Dell E196FPf
+ More Options
Posts
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell E196FPf
    Originally posted by garbermf
    PlainBill,
    Do you want me to post any pictures back side of the board?
    Yes, I do, thanks for offering. I'm going to have to do a little circuit tracing to locate test points.
    The detail visible in the one you posted is excellent. The only problem was it covered only part of the board. I would like two pictures, one of the top and one of the bottom of the board, both covering the full size of the board.
    PlainBill
    • garbermf
      • Mar 2010
      • 12
      Re: Dell E196FPf
      Here are the pictures that you requested. Please let me know if you need more details.
      • PlainBill
        • Feb 2009
        • 7034
        Re: Dell E196FPf
        They are adequate. Unfortunately, I've just discovered that working with double sided boards is a whole new ball game!
        I've circled what should be the three main filter caps. It appears this design has only a single output on the main supply. Check the voltage across the caps; they should all read the same.
        PlainBill
        • garbermf
          • Mar 2010
          • 12
          Re: Dell E196FPf
          All three caps measured the same: 25.9 ACV
          • PlainBill
            • Feb 2009
            • 7034
            Re: Dell E196FPf
            Try it on the DC range.
            PlainBill
            • garbermf
              • Mar 2010
              • 12
              #26
              Re: Dell E196FPf
              I got 12.15 DCV on all three.
              garbermf
              • PlainBill
                • Feb 2009
                • 7034
                Re: Dell E196FPf
                garbermf
                Good!!! That seems to show the power supply is working. While it is possible there are bad caps, let's move on to another area.
                I've marked up the picture of the top. I've circled three devices - probably voltage regulators - and labeled them A, B, and C. I've also marked one pin on each in red, and labeled a ground point. With the monitor plugged in, measure the DC voltage from each of the pins AND the tab on each device to the point I've marked Gnd.
                In addition, I've marked 4 additional devices D, E, F, and G. A couple of these may be transistors; if they are the location designator would start with a Q. (Q201, Q723, etc). Ignore any that start with a Q. For the three voltage regulators and the additional devices 'tagged' with a letter (with the exception noted above), what is the part number on the package?
                PlainBill
                • garbermf
                  • Mar 2010
                  • 12
                  #28
                  Re: Dell E196FPf
                  Would you please post the marked up picture?
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Re: Dell E196FPf
                    PlainBill
                    • garbermf
                      • Mar 2010
                      • 12
                      #30
                      Re: Dell E196FPf
                      Here are the readings A = 12.15 , b= 0, c= 0 I had a hard time reading your letter markings on your picture so going down on the left column here are the labels:
                      a: U851 - 1506 0549BL
                      b: d857 - UTC LD1117AL 33AJASJ03
                      c: U802 - MM1117 188526
                      e: C409 - PM25LV010 EN190K 0547HAN
                      f: U301 - CSI 24FC02W1 0539E
                      Right column going down:
                      d: Q501 - A12E 1C
                      g: Q502 - W1A 59
                      • Ingenuity
                        • Aug 2010
                        #31
                        Re: Dell E196FPf
                        Are these the caps you replaced? It sounds like I have the same problem but don't have an electronics test bench - just need to do a quick fix. I've circled the ones I think you switched with success. If these are, I'll order them from my local shop.
                        If they aren't the right ones, can you circle the two you replaced?
                        • gobbler
                          • Jun 2009
                          • 55
                          #32
                          Re: Dell E196FPf
                          Hi
                          I have the same model Dell E196fpf which has no power.
                          I have identified the yellow transformer to be faulty using flyback tester.
                          Anyone knows where I can buy this part? Thanks.
                          • Rtech
                            • Jul 2010
                            • 1095
                            #33
                            Re: Dell E196FPf
                            I've seen a lot of the FPf series,as well as many other Monitors and as yet have never come across one of these transformers that have failed !!,perhaps this is the first one !.The normal fault on these is the regular failure of the SMPS chip,A voltage Regulator failure,and of course caps,although that is unlikely to be your problem.If is is the transformer,then unless you can find a Board with another fault, then I doubt very much whether you can source one.Where are you located ??
                            • gobbler
                              • Jun 2009
                              • 55
                              #34
                              Re: Dell E196FPf
                              I am located in Singapore.
                              Using the flyback tester, these are the readings I have got. PRI side pins 1-2 bad with two red bar; pins 3-4 green ok; SEC side pins 5-6 & 7-8 shorted no light. I am pretty sure the readings are accurate.
                              Tomorrow I can get hold of a unit of E176Fpf, I think they are using the same board. Let me swap the transformer and test. Will report back.
                              • Rtech
                                • Jul 2010
                                • 1095
                                #35
                                Re: Dell E196FPf
                                I asked for the location, as I have a number of E173's etc,and may have been able to help if you were UK Based... Good luck when you replace it.
                                • gobbler
                                  • Jun 2009
                                  • 55
                                  #36
                                  Re: Dell E196FPf
                                  darn... E176Fpf circuit board is different model from E196Fpf, the transformer is also different too. I am at dead end...
                                  • Rtech
                                    • Jul 2010
                                    • 1095
                                    #37
                                    Re: Dell E196FPf
                                    E153FPf and the E173FPf,seem to be the same cosmetically,but there are slight differences in the Circuitry between them and the E196FPf..HOWEVER the latter is the same as the E177FPf,if you see one of them.
                                    • bongsenit
                                      • Aug 2014
                                      • Malaysia
                                      #38
                                      Re: Dell E196FPf
                                      Need to what is the real value R856, R861, and R887
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        Re: Dell E196FPf
                                        Are yours totally burnt up ? or missing? - Sometimes they look pretty burnt but you can clean with iPA or the rings remain on the side nearest the board.
                                        What do they test at
                                        • Rtech
                                          • Jul 2010
                                          • 1095
                                          #40
                                          Re: Dell E196FPf
                                          R856 is 15Ω R861 is 470Ω...cannot find the other resistor, check the number...also I am away on holiday today,so hopefully someone will help with other values if necessary.
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • DanPoka
                                            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                            by DanPoka
                                            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                            02-15-2025, 05:05 AM
                                          • Jesus Coder
                                            Issues Reviving Old Dell 2408WFPb Monitor
                                            by Jesus Coder
                                            I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                                            06-25-2023, 02:33 PM
                                          • ChristianBr01
                                            Dell 34 inch U3419W Monitor with thin stripes on partial screen
                                            by ChristianBr01
                                            I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                                            This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                                            This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                                            Does someone have seen this before?...
                                            05-23-2025, 06:06 AM
