Need help DCLCD 19" LCD Monitor - I already replaced caps
--- begin sig file ---
--- end sig file --- -
Re: Need help DCLCD 19" LCD Monitor - I already replaced caps
I am waiting for my 22uF caps to come in so in the mean while, I was reflowing the solder on the connector and the transformers as you suggested to others.
On the SOIC-8 PWM chip, I found a single strand of copper wire that looked like it was laying between the two pins where the yellow line off the yellow circle is on the attached pic. I had it under a microscope and when so I brushed it off of the board. It was so small, I couldn't find it on the table. Maybe a failure mode?
I also measured the 22uF cap with a Fluke and it returned 21.7uF. Hmmm... I don't know about under a load though.Comment
I put the cap back in. No difference. I can hear a steady ticking noise that coincides with the voltage pulses mentioned earlier. I seems to be in the area of the yellow transformer or the sink next to it. I can't pinpoint it. Any input on this?Comment
The ticking is the SMPS controller trying to start up. If the little cap is proven to be bad and replaced with a good one, the ticking will go away.--- begin sig file ---
--- end sig file ---Comment
Before replacing the big one, what is the voltage across the 22uF cap?--- begin sig file ---
Ok. In post #2 on the right circled in green is the power filter caps. behind them are two units connected to the heatsink (in Yellow). Are they power transistors? The top one, on my board, the outer 2 to the center pin only have 0.1 ohms res. The other two have on the board have much greater amounts. That one is directly connected to the large yellow transformer, or is this the SMPS?
I have not even a flicker of light from the power LED on the front panel any more.Comment
What is the voltage across the new small cap and is it stable or fluctuating like before?--- begin sig file ---
They were suppose to be Rubycon's but they sent Chengx.
The voltage is not stable and is 10V-15V DC.
Is the large sqr. yellow unit the SMPS?
Why can I detect voltage on the heat sink by the large cap?Comment
Any chance of getting the Rubycon? Most here will question the Chengx brand even though the little cap may not root cause here.
If it is not the small cap, please re-measure the large cap to see if the fluctuating voltage is there or not. Other possibilities is that the SMPS controller chip is bad. I'm trying to guide you through each scenario one at a time.--- begin sig file ---
I appreciate it. The large cap V is the same and fluctuating as before. I read that the Chengx brand is not liked. I can try to get a replacement for it. Since I see the same voltages and fluctuation, I for now will leave it in. The board is looking a bit rough at the solder points.Comment
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by black6hostGood day!
I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
I'm going to replace the caps and I'll be the first...-
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by momakaHere's another LCD monitor repair: Westinghouse L2210NW.
Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
Pictures of the monitor outside/case after a brief...-
by zlr8rHey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
To begin with, this laptop was dead-dead.
Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;- am getting white power led
- 5-long-flashes on CAPS Lock and NUM lock
- then, fan full speed
- CPU heats up some (smaller die PCH, does not)
- always constant black screen no matter what's tried
- no USB recognition
- no HDMI output
I tried... - Loading...
