Dell 1704FPT
  • bananaman
    Re: Dell 1704FPT
    Gentlemen:
    I was asked to fix a dell 1704FTP monitor. When powered up the green light comes on and is steady. There is not any video, not even for a few seconds (2 second to death issue is not applicable) I disassembled and the power supply board looks fine. Caps are not expanded and R125 looks fine. The only thing I noted was a funny bubble on the side of a blue trimmer (VR801 I think), but not sure that is a problem.
    I think may be a video problem. There was a screw missing that tells me it was opened before. Anyone have similar problem? (solid green power light with no video at all)
    bananaman
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      #42
      Re: Dell 1704FPT
      Hi - When you say no video have you checked with a flashlight on the screen at an angle - assumes you have a source connected.
      Welcome to the forum-
      We can often help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...7&d=1280167246
      https://www.badcaps.net/forum/attach...6&d=1280167246
      https://www.badcaps.net/forum/attach...4&d=1280167246
      • fc227a
        • Jan 2015
        • 12
        Re: Dell 1704FPT
        I know this is an old thread, but I have a question. IS there a schematic for this board?
        God Speed , Fred
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #44
          Re: Dell 1704FPT
          Dell did not do many schematics for monitors (at least showing the power board)
          Problem is usually bad solder. bad inverter transformer - test see here
          https://www.badcaps.net/forum/showpo...04&postcount=8
          IF your board is the same.
          Bad bulbs - perhaps you can test those in your recently fixed monitor.
          Bad inverter mosfets - usually 5707s (or similar) on the back of the board.
          We also have a useful guide on 2 seconds to black by retiredcaps
          https://www.badcaps.net/forum/showthread.php?t=10419
          Start at post19.
          • flinx
            • Aug 2010
            • 132
            Re: Dell 1704FPT
            reviving an old post.
            I have a couple of these monitors. one of them had the 2 seconds on then off. I connected the CCFL on each side to one or the other connectors on the power supply and noted that one side of the high voltage output was not working.
            All caps appeared ok, I did some checking and troubleshooting but could not nail down the problem. I did note a slight difference on the High voltage transformer (from the side that was not working) as compared to the ohms readings of the HV PS on another board. I replaced the HV transformer and the problem went away.
            Even though none of the capxon caps showed signs of bulging or leaking I replaced all the electrolytic caps on the board (except the large one). I replaced them after I noted the display was working properly.
            Capxon capacitors are junk.
            "...off the record, unnamed government sources
            alluded to unsubstantiated innuendos about
            alleged indiscretions and insinuated that they
            are rumored not to be without basis for further
            speculation..."
            • Loupe
              • Nov 2016
              • France
              #46
              Re: Dell 1704FPT
              Hi, I read all above posts concerning this thread, but didn't find answer to my problem.
              I had some trouble to switch on my Dell 1704 FPTt monitor. The greenlight from the front panel remained faded.
              Changing all caps on the low voltage side of the power board helped solved the problem for a while until a recent grid power failure.
              I measured the voltage at several points on the board and noticed that the + 5 V leads from the power board to power on the video control board were not stabilized (the value oscillated from 0 to 3 or 5 Volts with the DMM.
              So I tried to find out the start of this failure.
              I noticed this oscillating values on the leads of a component located at the limit between HV/LV separation, but I'm not sure that's the source of the problem.
              This IC component is a 4 pin tagged I802 on the board and labeled Lo 503 817D x ; but I don't know what kind of component it is.
              [It looks like a Transistor Output Optocoupler, Through Hole, 4-Pin DIP]
              It is located on top middle of the picture :
              https://www.badcaps.net/forum/attach...8&d=1265184429
              (the first picture of this thread)
              Your help would be much appreciated.
                Re: Dell 1704FPT
                So you did not replace the small lytics start-up/running cap in the primary side?
                The rectifiers in the secondary side are all OK?
                • Loupe
                  • Nov 2016
                  • France
                  #48
                  Re: Dell 1704FPT
                  I replaced the 11 caps surrounded in the attached pic.
                  "So you did not replace the small lytics start-up/running cap in the primary side?"
                  Which one do you mean on the picture ?
                  "The rectifiers in the secondary side are all OK?"
                  Where are they located on the board ? And how to test them ?
                  Thanks for your help.
                  • Loupe
                    • Nov 2016
                    • France
                    #49
                    Re: Dell 1704FPT
                    Hi budm,
                    Sorry to be so novice in electronics.
                    I improved a little bit my knowledge about the SMPS.
                    I understand the basic difference between linear PS and Switch mode PS.
                    I better figure out the components function on the primary side than in the secondary side on the board.
                    I guess you wanted to enlighten me to the possibility of a short-circuit in one of the rectifiers in the secondary (1 SB1060FCT & 2 ER1002FCT) side that could create an excessive load signal to the feed back pin (via an activation of the opto-coupler and a precision Zener Diode circuit ) of the PWM controller (SG6841).
                    So that the oscillating voltage value on the 5V and 12V outputs could be the result of a cyclical shut down and turn on of the oscillating signal to the power transistor (FQPF8N60C) from the PWM controller.
                    So my first question how could I test the 3 rectifiers on the secondary side ?
                    By small lytics start-up/running cap on the primary side do you mean those encircled on the new posted pics ?
                    I hope you'll have some time to consider my message.
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • DanPoka
                      by DanPoka
                      02-15-2025, 05:05 AM
                      by momaka
                      03-15-2023, 10:17 PM
                    • Jesus Coder
                      Issues Reviving Old Dell 2408WFPb Monitor
                      by Jesus Coder
                      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                      06-25-2023, 02:33 PM
                    • ChristianBr01
                      Dell 34 inch U3419W Monitor with thin stripes on partial screen
                      by ChristianBr01
                      I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                      This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                      This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                      Does someone have seen this before?...
                      05-23-2025, 06:06 AM
