on off problem with new71 la-5893p
  • mitu_sharma
    • Jul 2015
    • 182
    • india
    hi friends
    i need ur help
    this laptop came with onoff problem
    when i press power btn its on then off again and again
    i tried check out all the cores present but one is missing (Pl9)
    according to schematic i tried to chk all voltages related with pl9 core
    so i found that this core genrate automatically the problem somewhere else
    i tried many things but no luck what could cause this?? please help
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: on off problem with new71 la-5893p
    where is schematic?
    • mitu_sharma
      • Jul 2015
      • 182
      • india
      here it is
      • smali
        • Sep 2014
        • 287
        • Pakistan
        First check the short circuit of PL9 with Ground. how many ohms with ground of PL9?
        • mitu_sharma
          • Jul 2015
          • 182
          • india
          6 ohm
          • smali
            • Sep 2014
            • 287
            • Pakistan
            ok check the voltage on PR128 both legs if you received 3 volts then remove PR130 for temporary checking and check voltage on pl9.
            • mitu_sharma
              • Jul 2015
              • 182
              • india
              no resistor placed on that location and no voltages present on pr128 both empty legs
              • atsio
                • Oct 2013
                • 819
                • Greece
                Probably problem with gpu, reflow or better reball.
                • mitu_sharma
                  • Jul 2015
                  • 182
                  • india
                  today i spent lots of hour to solve this problem but no result
                  i reball nvidia but still same
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1488
                    • portugal
                    5891p , make sure , near the trackpad button they are usually with a black tape on it , lift it and chek the components in that area !
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1488
                      • portugal
                      and add some of does with main bios issues as well, very rarely i replaced a video chip or reballing on this units
                      • mitu_sharma
                        • Jul 2015
                        • 182
                        • india
                        as i told i checked all the component no one is faulty
                        i cant understand where i make a mistake
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          well if it does shutdown after turning on , chek S3 S5 stages problems is somewhere on hardware starting .
                          • LP_tekh
                            • Oct 2015
                            • 95
                            • Laos
                            You need to replace the gpu with a new one. Reball does not solve the issue, if the bga chip is faulty.
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              disable GPU and if machine still turning on and off NOT GPU issue !
                              • sopik78
                                • Nov 2013
                                • 517
                                • Czech Republic
                                Well, I had similar issue on a few 5742's. As I remember that was 5894P board, but it doesnt matter.
                                First was BIOS issue, I had to try three different BIOS dumps and flash it 3 times until it works.
                                Second one fixed reballing Intel PCH.
                                As far as I understood here, you have no power on VGA, so try to check VGA_ON and DGPU_PWR_ON signal. I quess the problem here is problem on PCH as well.
                                The same I had on some Samsung N350 few weeks ago.
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1488
                                  • portugal
                                  i agree here with sopik , i believe much more problems on PCH rather than gpu . meanwhile you got a short or else machine would start , so you must chek all coils on S0 S3 andS5 you must chek resistivity on all states to know wich is shorting !
                                  • bilinch
                                    • May 2015
                                    • 19
                                    • Turkey
                                    Today another La-5893P comes again. The problem is power on then off like mitu_sharma. I check the board and find that ethernet component (U39) is getting hot. After unsoldering it, everthing is fine.
                                    • rubbert
                                      • Apr 2023
                                      • austria
                                      Hi everybody
                                      I found this page because my old laptop is doing same behaviour, turns on/off (5 secs cycle). It is Acer Aspire 5741G, motherboard new71 la-5893p rev 1.0 (different than mitu_sharma, rev 0.1)
                                      found schematics here https://cdn.badcaps-static.com/pdfs/...161e700b97.pdf
                                      I tried all options mentioned in this thread, still no luck.
                                      I can say that PL9 is 3 Ohm. is it good or bad?
                                      few details more:
                                      1+ year ago this laptop had some issues at boot, sometimes it turned off in few seconds but with a 2nd start it used to work. after few months it did not turn on.
                                      I disassembled it and did a quick investigation, unsolder the CMOS battery and ... forgot about thies laptop, because my sister had another one meanwhile and I had my university course to finish.
                                      today I took it again, plugged the power and found this.
                                      differently from past it starts, but ...
                                      any idea on additional checks?
                                      btw what is S0 S3 ... I cannot find in schematics.
                                      thank you very much in advance
                                      • theone111
                                        by theone111
                                        3. Problem: TV shuts down
                                        07-22-2024, 10:36 AM
                                      • Zeonalbasta
                                        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                        by Zeonalbasta
                                        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                        09-13-2024, 01:17 PM
                                      • Gibon378
                                        Problem with stopping audio and video for no reason
                                        by Gibon378
                                        PC Specs:
                                        • CPU: Ryzen 5 1600
                                        • GPU: GTX 1080 Palit JetStream
                                        • MOBO: ASRock ab350 PRO4
                                        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                        • PSU: XFX 650W (don't remember what model)
                                        • OS SSD: ADATA SP920
                                        • OS: Windows 10 21H2
                                        Problem description:
                                        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                        11-19-2022, 09:41 AM
                                      • perzyk23
                                        Lenovo T580 - LCD Panel problem - error 0288
                                        by perzyk23
                                        Good morning,
                                        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                        10-25-2024, 12:42 AM
                                      • SDNarcia
                                        Dell 15R-5521 keyboard problem (KBC?)
                                        by SDNarcia
                                        Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                        As additional information,...
                                        07-20-2024, 10:47 PM
