Dell 2005FPW works for hours, but on hot re-boot fails...
  • tasin
    • Apr 2013
    • 5
    • the Netherlands
    #41
    Re: Dell 2005FPW works for hours, but on hot re-boot fails...
    with necked eyes, I have no esr meter, they looks healthy no leaks or color disorders, or blowing .
    • technotech
      • Apr 2013
      • 11
      • usa
      #42
      Mine looked healthy, but were bad. You might want to just replace them anyways -- it shouldn't cost much
      • tasin
        • Apr 2013
        • 5
        • the Netherlands
        #43
        I think it is the best solution in this case.
        Thank you very much for replay.
        • CQTip
          • Apr 2013
          There are two caps circled in blue. One of them provides stable power for the SMPS controller at startup, the other while it is operating. NOW, this is somewhat of a long shot, but if either of them is bad, the power supply won't come up.
          There are two approaches. One is to replace these caps and see if that fixes the problem.
          The other is to check if the power supply comes up. If you look at the bottom of the board you will see that the pins for the connector to the logic board has the function of each pin labeled. With the monitor in 'won't restart' condition, check the voltages from the 12V and 5V pins to Gnd. If these are the same in both working and won't work states, the problem is on the logic card, which is a much more difficult matter.
          PlainBill
          I picked up the Dell 2005FPW monitor at a computer show for $45. It worked for about a day or so. I found it blinking all of its front panel indicators. None of the front panel buttons, even the power button, would work. Would have to unplug to restore operations which would only last a few minutes and then the same symptoms would appear.
          Online search quickly lead me to the following posting and videos on fixing known issues with this monitor due to the bad capacitors:
          Dell 2005FPW works for hours, but on hot re-boot fails... - Badcaps Forums
          https://www.badcaps.net/forum/showthread.php?t=8998
          Repair a Flickering 20" Dell 2005FPW LCD Monitor (similar to 2007WFP) - YouTube
          http://www.youtube.com/watch?v=Oh-7-6Yb0Oc
          WLDock's media
          http://media.photobucket.com/user/WL...g.html?filters[term]=2005fpw&filters[primary]=images&filters[secondary]=videos&sort=1&o=0
          I only replaced the following caps on the power board to confirm that they were the problem; and YES indeed, it fixed it:
          C103 - 47uf 25V
          C107 - 1uf 50V
          THANKS for this site and all that shared.
          CQTip
          • matt526
            • Nov 2013
            I am going to replace the c635 and c637 470uf 16v
            but all I have laying around is a 470uf 35v. you think this would be fine for now?
            I have seen people put a 470uf 25v just fine.
              That will be fine for testing but, is it low ESR type or general purpose type.
              • spice_disc
                Vizio TV M50-C1 reboot cycle and static on screen
                by spice_disc
                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                09-08-2024, 02:37 PM
              • Track4207
                Hisense H50N5300UK reboots when showing full red images
                by Track4207
                Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
                What happens:
                • TV appears to operate normally, for an indefinite amount of time until a problem image appears
                • The problem image is displayed very briefly, then the
                08-30-2023, 11:58 AM
              • gumball
                BenQ GW2450HM - Panel is partially dimmed, works for 2 hours after replacing few caps
                by gumball
                Issue: Panel is partially dark or dimmed, left side is okay (see photos attached).
                Trial: Replaced three visibly bad capacitors on the power supply board (see photos).
                First result: Monitor worked for two hours only. Two capacitors bulged again.
                Diagnosis: After replacing those capacitors the monitor was connected via HDMI cable to a laptop. Laptop was connected to power supply and charging. Power cable was removed from the laptop end and put back. Maybe this was a coincidence but since unplugging the power cable it was noted that the panel had darkened...
                10-10-2022, 01:54 PM
              • CapLeaker
                Dell ATX PSU won’t start, but forcing it works fine?
                by CapLeaker
                Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                10-28-2024, 06:59 PM
              • Sergejs A
                Asus FA617NS bootloops
                by Sergejs A
                Picked up FA617NS laptop from bin 😀
                Have situation were it fails to boot windows/linux for random set of times and then boots and works like nothing happened.
                You can shutdown it and then if it powers on via fast start it works, but if you reboot it boot loops is here again.
                Changed thermal paste with pads, changed ssd, changed memory
                Battery are in bad shape, but disconnecting connection it changes nothing.
                Noticed that when it lags, it does not react to power button correctly and sometimes lags in bios.
                Decided to reflash bios, to...
                04-23-2025, 09:20 AM
