Fujitsu Scaleoview L22W-3 inverter fail
  • dondrusco
    • Apr 2009
    • 89
    Hi, everybody.
    I smoothly moved from level one - bad caps to level 2 - not working inverter.
    There is FSP055-2PI02A power board with inverter. I recapped it, but it still won't work. It starts only for 4-5 seconds and then turns CCFL off. During light on it hazzles silently. Inverter logic chip is MP1038EY.
    I want to replace those two N-MOSFETs, but I can't read type of them.
    Have you any suggestion, what type of MOSFET to use?
    Thank you
  • dondrusco
    • Apr 2009
    • 89
    Re: Fujitsu Scaleoview L22W-3 inverter fail
    I measured backlight transformer once again, and there is the problem.
    One secondary circuit has resistance 1kOhm - it is OK. But the second one has more than 10kOhm.
    The type is SPI 8TC00332. I found it only in the United States. Is there any option to buy it in Europe?
    Thank you in advance
    • dondrusco
      • Apr 2009
      • 89
      Fine, repaired.
      I ordered new transformer from lcdparts.net
      Now it works fine.
      • PlainBill
        • Feb 2009
        • 7034
        Originally posted by dondrusco
        Fine, repaired.
        Now it works fine.
        Good job!!!
        PlainBill
        • gougou123
          • Nov 2009
          hello dondrusco
          J break down same that you
          I have were on the site my steps of SPI 8TC00332
          you can informed me about the American site
          thank.......... "french"excuse me
          • dondrusco
            • Apr 2009
            • 89
            No problem with lcdparts.net site. I ordered new transformer and paid by PayPal.
            http://lcdparts.net/TransformerDetai...ProductID=2796
            It arrived within one week. No customs - amount was within free customs range (25 EUR)
            dD
            • gougou123
              • Nov 2009
              thank you to have answered also quickly
              I made an account, my as soon as I but my email and password nothing this master key
              thank you.thank you.thank you.dondrusco
              • terry
                • Oct 2007
                • 91
                • Milton Keynes, Bucks
                Re: -3 inverter fail
                Can any one help please, I have a Fujitsu Scaleoview L22W monitor with a power problem, The board number is FSP055-2PI02A. The power FET has blown and I am can not see any part number.
                • jetadm123
                  • 2169
                  Apparently, this board is also used in the Acer X221W and X222W. Maybe someone who has this model monitor can chime in.
                  • Toasty
                    • Jul 2007
                    • 4171
                    Not a FET.
                    TOPSwitch.
                    Report mains cap brand and series please.
                    veritas odium parit
                    • BarrelRoll
                      • Jan 2011
                      • 34
                      I'm holding an X221W power supply in my hand right now. The IC in question is this:
                      First line:
                      F 1 H06
                      Second line:
                      CM0565R
                      • Toasty
                        • Jul 2007
                        • 4171
                        Fairchild - CM0565R - Power Switch
                        aka: TOPSwitch for all intents and purposes.
                        PDF attached
                        MOSFET Switcher, PWM combo
                        Not finding anyone with stock. Most are storehouses that want to sell you $300 - $1000 or better. Not one piece.
                        Toast
                        veritas odium parit
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          You can probably replace it with an actual TopSwitch or maybe ST Viper series, just requires some careful reading of datasheets.
                          A working TV? How boring!
                          • inteltronics
                            • Jan 2011
                            Hello, i have same board to Acer, the component is:
                            first line:
                            F1 G47
                            second line:
                            CM0565R
                            Wbr, Carmelo.
                            • terry
                              • Oct 2007
                              • 91
                              Thanks for all the help finding the part number, I can not find any one with them in stock.
                              Terry
                              • gio9sig551
                                • Aug 2012
                                • 3
                                • Finland
                                Hi, This is my first message here and I have the same problem than dondrusco had with a L22W-2 monitor, the lights shouts down after few seconds.
                                I saw how to solve it and I only need to order the transformer. I just wanted to ask if that tranformer is ok for every L22W monitor or maybe it's different for the L22W-1 and the L22W-2 and if it's like that how can I see which transformer I need?
                                And maybe that's not even the problem in my monitor.. I saw a guide here with all the problems that can cause the screen to shot down. There is an easy way to understand if the the transformer is the problem or not?
                                Thanks!
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  You are correct - it could be many reasons- Does you transformer have any numbers on it.
                                  Welcome to the forum-
                                  We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                                  Examples of what is needed
                                  https://www.badcaps.net/forum/attach...1&d=1290283049
                                  https://www.badcaps.net/forum/attach...7&d=1280167246
                                  • gio9sig551
                                    • Aug 2012
                                    • 3
                                    • Finland
                                    Really thanks for the good welcome! Here the images:
                                    I hope this helps. Because I guess it's not so easy to understand what's wrong in that from some images. It seams that the component are not burned or broken (from the outside).
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      Please edit your post take off the pictures and repost as above
                                      • gio9sig551
                                        • Aug 2012
                                        • 3
                                        • Finland
                                        Oh sorry about that.. I cannot even read now.. And I can't find where to edit..
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                          Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook U Specification for Upgrade or Repair
                                          This specification for the Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7411 boardview and LIFEBOOK U7411 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                          Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook U Specification for Upgrade or Repair
                                          This specification for the Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7511 boardview and LIFEBOOK U7511 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Fujitsu LIFEBOOK LIFEBOOK U9311 Notebook U Specification for Upgrade or Repair
                                          This specification for the Fujitsu LIFEBOOK LIFEBOOK U9311 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U9311 boardview and LIFEBOOK U9311 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
