Dell 2005FPW works for hours, but on hot re-boot fails...
  • kingofcoins
    SaveOnGreen-Cap
    • Jan 2010
    • 162
    I thought I had fixed this Dell 20005FPW LCD monitor, which originally had the common diode blink and no display. The 1st time in I replaced several s^m young caps on power side though absolutely nothing on board looked bad or overheated. A day or 2 later I did a hot reboot and lcd failed to come on...it just gives a subdued back light pulsing flash every second or so. Next time in I also followed this thread...
    https://www.badcaps.net/forum/showth...ghlight=2005fpw
    ...and did about all mentioned including replacing cap c637, and C635 on the video side. Symptom remains that unit will work fine for say 3, 4, 5 hours or longer, but if you shut down and try a reboot before unit cools for some hours, it will just sit there with a white flash blink and the power on/off button does not function at that time. If I wait and boot the next day, viola it works for hours until you shut down again. It blinks when power is applied not video cable, so I'm sure its PS related.
    What do you think is next to do?
  • sceva
    • 196
    Re: Dell 2005FPW works for hours, but on hot re-boot fails...
    I am having a similar problem with a Dell E176FPf. I replaced some caps, resoldered several connections, but nothing seems to have helped. This monitor will come one, work well for 15 minutes to a couple of hours, then the display will flash on/off about once a second. It shows "Dell" on the screen when it is in the on cycle, not the computer image that was being displayed before the cycle began. The power led also flashes on/off with the display, and the power button has no effect. It will continue to flash until I remove the power cord. Once I reconnected the power cord a few minutes later and this time it just gave a very brief flash, no power led or anything else...
    Here are the pics of the board:
    • PlainBill
      • Feb 2009
      • 7034
      (Sigh) It doesn't cost anything to open a new thread. For future reference, don't hijack a thread for a different model monitor with a different problem.
      Second, troubleshooting by remote control is very much garbage in, garbage out. It would be of a moderate help to indicate which caps were replaced and what the replacements were.
      Now for the good stuff. The symptoms suggest the video processor (the Genesis chip at the right side of the board) is being reset. This MAY be due to power supply fluctuations.
      I've marked three voltage regulators (I think) with the numbers 1, 2, and 3. What are the part numbers of these three regulators? If you can locate the datasheets for them, you can anticipate my next question by telling me what the output voltages are when the monitor is working, and when it fails.
      PlainBill
      • kingofcoins
        SaveOnGreen-Cap
        • Jan 2010
        • 162
        So Bill, what of my 2005FPW...yep, I am typing with it...I replaced all the s^m young caps on power supply from 470uf to 1000uf (C201 thru C205),and both C635 and C637 on the video side which were 470uf x 16V. I use panasonic or nichicons low esr's of the same uf or one up, and meet the voltage and often one level up. No I don't have schematic.
        Here is the other thread I followed here...try this link:
        https://www.badcaps.net/forum/showth...hlight=2005fpw
        What do you need to know next on this one that works until you shut down?
        • PlainBill
          • Feb 2009
          • 7034
          I'm glad to see you used good quality caps as replacements. That's one less possibility.
          As far as help for you, well, I'm old and cranky. I will do a lot to help someone get his monitor up and working. But I won't jump to another thread to look at pictures of a monitor that had a different problem.
          So, pictures, and indicate the capacitors you replaced. A prime suspect in power supply issues are the small caps around the SMPS controller. To my sorrow, I learned the hard way that they can fail without any visible sign.
          PlainBill
          • sceva
            • 196
            Sorry about the hijack. Do you want me to create a new thread and move the post there?
            Thanks for the reply, I will check into it and get back.
            • PlainBill
              • Feb 2009
              • 7034
              It's up to you, but I already misinterpreted kingofcoins' response as coming from you. (Almost made an idiot of myself lashing out at him for a non-response.)
              When I am faced with a non-working monitor I do a search by model number.Trying to separate responses to two different monitors with two different problems seriously limits the usefulness of the thread.
              PlainBill
              • sceva
                • 196
                I moved the info to a new post, but can't figure out how to delete my posts in this thread... I will try your suggestions in a couple of days and get back...
                • kingofcoins
                  SaveOnGreen-Cap
                  • Jan 2010
                  • 162
                  Bill...OK, here's the power supply board pics for my 2005FPW. It took over 3 hours up today and two cold boots to get unit to fail on a hot restart. The red area shows the caps I replaced.
                  Which are the caps near the SMPS controller you mentioned.?
                  • kingofcoins
                    SaveOnGreen-Cap
                    • Jan 2010
                    • 162
                    Better full pics...
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Better full pics...
                      There are two caps circled in blue. One of them provides stable power for the SMPS controller at startup, the other while it is operating. NOW, this is somewhat of a long shot, but if either of them is bad, the power supply won't come up.
                      There are two approaches. One is to replace these caps and see if that fixes the problem.
                      The other is to check if the power supply comes up. If you look at the bottom of the board you will see that the pins for the connector to the logic board has the function of each pin labeled. With the monitor in 'won't restart' condition, check the voltages from the 12V and 5V pins to Gnd. If these are the same in both working and won't work states, the problem is on the logic card, which is a much more difficult matter.
                      PlainBill
                      • kingofcoins
                        SaveOnGreen-Cap
                        • Jan 2010
                        • 162
                        Thanks for sticking with me Bill...the caps you circled are 47uf x 25v 's. The smallest new caps I have on hand are 200uf's. As a quick test replacement trial, I have some computer PSUs and some older Mobos I can salvage from...what would be an acceptable range of values to use...considering I will try for a 'good' brand ? Of course this is temporary, and I maybe buying more parts as well.
                        In your pic you circled a cap chip in yellow...any significance ?
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Since you don't have appropriate caps on hand, perhaps checking if the power supply is at fault (the second option I mentioned above) might be easier. I would guess that something in the 22uF - 100 uF would work. Checking the app note for the SMPS controller might give more information.
                          That yellow circle was a mistake (yes, not only do I make them, I admit it. Strange, huh?). I had suspected there might be a cap under the glue. When I looked at the bottom of the board I realized it was a ceramic cap. The exercise for the student is to determine how I was able to discern that from the bottom of the board.
                          PlainBill
                          • Toasty
                            • Jul 2007
                            • 4171
                            Seems to be a case of not replacing every cap the first time around. Except for the really big one, you most likely should have replaced -all- the others with vent marks. You didn't mention if you tested them for failure or weakness, so it was purely a guess, I suppose?
                            If you leave it run without power-off or system reboot, does it stay on?
                            veritas odium parit
                            • kingofcoins
                              SaveOnGreen-Cap
                              • Jan 2010
                              • 162
                              Bill... I'll try to check if the power supply is at fault.
                              Quiz answer...You knew the cap type because ceramic caps have a plain (flat chip) symbol thus,... -l l- while electrolytics have a curve (in a can) symbol as -) l-....also because I have a good camera and you have good intuitive skills !
                              Toasty... Thanks for joining in...the reasons why I didn't replace all the caps first was I didn't have any smalls, and the initial 'fix' worked. I will try a 100uf small temp fix on C103 and C107 next and report as well.
                              And on your question: "If you leave it run without power-off or system reboot, does it stay on?"....Yes it runs as long as my test uses have been, about 6-7 hours I'd guess, and no it has never failed yet unless I power off or re-boot.
                              • kingofcoins
                                SaveOnGreen-Cap
                                • Jan 2010
                                • 162
                                I salvaged some small caps from a computer PSU to try as temps...yes,yes you folks have got me interested enough in these repairs that I will need to buy an ESR meter.
                                In the meantime does anyone want to hazard a guess which 2 caps I could try to replace my questionable 1uf x 50v and a 47uf x 25v, the C107 and C103 caps?
                                My candidates...all are on the bad list, apparently mfg about 2003...
                                Jun Fu HK 1uf x 50v
                                G-Luxon SM 2.2uf x 50v
                                Canicon TC 10uf x 50v
                                Capxon KM 22uf x 50v
                                YEC 85*C 47uf x 25v
                                Canicon TC 47uf x 50v
                                • kingofcoins
                                  SaveOnGreen-Cap
                                  • Jan 2010
                                  • 162
                                  UPDATE.....
                                  I chose to use the G-Luxon SM 2.2uf and the Canicon TC 47uf as a trial replacement for those two small caps near the power controller...and viola... it works...so far on a long time yeterday and again today with no hot boot or re-boot failures ! Sucess...>
                                  On this 2005FPW is there any other checks/replacements you think I should make?
                                  So now I'll need to order fresh caps from Digi-key...what sizes would you recommend for my original 1uf x 50v and 47uf x 25 v ? I usually don't stock too many below 220uf for LCD repair works...what sizes do you usually keep below 220 uf ?
                                  Thanks all !
                                  Dan
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    UPDATE.....
                                    Thanks all !
                                    Dan
                                    My practice is to order at least 10 of any cap of 100uF or smaller I require, then keep the surplus on hand. They are inexpensive, but can cause unusual problems if they fail.
                                    PlainBill
                                    • 995sunglasses
                                      • Mar 2011
                                      • 17
                                      I had this same problem with my dell 2005fpw,
                                      I went to radio shack (RS) to buy the capacitors and they gave me the Axial lead ones instead of the radial lead ones which I know doesn't matter but on the 47uF 35v the RS item number they gave me was 272-1015 now I know most of you don't recommend buying from RS but I had to try and fix this thing quick. I noticed on the 47uF/50v one they gave me, the front of that package said 50WVDC maximum and on the capacitor itself gives a temp rating of -40 to 85' C. Is this correct? because on the package of the 1uF 50v capacitor (item number 272-0996) the package says 50v on the back and not 50WVDC like the other one did.
                                      On the 47uF/35v did I buy the right one according to the fix that KINGOFCOINS did?
                                      or my question is, is there a difference between "v" and "wvdc", this is my first time repairing my monitor.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        If you live in the USA (which I assume because of the Radio Shack), digikey.com has low cost $2.75 shipping and you get your parts in about 48 hours.
                                        RadioShack does not sell low ESR caps. The fact that you got 85C caps demonstrates this.
                                        Fixing it quick and fixing it correctly are worlds apart.
                                        --- begin sig file ---
                                        --- end sig file ---
                                        • yaya3gmax
                                          Laptop Power Issue – Works on Battery, Fails on Adapter Load
                                          by yaya3gmax
                                          Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                                          Symptoms:
                                          • Laptop works normally on a pre-charged battery.
                                          • Battery does not charge when adapter is connected.
                                          • Without battery:
                                            • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                                            • Speakers “pop” when power cut occurs indicating harsh sutdown.
                                            • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                                          08-21-2025, 07:16 AM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • Track4207
                                          Hisense H50N5300UK reboots when showing full red images
                                          by Track4207
                                          Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
                                          What happens:
                                          • TV appears to operate normally, for an indefinite amount of time until a problem image appears
                                          • The problem image is displayed very briefly, then the
                                          08-30-2023, 11:58 AM
                                        • nothinghyper
                                          Blackscreen after couple of hours playing (PC)
                                          by nothinghyper
                                          Hi Everyone,
                                          After couple of hours playing a game i get blackscreen , i can still hear the sounds and i can move the character but the image doesnt come back until i reset the computer. I have tried running Furmark 1080p settings fullscreen for 7 hours and didnt encounter the same problem. It used to give me an error as driver not responding so i have installed only the driver itself and not the radeon software since than that message doesnt come up anymorre but i still have the same issue. Sometimes it happens after 30 mins gaming time , sometimes after 3 hours , sometimes even after...
                                          08-27-2025, 07:23 AM
                                        • gumball
                                          BenQ GW2450HM - Panel is partially dimmed, works for 2 hours after replacing few caps
                                          by gumball
                                          Issue: Panel is partially dark or dimmed, left side is okay (see photos attached).
                                          Trial: Replaced three visibly bad capacitors on the power supply board (see photos).
                                          First result: Monitor worked for two hours only. Two capacitors bulged again.
                                          Diagnosis: After replacing those capacitors the monitor was connected via HDMI cable to a laptop. Laptop was connected to power supply and charging. Power cable was removed from the laptop end and put back. Maybe this was a coincidence but since unplugging the power cable it was noted that the panel had darkened...
                                          10-10-2022, 01:54 PM
