Re: Samsung SyncMaster 226BW
Hi
I have a Samsung 226BW whitch had the flickering backlight problem.
After exelent advice from this forum I have now replaced the caps.
1x 47uf 50v
1x 330uf 25v
2x 820uf 25v (My local distributer only hade this cap as a 35v. But it fitts, just)
2x 680 uf 25v
To my delight the screen worked once again.
For a few seconds until i got the computer to send a fully light screen.
If the computer sends a dimed screen signal all works fine. But a fully light screen cases the backlight to go out after a second or two.
I can see the image om the screen if I use a flash light even when thou the backlight is not light.
When the screen receives a full light signal the IP-45130A rev 0.1 board starts to make a high pitch screetching sound. It sounds like the noise comes from the power half of the board. But this is more of a gues then anything else.
The equipment i have to work with is basic. A soldering iron and a multimeter, that can not mesure capasitance.
I have replaced this far:
caps listed above
3A fuse as this was also blown
2x 4511GED ICs
I have been scouering the forum for a simuler problem.
I have been stretching my electronics knolage wafer thin.
And this has now become a misson to get it to work.
So any input or suggestions are greatly apreciated.
Many thanks and happy christmas
					Hi
1x 47uf 50v
1x 330uf 25v
2x 680 uf 25v
caps listed above
2x 4511GED ICs
 I think you are right about the sequence. I was viewing that connector as power in. It is not of course. What makes me suspicious that it is an output is that big AC socket at the other end of the board and all that power supply stuff around it. Duhh. Old brain, getting older.
