Dell E178fp repair
  • mathog
    • Mar 2010
    • 2655
    Dell E178fp repair
    Dell E178fp intercepted on the way to e-waste, manufactured in 2007.
    Initially at power on the DELL warm up screen would appear dimly for a second or two and then it would blank. At best, other times it would just start black. Disassembled and found the power supply and video board shown front and back in the attachments. The PS board had 4 Capxon electrolytic capacitors of which the biggest two (c203 and c204 on the right side) were domed and one of the smaller ones (c16, near F151 at the left) had blown its plug. Replaced them with Panasonics. Reassembled, and it powered up and lit.
    However, the image has problems (see the attachment). The video board has 2 X Teapo 330uF 16V, 8 X G-Luxon 22uF 25V and 1 X Teapo 100uF 25V. Is the image defect shown consistent with some or all of these being bad? They all look ok, but as I understand it, none of these are very good capacitors. Measured the voltage at pin 1 on the power supply and it was 5.1, which is the value stamped on the motherboard. So I think the PS board is OK now and this problem is either in the video board, or I suppose it could be in the panel itself. The horizontal lines follow the color rectangle around the screen and appear in all positions. The Moire pattern is from the camera image, it isn't visible by eye.
  • Wizard
    • Mar 2008
    • 2296
    Re: Dell E178fp repair
    You're not done and what kind of panasonic capacitors was used? FC, etc?
    Need to replace the rest of capacitors ( group of violet caps) and check the rest on the mainboard.
    Be easy with these white ribbon cables, they are delicate.
    Cheers, Wizard
    • mathog
      • Mar 2010
      • 2655
      Originally posted by Wizard
      You're not done
      Clearly
      FM.
      I don't have this board with me, but if memory serves I didn't replace those because they still looked good and were from an OK manufacturer. By "mainboard" are you referring to the video board? None of the caps there are visibly deformed, but neither Teapo nor G-Luxon has a stellar reputation. I don't have an ESR or any other kind of capacitance meter. All I can check is if the caps are shorted.
      Seemed to me the display glitches remaining were probably from problems on the video board, since the horizontal lines correspond to video signal changes, and that's all on the video board.
      Will try to be careful with the white ribbon cable.
      Thanks.
      • Wizard
        • Mar 2008
        • 2296
        The way it looked shows me there is noise that is not cleaned up or poor voltage.
        This is ideal to go all the way to recap the power supply if don't have ESR meter, just swap out these four on that power supply.
        I'll just wait.
        Cheers, Wizard
        • mathog
          • Mar 2010
          • 2655
          Better than OK. The are all Nichicon: two HD and two PW.
          • mathog
            • Mar 2010
            • 2655
            Progress report.
            Replaced all the caps on the video board. Reassembled, powered on, nothing. Inspected and noticed the connector between the PS and video board was off one row (that is, 4 on one side were hanging out into the air, and the other 4 were plugged into the holes where the first ones were supposed to be. My bad, hopefully that didn't blow anything up permanently. Reassembled correctly this time. Power on (with no video input). Nothing, not even a back light. After a while though the Dell warm up screen came up for a while. It was still a little noisy, but just a bit on the left edge of the box that wanders around the screen this time, not lines all the way across like before. However it didn't stay on, but turned off after a while. Maybe that's normal - I've never had this monitor in working condition.
            I could easily have damaged the video board replacing those caps as it was very, very hard to get the solder out of the through holes once the caps were out. Couldn't do it with a solder sucker, a Radio Shack desoldering iron, or solder wick. Eventually resorted to heating up a resistor lead, pushing it through the hole, wiping the solder off the far side with the iron, and repeat until the hole cleared. TEDIOUS. Overheating of nearby components is a distinct possibility. As are solder bridges, although I didn't see any. (My eyesight is crappy these days though, and the video card is pretty densely packed, so the odds of me seeing a small solder bridge are not great.)
            Guess I'll try plugging in a video source that's umm, expendable, just in case it handles real video input OK (I really don't care if the warm up screen looks right if the normal display correct.) Also replacing the last few caps on the PS.
            • llphat
              • 20
              Apologies for digging out such an old thread, I have recently come across an E178FP which does not power up. Opening up and checking the PCB, there were no obvious bad caps or burnt areas. There was no voltage across pin 1 which should be be 5.1V when on.
              The only obvious thing is when I measure across ZD2 which gives 0.001V (in circuit) which surely does not sound right - is this the culprit?
              Oh if ZD2 does turn out to be blown, is there a way to find out the values from the marking on the component?
              • Rtech
                • Jul 2010
                • 1095
                What is the other letters in the model code after the FP /c/,v/,b etc ??
                • llphat
                  • 20
                  The model is E178FPv the boards are similar to the images posted in the first post.
                  Fuses checked OK and there is a ~330V voltage across the big cap at the bridge exit.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    What is the DC voltage across C4? That is the startup cap for the SMPS. It should be steady and not fluctuating.
                    --- begin sig file ---
                    --- end sig file ---
                    • tmcw
                      • Oct 2010
                      • 382
                      • Ireland
                      Re: Dell E178fpV repair
                      Another E178FPv here, exact same boards, observations and symptoms (no 2 seconds, or any sign of life) as yourself, though ZD2 measures "OL" both ways on mine.
                      My first thoughts were with the startup cap C4, so I replaced that with a Panasonic FM 47uF/50V, but there are no changes from that.
                      C160 looked coupled to pin 1, so I changed that as well (it was giving some bizarre behaviour when probed, so it looked suspect, will check the ESR later). Anyway, on pins 1-8, I'm now getting the following...
                      1, 2: 5.19v
                      3, 4: GND
                      5: NC
                      6: 5.11v
                      7: 3.5v
                      8: 0v
                      ... but still no visible signs of life, not even from the LED on the button panel.
                      Did you pursue it any further?
                      I know the other Capxons will need to be replaced, but should I be seeing other signs of life before they need replacement?
                      Should pin 8 be registering a voltage change if the on/off button is switched on and off? How best to test this?
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Are you measuring ZD2 with the diode test function or resistance function on your multimeter? I always use diode test.
                        No power LED suggests something is wrong on the main/logic board. A good place to start is with the voltage regulators.
                        • tmcw
                          • Oct 2010
                          • 382
                          • Ireland
                          Yes, I went back and retested the ZD2, and got 0.01 both ways on diode test. I had to scratch one of the pads to get a reading, must be a bit of oxidation there.
                          Found another thread on this monitor since (https://www.badcaps.net/forum/showthread.php?p=152680) and went back and tested the button panel, but it seems to be functioning correctly. Buttons (cheap clicky things, like mobile phone contacts) all register out to the logic board, and I even got to see the orange and yellow LEDs to light up when testing them for continuity to ground. Is that bad for them?
                          I might be able to get a similar working monitor to transplant and test, at least rule out the logic board, but might help troubleshooting the power board.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Remove ZD2 and test out of circuit to verify it is shorted. In circuit measurements can cause false readings sometimes.
                            • tmcw
                              • Oct 2010
                              • 382
                              • Ireland
                              Yep, did that, I guess it's fine, "OL" one way, 0.737 the other way.
                              • selldoor
                                Slow Learner
                                • 7870
                                ok - so do you want to put off further tests until you know if you are getting the similar working monitor?
                                • tmcw
                                  • Oct 2010
                                  • 382
                                  • Ireland
                                  It might be a while (couple of weeks) before I can get the same model monitor, so if you have any suggestions, feel free to suggest them.
                                  I additionally changed the rest of the electrolytic capacitors (except the large line filter), and tested the rest of the zeners and the bridge rectifier (out of circuit), and they're all ok. But the set still shows no sign of life.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    I repeat, voltage regulators as per post #12.
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • Hakuu
                                      by Hakuu
                                      Hi There,
                                      More Details
                                      TV Model - LG OLED77G1PUA
                                      07-12-2023, 02:37 PM
                                    • Garret Matt.
                                      DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                                      by Garret Matt.
                                      I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                                      Thank you in advance for any assistance you can render.
                                      Inductor In question. Buzzes like...
                                      06-20-2025, 01:21 PM
                                    • PacoGT
                                      Gpu DELL OEM RTX3080 No video
                                      by PacoGT
                                      Hello friends, I have a question. They brought me this video card, a DELL RTX 3080. They told me that it fell and the impact no longer produced video.
                                      When trying it, it's as if it wanted to give video but in the end nothing, I already checked voltages etc. everything is as it should, but without video
                                      I suppose it could be a bios problem but since sometimes they don't tell you everything, I've searched for the bios everywhere but without success
                                      I can't find a backup or something to try to reprogram bios and see if it's the fault, could you help me maybe someone has one that...
                                      02-18-2025, 01:08 AM
                                    • howardc64
                                      by howardc64
                                      07-24-2025, 05:17 PM
