Dell E171FP No power
  • Welchs101
    • Sep 2008
    • 979
    Re: Dell E171FP No power
    Bill,
    Thanks again. I learned somethings so thanks.
    I did have one question i wanted to ask. Why did you have me put the resistor across the 2200uF cap instead of the other row of caps? Just curious.
    thanks again.
    • Welchs101
      • Sep 2008
      • 979
      One other question
      From this link pin1 is "SD=shutdown" and pin2=vin. Should they be shorted? Because they are.
      • PlainBill
        • Feb 2009
        • 7034
        Originally posted by Welchs101
        Bill,
        thanks again.
        This goes back to SMPS design. The output voltage of the supply is fed back to the controller. If the output voltage is too low, the width of the drive pulses are increased to pass more energy from the primary side to the secondary. If the output is too high, the pulse width is reduced. If you have a single output, design is easy - regulate the single output. If you have multiple outputs it gets more difficult. The design can either regulate one output and let the others wander, or use multiple controllers, transformers, etc. In most applications one voltage is critical, usually the 5 volt supply. That's the one I had you load.
        PlainBill
        • PlainBill
          • Feb 2009
          • 7034
          One other question
          Yes. Notice the line over SD. That indicates an active low signal. In other words, pulling pin 1 to ground will turn off the regulator. By tying it to Vin, it's always on.
          PlainBill
          • Welchs101
            • Sep 2008
            • 979
            thanks! learned something new again!
            • syclonejim
              • Jan 2006
              • 4
              #46
              I don't know if you ever got your E171FP power board to work, but I have fixed twenty to thirty of these power supplies. The problem is always the 50 volt caps I have circled in red.
              • silverbulit
                • Sep 2010
                #47
                Hey guys (and gals),
                I just wanted to let you know that I replaced the capacitors that syclonejim was referring to and my monitor is working perfectly after being completely dead. Thanks for your help!
                Silver
                • billy66
                  • Mar 2010
                  • 124
                  #48
                  I have a Samsung 151s monitor with this exact same boards. The Mosfet in bottom right corner was bad (see syclonejim's pic). I haven't replaced yet, as the Mosfet is no longer available (MTP2955V). I will also replace the caps as suggested. I just wanted to add the Samsung monitor to this tread so others when searching for that monitor will come across this.
                  Thanks.
                  • trickymint
                    • Sep 2010
                    #49
                    Hi, had a similar problem with an E171FP bought on eBay. On first power up there was a pop from the back of the monitor and a subsequent electrical burning odour. It was going to cost me postage to return to seller with no guarantee of a replacement or money back so decided on repair.
                    Opened it up and discovered bulging C5 (100uF, 400V, CapXon) and blown 3.15A fuses on power/inverter board. In addition found bulging 220uF, 25V, Teapo on CFL driver board.
                    Replaced C5 with 47uF, 450V (closest match available from local store) and 220uF caps. Couldn't get PCB fuses readily so replaced with 5A fuse wire links (naughty I know).
                    Monitor now working.
                    • billy66
                      • Mar 2010
                      • 124
                      #50
                      I replaced all the caps on the power board and the mosfet Q1... monitor is now alive.
                      • printone2
                        • Jun 2007
                        • 102
                        #51
                        I have included pics as well because i am notorius for looking at a partnumber and getting it wrong.
                        From what i can tell with magnifying glass:
                        Part1)
                        26AT
                        LBBB
                        Parts2)3)4)
                        BA033
                        2B 29
                        Part5)
                        7805C
                        NLEC239
                        If this does not answer your question or you need more info just let me know.
                        I too thought I had a power supply problem, but the real problem was on the image board. I compared a working power supply output and found the two 12 volt rails were showing 15.9 volts. When I swapped the image boards the panel would not light up. The problem was a bad cap on the image board at C163 a 47uf 6.3v 6mmx6mm. It was reading 2.48v on the good image board, but only 1.52v on the bad one. When I pulled the cap it registered 38uf, so I replaced it and now my panel lights up.
                        • skisabeth
                          • 3
                          My Monitor too had 15v on 12 v rail and replacing C163 fixed it eventhough the cap checked good on tester (53uf)
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • Steph.hen
                            Bridge rectifier identification part number KPB305G
                            by Steph.hen
                            Hi all, a newby question about a bridge rectifier I'm trying to identify.
                            I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                            08-29-2024, 09:52 AM
                          • mpn78
                            Fujitsu Q556, What capacitor for bridge rectifier?
                            by mpn78
                            Hello
                            My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                            There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                            Thanks....
                            04-05-2022, 12:31 PM
                          • master3112
                            by master3112
                            07-29-2025, 01:55 PM
                          • F R 2568
                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                            by F R 2568
                            Hello all,
                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                            If the laptop is only connected to the AC adapter (battery removed):
                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                            The power/battery...
                            01-08-2025, 05:45 AM
