Sony CD player CDP-XE500 repair, bad Servo-DSP IC CXD2545Q
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This nice Sony CD player based on KSS-213B optical pickup doesn't read any disc. Symptom is different from typical bad laser or dirty optics. It spins a bit and then it slows down while the lens is still focusing. Difficult to describe in words. Focus system has a characteristic sound that you can recognize when experienced.
    I tried pickup in another player and, as expected, it worked fine. A new pickup replacement doesn't improve either. FFC OK. Check CD board SMD caps and C117 (100uF/4V) show 13Ω ESR. Replace it and no changes!
    I recall that 10 years ago I failed repairing a Sony CDP-213, with apparently similar symptoms. I remember it because I've repaired hundreds of Sony CD players and they're all highly repairable. Check schematics and both share same CD board. Since I have them, I decide to replace main ICs (IC103 CXA1821M RF amp, and IC101 CXD2545Q Servo+DSP). First one is easier, I start with this one, no changes. Then IC101, and it's fixed!
  • Xenon-Codex
    • 186
    • Finland
    I saved a CDP-XE320 from the dump. It plays all discs, but with CD-R's it's hunting hard and then recognizes the disc. No hunting with most silver cd's. Can the IC101 cause that?
    • Chungalin
      • Jul 2014
      • 423
      • Spain
      I don’t think so. The failure I described was an all-or-nothing one, not a selective one like you say. I’d point to laser pickup, possibly dirty or dusty.
        • 31305
        ajust the laser current while scoping the eye pattern.
        cdr's have lower reflective signal than pressed disks and cdrw's are even worse.
        a lot of players - specially made by philips run the laser at minimal current to give it a long life - downside is they hate cdr's
        • Xenon-Codex
          • 186
          • Finland
          I already cleaned the laser. No change. It hunts 1-4 seconds to read the TOC, and then play flawlessly.
          • nervous_capybara
            Repairing the Hitachi DA-6000 CD player
            by nervous_capybara
            Hello everyone !
            I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
            Feel free to share your experience if you ran into other issues.
            DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
            CD tray would not come out of the player
            I could hear a motor spinning inside the player but the CD tray would not come out.
            Turned out that the issue was the CD tray belt that aged poorly and began to...
            11-05-2025, 03:11 AM
          • bogosort
            Sony DVD player stuck tray (DVP-SR310P)
            by bogosort
            I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
            Anyone knows why?
            Thank you....
            05-11-2024, 04:29 PM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • mikey5791
            Sony CFS-5000S radio cassette player no FM reception
            by mikey5791
            Hi forum members,
            In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
            Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
            I opened the casing inside and checked for any dry solder, burned component or loose wires...
            02-24-2023, 03:48 AM
            MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
            This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
            09-06-2024, 05:30 PM
