the leads of the power fet:
              PowerFet1:
              Resistance between Pin1(Red probe) and Pin2(black probe):open....resistance too high to measure
              Resistance between Pin1(black probe) and Pin2(red probe):1.488MegaOhm
              Resistance between Pin1 (red probe) and Pin3 (black probe):open....resistance too high to measure
              Resistance between Pin1 (black probe) and Pin3 (red probe):starts out at 3.4MegaOhms and keeps increasing
              Resistance between Pin2 (red probe) and Pin3 (black probe):4.43 Meg ohms
              Resistance between Pin2 (balck probe) and Pin3 (red probe):2.7Megaohms and increases
              PowerFet2:
              Resistance between Pin1(Red probe) and Pin2(black probe):starts at 3.7Megohm and increases
              Resistance between Pin1(black probe) and Pin2(red probe):3.33MegaOhm
              Resistance between Pin1 (red probe) and Pin3 (black probe):3.64megohms
              Resistance between Pin1 (black probe) and Pin3 (red probe):3.1megohms
              Resistance between Pin2 (red probe) and Pin3 (black probe):3.96megohms
              Resistance between Pin2 (balck probe) and Pin3 (red probe):2.75Megaohms and increases
              Resistance between Pin1 of fet1 and pin1 of fet2: 5.8megohms
              • frankNstein
                • 35
                This looks like a DAC-19M005 board if it is check F200 and see if it is open again.
                • Welchs101
                  • Sep 2008
                  • 979
                  I already replaced the fuse 200. I replaced several caps and the power fets.
                  Current status of monitor:
                  Power LED light comes on. I can see the image on the screen with the help of a flashlight. I have also checked the ccfls........they appear to be good.
                  • frankNstein
                    • 35
                    The fuse is probably open again. I have one of these boards with the same problem.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Things to check:
                      1. The fuse. If it is open, don't replace it yet. Instead use a #1157 bulb (automotive tail light).
                      2. The state of the BL_ON line. It should be close to 0 volts.
                      3. Is power getting to the inverter controller?
                      PlainBill
                      • Welchs101
                        • Sep 2008
                        • 979
                        I checked the fuse........IT IS OPEN!
                        I bought a bulb but i dont know if it has the same voltage and current rating. The one i have is a Sylvania #921 (12.8V, 17.9W). Would this work? If not i will buy the one you mentioned in your thread.
                        You said the state of the BL_one line should be 0V......where do i measure this?
                        Is power getting to inverter controller...........Is the inverter controller the BIT3713 device?
                        • PlainBill
                          • Feb 2009
                          • 7034
                          That bulb will work, perhaps better than the one I suggested. Now the idea is to use that to replace the fuse (temporarily) while you figure out what is causing the fuse to blow.
                          PlainBill
                          • Welchs101
                            • Sep 2008
                            • 979
                            Any suggestions on how to figure out what is causing it to blow while the light is on? I mean what do i look for? Do i touch comonents to see which one is getting hot or do i try and measure voltages?
                            • PlainBill
                              • Feb 2009
                              • 7034
                              I'd do the 'touch tests' first - CAREFULLY!!!
                              PlainBill
                              • frankNstein
                                • 35
                                Check Q202 and see if it is open.
                                • Welchs101
                                  • Sep 2008
                                  • 979
                                  will do. Right now i am fighting a really big fire........my A/C is not working. Soon as i get it fixed.......i will get back on this monitor.
                                  Thanks for all the suggestions!
                                  • smason
                                    • 1652
                                    A/C??? WTF? It's April! We're months away from A/C season.
                                    • Welchs101
                                      • Sep 2008
                                      • 979
                                      A/C working......at least for now. Guess what........the cause was a bad "start" capacitor.
                                      Anyway, back to monitors.
                                      I checked Q202........but to be honest i am not sure what this device is and what it should measure. I am enclosing a pic of this device (Q202) ........it has markings on it of "14".
                                      I am hoping to try the "light bulb" test later today.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Use the standard tests for a transistor. Label the leads - lower left '1', top center '2', lower right '3'. Measure resistance 1-2, 1-3, 2-3; all should read > 100 ohms.
                                        Switch to the diode test range and do these tests. Black lead goes to the first terminal, red lead to the second. You should get a reading of about .5 volts on only two of the six tests. The others should read open.
                                        1 2
                                        1 3
                                        2 3
                                        2 1
                                        3 1
                                        3 2
                                        PlainBill
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • maralexbar
                                          How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                                          by maralexbar
                                          I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                                          It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                                          If anyone knows how to force the external monitor as primary for Notebooks of those models
                                          11-02-2024, 09:18 AM
                                        • 3D Modelka
                                          AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
                                          by 3D Modelka
                                          Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
                                          02-09-2024, 02:42 AM
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
