AOC LM725 screen goes blank
  • selldoor
    Slow Learner
    • 7870
    #41
    Re: AOC LM725 screen goes blank
    Stumbled across this info - (dont know for certain if it is correct)
    TT2140 Transistor. Used as a Horizontal Output Transistor in newer Funai,
    Sylvania, Toshiba, etc... sets. Will Sub with any of the following info
    below;
    TT2140 = AD301779 $1.16 (Tritronics) Original Transistor with TT2140 Written
    on it.
    TT2140 = BZ510120 $2.31 (Tritronics) Original Transistor with TT2140 Written
    on it.
    TT2140 = 2SD2627 $2.89 (Tritronics) Subs fine and same part Funai sends
    out.
    TT2140 = NTE2640 $2.35 (Tritronics) Silicon NPN Horizontal Output
    Transistor.
    TT2190 = Also will sub with any transistor-cross above for the TT2140.
    • benja1475
      • May 2012
      • 26
      • Philippines
      #42
      this is what I'm wondering... why TT2190 is being use as a driver by the other transformer while the c5706 is capable of doing the job...
        I always use 2sc5707 in place of 2sc5706. The 2SC 5706/5707 have very low Vsat compared to the TT2190, BUT TT2190 has much much higher Vce (1500V), unless the design of the ciruits has very high kick back voltage, so they use the high voltage transistor instead. you can try the 2sc5706/5707 ad see what happen, but make sure to check those two blue caps.
        • Falipene
          • Mar 2013
          • Spain
          #44
          I had the same problem, monitor works for 3-4s then screen goes black.
          I had laying around this one for long time, and bought the 5706 off ebay while ago.
          So without testing, I swapped all 4 5706 for new ones and 2 caps (green ones) and the screen not even turned on, always black (power light works)
          Then I put again old caps and same black screen.
          So desoldering transistors for checking I saw this:
          Soldered again two caps and four 5706 and fixed the transformer same black screen.
          This pictures as it is now:
          TOP:
          bottom:
          Should I replace this caps too?
          Thanks!
          • selldoor
            Slow Learner
            • 7870
            #45
            Please update your profile with Country and Mains voltage.
            Many members do not like images posted in line or offsite - they should be posted using
            manage attachments
            • Falipene
              • Mar 2013
              • Spain
              #46
              manage attachments
              I'll fix it asap I can edit my last post
              Meanwhile I uploaded here the images.
              Sorry.
              • selldoor
                Slow Learner
                • 7870
                #47
                Ok Better check further with a magnifier for cold joints.
                Can you also check q212, q209 and q210 again for solder bridge on the legs. Probably just the pic but better check.
                You should also resolder (Remove the old solder and replace)
                on C213 and C214 and C201.
                • Fred_Brook
                  • Sep 2014
                  • Argentina
                  #48
                  Can you tell me the function of CN102 connector signals?
                  Or share the circuit... it would be enough to understand
                  • jeromy
                    • Jan 2017
                    • 11
                    • philippines
                    #49
                    Originally posted by chriscute42
                    hi kharr, where did you buy transistor c5706?.. im from manila philippines... thanks...
                    hello, Hope you already able to buy said transistor in manila, its available in Deeco , the biggest electronic store in Quiapo near Raon, around 25- 30 php each
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • Chrissygizmo
                      Panasonic TX-48CX350B backlights but white screen , blank screen
                      by Chrissygizmo
                      Hi all, I’ve got a problem I hope someone can help me fixi.
                      I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                      01-11-2025, 03:18 PM
                    • dicky96
                      HP Elitebook Screen blank - backlights but no image
                      by dicky96
                      Hi guys
                      I'm trying to fix this laptop screen
                      Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                      OK so I have the original screen which works but has lines across the bottom quarter of the screen
                      I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                      04-28-2021, 07:30 AM
                    • Kalman27
                      Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF OLED Blank screen
                      by Kalman27
                      We have a Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF for repair. The original issue the OLED screen is blank.
                      We have replaced the OLED screen with the exact model, also we replaced the LCD cable, but no luck.
                      I think there is something with the motherboard. I don't really have experience with OLED screens so far, so not sure how it should work. I have seen some laptop comes with a separate controller board, but this model does not.
                      Also, there is an error in Windows device manager - This device cannot start (Code 10) - Intel(R) Serial IO I2C Host Controller...
                      06-17-2025, 05:52 AM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
