ACER AL2017.....not working...Led comes on....with-flashlight can see image
  • Welchs101
    • Sep 2008
    • 979
    I have an ACER AL2017 a friend brought over for me to look at. I am hoping to fix this monitor so that i can fix another monitor that i have been working on for a long time. This monitor has a power supply board very similar to the westinghouse power supply board shown in this thread
    https://www.badcaps.net/forum/showth...3&page=1&pp=20
    In this thread above caps, power-fets and fuse were replaced. I did the same.
    When i power on the monitor the lamps DO NOT COME ON.
    The green LED light does come on.
    Also, using a flashlight directed towards the screen, i can see the image.
    Its just that the lamps wont turn on.
    Note: I have checked the LAMPS using another monitor and they work fine.
    Sounds like an inverter problem but i am not sure how to isolat the problem.
    Any ideas on what to measure to figure this one out?
  • PlainBill
    • Feb 2009
    • 7034
    Re: ACER AL2017.....not working...Led comes on....with-flashlight can see image
    If memory serves, this board is notorious for shorted inverter transistors and a blown fuse. The fuse is a smt style on the back of the board - look for the M in the inverter area. Also, replace all electrolytic caps with the usual exception.
    PlainBill
    • Welchs101
      • Sep 2008
      • 979
      Yep, i already replaced the inverter , fuse and a few caps.
      • seanc
        • Nov 2008
        • 1319
        I think that board looks pretty similar to a board I have in my Viewsonic VX2235M (or similar model)
        • Welchs101
          • Sep 2008
          • 979
          ok. I looked up the model you suggested not much in the way of repair or troubleshooting info. But thanks.
          • seanc
            • Nov 2008
            • 1319
            Oops, it's VX2235WM, here's a good thread for pictures: https://www.badcaps.net/forum/showth...light=vx2235wm
            • Welchs101
              • Sep 2008
              • 979
              the original power mosfets that were in this board had shorts between two of the legs. The part number for the original power fets were "40T03GP". I read on the bad caps forum that an equivalent part to use for this was the following:
              http://search.digikey.com/scripts/Dk...863-NTP45N06LG
              The badcaps thread which mentioned this part equivalency is shown here:
              https://www.badcaps.net/forum/showthread.php?p=81893
              For this monitor i was asked to measure the resistance between the leads of the power fet:
              PowerFet1:
              Resistance between Pin1(Red probe) and Pin2(black probe):open....resistance too high to measure
              Resistance between Pin1(black probe) and Pin2(red probe):1.488MegaOhm
              Resistance between Pin1 (red probe) and Pin3 (black probe):open....resistance too high to measure
              Resistance between Pin1 (black probe) and Pin3 (red probe):starts out at 3.4MegaOhms and keeps increasing
              Resistance between Pin2 (red probe) and Pin3 (black probe):4.43 Meg ohms
              Resistance between Pin2 (balck probe) and Pin3 (red probe):2.7Megaohms and increases
              PowerFet2:
              Resistance between Pin1(Red probe) and Pin2(black probe):starts at 3.7Megohm and increases
              Resistance between Pin1(black probe) and Pin2(red probe):3.33MegaOhm
              Resistance between Pin1 (red probe) and Pin3 (black probe):3.64megohms
              Resistance between Pin1 (black probe) and Pin3 (red probe):3.1megohms
              Resistance between Pin2 (red probe) and Pin3 (black probe):3.96megohms
              Resistance between Pin2 (balck probe) and Pin3 (red probe):2.75Megaohms and increases
              Resistance between Pin1 of fet1 and pin1 of fet2: 5.8megohms
              • frankNstein
                • 35
                This looks like a DAC-19M005 board if it is check F200 and see if it is open again.
                • Welchs101
                  • Sep 2008
                  • 979
                  I already replaced the fuse 200. I replaced several caps and the power fets.
                  Current status of monitor:
                  Power LED light comes on. I can see the image on the screen with the help of a flashlight. I have also checked the ccfls........they appear to be good.
                  • frankNstein
                    • 35
                    The fuse is probably open again. I have one of these boards with the same problem.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Things to check:
                      1. The fuse. If it is open, don't replace it yet. Instead use a #1157 bulb (automotive tail light).
                      2. The state of the BL_ON line. It should be close to 0 volts.
                      3. Is power getting to the inverter controller?
                      PlainBill
                      • Welchs101
                        • Sep 2008
                        • 979
                        I checked the fuse........IT IS OPEN!
                        I bought a bulb but i dont know if it has the same voltage and current rating. The one i have is a Sylvania #921 (12.8V, 17.9W). Would this work? If not i will buy the one you mentioned in your thread.
                        You said the state of the BL_one line should be 0V......where do i measure this?
                        Is power getting to inverter controller...........Is the inverter controller the BIT3713 device?
                        • PlainBill
                          • Feb 2009
                          • 7034
                          That bulb will work, perhaps better than the one I suggested. Now the idea is to use that to replace the fuse (temporarily) while you figure out what is causing the fuse to blow.
                          PlainBill
                          • Welchs101
                            • Sep 2008
                            • 979
                            Any suggestions on how to figure out what is causing it to blow while the light is on? I mean what do i look for? Do i touch comonents to see which one is getting hot or do i try and measure voltages?
                            • PlainBill
                              • Feb 2009
                              • 7034
                              I'd do the 'touch tests' first - CAREFULLY!!!
                              PlainBill
                              • frankNstein
                                • 35
                                Check Q202 and see if it is open.
                                • Welchs101
                                  • Sep 2008
                                  • 979
                                  will do. Right now i am fighting a really big fire........my A/C is not working. Soon as i get it fixed.......i will get back on this monitor.
                                  Thanks for all the suggestions!
                                  • smason
                                    • 1652
                                    A/C??? WTF? It's April! We're months away from A/C season.
                                    • Welchs101
                                      • Sep 2008
                                      • 979
                                      A/C working......at least for now. Guess what........the cause was a bad "start" capacitor.
                                      Anyway, back to monitors.
                                      I checked Q202........but to be honest i am not sure what this device is and what it should measure. I am enclosing a pic of this device (Q202) ........it has markings on it of "14".
                                      I am hoping to try the "light bulb" test later today.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Use the standard tests for a transistor. Label the leads - lower left '1', top center '2', lower right '3'. Measure resistance 1-2, 1-3, 2-3; all should read > 100 ohms.
                                        Switch to the diode test range and do these tests. Black lead goes to the first terminal, red lead to the second. You should get a reading of about .5 volts on only two of the six tests. The others should read open.
                                        1 2
                                        1 3
                                        2 3
                                        2 1
                                        3 1
                                        3 2
                                        PlainBill
