LG 22EN43T not start
  • Maxmad
    • Jul 2013
    • 58
    • Greece
    This monitor had problems turning on from time to time. Pressing on-off button made power led to blink with no picture.
    After some tries ,once it started, there was no problem. Working perfectly.
    Now, there is no way to turn it on after several tries.
    The whole board is an eax65118801. I attach the schematic.
    All voltages are fine , 5VS from IC102 and both 3.3VS and 1.2VS from IC103 are OK.
    There is no voltage drop except from 0.5V on R100 when on-off button is pressed.
    I checked 2 big SMD electrolytic caps, and some other ceramic.
    Why not starting?? Do you think is a firmware issue?
  • R_J
    • 9559
    Re: LG 22EN43T not start
    I see this is NOT the picture of YOUR BOARD (C154 does'nt look good, it seems slightly bulged).
    Post pictures of YOUR board.
    If this cap on your board is bad the backlight will not come on all the time.
    Have you checked the screen with an external light (flashlight) to see if there is an image on the screen? It could be the monitor is working and just the backlight is not working.
    • Maxmad
      • Jul 2013
      • 58
      • Greece
      I upload a picture of my board.
      C154 was checked, both capacitance and ESR are good.
      This in not a backlight issue. There is no picture at all.
      Monitor's power led is blinking. When was working the led was light steady.
      Seems that the monitor "is not starting".
      • frica
        • Nov 2017
        • 37
        • Spain
        Hello Maxmad:
        I am not an expert but I read a repair of a monitor where the Power Led blinks and no turn on the monitor:
        http://www.electronicsrepairfaq.com/...l-senso-m2289c
        The expert repairer say "The stand by on this computer monitor was flicking which gave me the indication of a power supply failure. I was expecting either cold soldering joints, bad capacitors or could be both because I have seen it many times in my field of work"
        The monitor was repaired removing and replacing same bulgy electrolitic capacitors. If in your monitor there is no capacitor problema, maybe the problem is cold soldering joints.
        • Maxmad
          • Jul 2013
          • 58
          • Greece
          Thanks for your replay frica.
          Unfortunately this is not a bulgy capacitor problem.
          Maybe this has to do with cold soldering.
          Today after keep pressing the power button the monitor powered on. Once it starts it's ok.
          I am trying to find the start up procedure in order to isolate the problem.
          • R_J
            • 9559
            At this point I would try a different power adaptor, It could be that the adaptor has an issue IE bad output cap. and the voltage to the monitor drops for a second causing the monitor not to come on. After a few tries the power supplies output cap is charged enough to keep the monitor on.
            You could try adding a 1000µf 25v capacitor across the 19v dc input and see if this makes a difference.
            • Maxmad
              • Jul 2013
              • 58
              • Greece
              Good suggestion, but no result.
              I add a capacitor and makes no difference...
              • R_J
                • 9559
                Check the voltage on P102, pins 1,2,5 & 6. Monitor pin1 when you turn on the monitor, then try again with pin2 and so on. It could be that there is a faulty led causing the problem.
                • Dumah Brazorf
                  • Jun 2013
                  • 179
                  • Italy
                  I quote the suggestion to try another power supply.
                  Crack it open, bulged caps should be there.
                  • Antonynl
                    HP zbook pwr Jack flashes 8x orange 150w adapter
                    by Antonynl
                    I'm stuck with a hp zbook : the charge port flashes white/orange 8 times and than a white light
                    it has 3.3 and 5v and 19v main power
                    got 3.3 on onoff switch that gets pulled down by onoff switch but no reaction
                    Got 1.6v on the middle pin of the power jack.
                    Using a 150w original hp adapter.
                    It has suffered minor some water damage
                    Board DA0XW1MBAI0 REV:1
                    Any suggestion or hint?
                    Thanks!!
                    09-21-2022, 08:10 AM
                  • sparrow2719
                    Missing VCCSA lenovo ideapad 300-15isk
                    by sparrow2719
                    Hi, motherboard code:
                    BMWQ1 BMWQ2 NM-A481
                    Rev 1.0
                    When plugged in the charger, the power light instantly ON, no fan spinning, battery RTC connected and good.
                    The on off button not responsive at all, must be pressed about 10 seconds or more and then the power light just blink a little, the fan just move a little bit and stop...and nothing. Measurred ONOFF# pin=3.3v on power button board and it goes to 0v when pressed.
                    No vcc core at all
                    No vccsa
                    nvidia core is ok
                    1.8v alw is ok
                    1v alw is ok
                    1.35v ddr...
                    01-03-2019, 12:53 PM
                  • Chungalin
                    Sony CD player CDP-XE500 repair, bad Servo-DSP IC CXD2545Q
                    by Chungalin
                    This nice Sony CD player based on KSS-213B optical pickup doesn't read any disc. Symptom is different from typical bad laser or dirty optics. It spins a bit and then it slows down while the lens is still focusing. Difficult to describe in words. Focus system has a characteristic sound that you can recognize when experienced.
                    I tried pickup in another player and, as expected, it worked fine. A new pickup replacement doesn't improve either. FFC OK. Check CD board SMD caps and C117 (100uF/4V) show 13Ω ESR. Replace it and no changes!
                    I recall that 10 years ago I...
                    09-28-2017, 09:05 AM
                  • mitu_sharma
                    on off problem with new71 la-5893p
                    by mitu_sharma
                    hi friends
                    i need ur help
                    this laptop came with onoff problem
                    when i press power btn its on then off again and again
                    i tried check out all the cores present but one is missing (Pl9)
                    according to schematic i tried to chk all voltages related with pl9 core
                    so i found that this core genrate automatically the problem somewhere else
                    i tried many things but no luck what could cause this?? please help
                    04-25-2016, 12:37 AM
                  • osci
                    LG 32LX2D-AA LCD tv no picture/sound
                    by osci
                    I picked up an LG 32" lcd tv from a tv repair business, I don't know the repair history of the unit or what was wrong, the owner of the business simply said to me if there's anything at the back of the workshop then I could have, so managed to pickup 2 plasma's of which one still work and the above lcd.
                    I've taken the back cover off and checked for any obvious popped caps on the main power board 6871TPT303B,and couldn't see anything out of the ordinary to my untrained eye, I then connected the power and virtually immediately the back lights came on and...
                    08-28-2010, 10:35 PM
