Need help DCLCD 19" LCD Monitor - I already replaced caps
  • DJM_PHX
    • Dec 2010
    • 47
    #121
    Re: Need help DCLCD 19" LCD Monitor - I already replaced caps
    Yes. Screws in and tight.
    • jetadm123
      • 2169
      #122
      There's a mosfet mounted on the heatsink directly below the large cap. I suggest you check it for shorts.
      • DJM_PHX
        • Dec 2010
        • 47
        #123
        Originally posted by retiredcaps
        I and probably others will have suggestions. The next post will probably be a long one and I don't have time right now to write it all out.
        Have you had any time to put a check list together of what I should do next?
        • retiredcaps
          • Apr 2010
          • 9271
          #124
          Check for shorts on the power mosfet as jetadm123 suggested in post #123.
          I have the same smps chip in my monitor. Once I replaced the small cap, I got secondary voltages. See
          https://www.badcaps.net/forum/showthread.php?t=9904
          for details. If the power mosfet is okay, then the SMPS controller may be bad. Replacements are available on ebay.
          --- begin sig file ---
          --- end sig file ---
          • nirvnyc
            • Jan 2011
            #125
            hi, can anyone tell me what the original uF and voltages are on those four caps c114 115 117 and 118 on the LM004 Ver:3 board... thanks
            i had replaced the caps a long time ago with caps of higher uF and voltage ratings... and now those went bad after a few years... and i have no idea what the original specs were..
            • DJM_PHX
              • Dec 2010
              • 47
              #126
              Check with and ohm meter out of the board, or in the board? Hot or not?
              In the board I see resistance but not shorted. I should be able to check voltage on each post by making a probe tip to reach in there.
              Also, I can not get to the SMPS control chip while powered up to check it as in the other thread.
              • DJM_PHX
                • Dec 2010
                • 47
                #127
                114 and 115 are 25V - 470uF
                117 and 118 are 10V -1200uF
                Is the yellow square transformer looking unit the SMPS?
                • jetadm123
                  • 2169
                  #128
                  I meant to check for shorts with power off.
                  • nirvnyc
                    • Jan 2011
                    #129
                    Thank you!
                    • jetadm123
                      • 2169
                      #130
                      The fluctuating voltage of 10-15V across the 22uf cap indicates that the power supply is trying to start up. Refer to the datasheet application circuit, page 14 regarding the following:
                      With power off and monitor unplugged,
                      1) The circuit shows a 56Kohm 1W resistor (your value will be different) connected to the output of the large cap. Find and measure the value of this resistor.
                      2) In the circuit, you have a 1N3613 diode (your values will be different) feeding the 10uf cap. Locate this diode and check it for shorts.
                      3) Measure resistance across pins 5 (gnd) and pin 7 (vcc) of the SG3842.
                      4) You've already checked the mosfet and replaced the small cap.
                      5) If the above checks good, I have some reservations about the voltage fluctuation on the 450V large cap, you might consider replacing it.
                      6) If the above checks good, I'm leaning towards replacing the SG3842 chip. It also goes under the part # UC3842 and is dirt cheap, so buy a couple of them.
                      • DJM_PHX
                        • Dec 2010
                        • 47
                        #131
                        Please excuse my ignorance about circuits, but when you refer to "in the circuit", are you talking about in the pdf (which figure) or another diagram? I attached pics of the top and bottom of my boards. It would help if you indicate which is which. I don't see a resistor connected to the large cap, at least what I would recognize a one.
                        If the diode is on the bottom of the board, D103, I have 99 ohms each way. If on the top of the board I have a D101 and D102. D101 I get nothing in both directions accross it, D102 I get a short beep with no reading but I can flip the leads and get the same result, a short beep. I am not sure what I am seeing.
                        • jetadm123
                          • 2169
                          #132
                          The applications circuit on page 14 of the pdf file was what I was referring to on my previous post. Since we don't have a manufacturer's schematic to work from, I chose to use the one for the SG3842. Please keep in mind that the SG3842 schematic is a "suggested" design. In reality, your circuit board will differ a little from it. The key is to try and match what you're seeing on SG3842 schematic to what's on your board.
                          Either D101 or D102 are probably connected to the positive terminal of your 22uf cap. Since you're getting unusual values from both (I have no idea what a "beep" means on your meter), try removing them from the circuit board and check them again.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #133
                            Diodes are best tested with the diode test function on your multimeter. Put red probe on one side, black on the other. Record reading. Now reverse the probes and record reading.
                            One reading should be between 0.3 and 0.8V and the other is "1" or 0L (depending on your multimeter).
                            • DJM_PHX
                              • Dec 2010
                              • 47
                              #134
                              The beep tells you if there is a connection and if possible, the Fluke will continue to provide the resistance measurement. I'm using an Fluke 87 DMM.
                              • DJM_PHX
                                • Dec 2010
                                • 47
                                #135
                                On D103 I get 0.058 in both directions. In the above pic, D103 is just above and to a little right of the control chip (orange and black). D101 a 0.462 and OL, D012 returns a 0.441 and OL.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #136
                                  If D103 tests the same out of circuit, it is bad.
                                  • DJM_PHX
                                    • Dec 2010
                                    • 47
                                    #137
                                    Nope, not it!
                                    • DJM_PHX
                                      • Dec 2010
                                      • 47
                                      #138
                                      When I measure between pins 5(Gnd) and 7(Vcc), I see an decreasing meg Ohm resistance. I assume the little cap is charging back thru the ground side of the cap.
                                      Using the diode selection, OL between 5 and 7.
                                      • DJM_PHX
                                        • Dec 2010
                                        • 47
                                        #139
                                        That's OL with black lead on GND. 0.448 reversed.
                                        • alexanna
                                          • Mar 2010
                                          • 1346
                                          #140
                                          Originally posted by hoadle
                                          I check the inverter/power board find out had cold solder at quickconnect to VGA card, resolder is working final
                                          This thread is a long one,One member had a blinkling PLED and found a poor solder joint.It might be advised to check the area where he had problems.
                                          Al
