Dell 1704FPT
  • Rtech
    • Jul 2010
    • 1095
    Re: Dell 1704FPT
    Suggest you try a local Maplins if possible.....trying to buy by post will not be economically viable.
    • ralphup
      • Aug 2011
      • 38
      Re: Dell 1704FPT
      thanks been search the NET all day, maplins dont do a 2MOhm so think its going to have to be 2 x 1 MOhm - unless you ca think of another option Rtech.
      • ralphup
        • Aug 2011
        • 38
        Re: Dell 1704FPT
        PS youre only up the road from me!
        • Rtech
          • Jul 2010
          • 1095
          Re: Dell 1704FPT
          As you are in Leeds, then go to Farnells !! Obviously no postage as it would be an over the Counter purchase, and I don't think there is a minimum order when you collect.
          • ralphup
            • Aug 2011
            • 38
            Re: Dell 1704FPT
            Hi mate,
            got 2 x 1MOhm and fittedm but no joy still dies after a few secs.
            This is with a NEW screen asthe old one had a broken CCL. I know its the PTB-1511 board as I have a couple of these and substituted for a good one. Any ideas what else could have died?
            Thanks for all help!
            • Rtech
              • Jul 2010
              • 1095
              #26
              Re: Dell 1704FPT
              I think some pictures of top and bottom may be helpful.Use the 'managed attachments' to put them on.
              • Rtech
                • Jul 2010
                • 1095
                #27
                Re: Dell 1704FPT
                Have just checked the faulty board I have,and that has the same symptoms as your has,BUT the fault is an open secondary on the Inverter Transformer T101,and am still waiting to find one,they should read approx 450 ohms.Also my R125 and the similar one on the other transformer is 2.2Mohms.
                • ralphup
                  • Aug 2011
                  • 38
                  Re: Dell 1704FPT
                  Thinking of buying a replacement PCB from EBAY:
                  Item number: 140512299224
                  If and when I do you can gladly have my faulty board for parts...
                  • Rtech
                    • Jul 2010
                    • 1095
                    #29
                    Re: Dell 1704FPT
                    Many thanks
                    • ralphup
                      • Aug 2011
                      • 38
                      Re: Dell 1704FPT
                      Many thanks
                      Hello there, I have sent you a PM and await your response sir!
                      • pcarbery
                        • Sep 2012
                        • 5
                        • Ireland
                        #31
                        Re: Dell 1704FPT
                        Hi there all,
                        I know this is an old discussion, but it is the best I have found; and hope some of you might be able to help.
                        I am wondering if anyone has resolved this issue. I too have one of these Dell monitors that displays a screen for less than a second before going blank. I too have noticed a burnt R125 resistor (but still seems intact). I was thinking of replacing the inverter board but am reluctant to, if it is just going to fail again.
                        I suspect from reading other forums that one of the lights may be gone and that the board automatically shuts down all others once it senses this....perhaps this is why the R125 resistor is overheating.
                        Any help? ideas?
                        • Rtech
                          • Jul 2010
                          • 1095
                          #32
                          Re: Dell 1704FPT
                          It may be the transformer that has failed ?? have you checked the Resistance of the secondaries ??
                          • pcarbery
                            • Sep 2012
                            • 5
                            • Ireland
                            #33
                            Re: Dell 1704FPT
                            hi Rtech, sorry for the late reply but couldnt get back to this project until now. Resistances of the secondaries are fine. A = 459 , B=434. all cap's look ok, no signs of any problems......will check them with DMM when I get a different one that can check farads. (I think I have one in work somewhere).
                            By the way, I can see the screen when I shine a flashlight on to it.
                            • Rtech
                              • Jul 2010
                              • 1095
                              #34
                              Re: Dell 1704FPT
                              If you can see the image,,then definitely a Backlight issue.
                              • pcarbery
                                • Sep 2012
                                • 5
                                • Ireland
                                #35
                                Re: Dell 1704FPT
                                Thanks Rtech, does you reply mean that it is one of the lights or could it still be the inverter board?
                                  Re: Dell 1704FPT
                                  Try test lamp?
                                  https://www.badcaps.net/forum/showthread.php?t=19987
                                  • Rtech
                                    • Jul 2010
                                    • 1095
                                    #37
                                    Re: Dell 1704FPT
                                    Could still be either !! you really need a test Backlight to identify where it is.
                                    • pcarbery
                                      • Sep 2012
                                      • 5
                                      • Ireland
                                      #38
                                      Re: Dell 1704FPT
                                      thanks guys for the replies.....will test lamp and reply back in a few days
                                        Re: Dell 1704FPT
                                        You can get one of these for testing your lamps:
                                        http://www.ebay.com/itm/1pc-4-Lamp-B...ht_3916wt_1400
                                        http://www.ebay.com/itm/LCD-Monitor-...ht_1794wt_1400
                                        • pcarbery
                                          • Sep 2012
                                          • 5
                                          • Ireland
                                          #40
                                          Re: Dell 1704FPT
                                          Things happen slowly in my country....anyway, I finally fixed the monitor and am looking at it right now. In the end, I purchased a new inverter board on ebay for 20 bucks. I couldn't locate any bad caps (but are sure there were some) I took a chance that the lights were ok and went ahead with the purchase. I will post again if there is any problem with it. So far so good, but it has only been switched on for 1 hour.
                                          Thanks for all the help everyone.
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • DanPoka
                                            by DanPoka
                                            02-15-2025, 05:05 AM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • Jesus Coder
                                            Issues Reviving Old Dell 2408WFPb Monitor
                                            by Jesus Coder
                                            I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                                            06-25-2023, 02:33 PM
                                          • ChristianBr01
                                            Dell 34 inch U3419W Monitor with thin stripes on partial screen
                                            by ChristianBr01
                                            I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                                            This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                                            This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                                            Does someone have seen this before?...
                                            05-23-2025, 06:06 AM
