Help with dead Commodore 1802
  • roadrash
    replied
    Re: Help with dead Commodore 1802
    Originally posted by R_J
    The bulb you are using has too high a resistance, and remember that 72.5Ω you measured is the DC resistance, it is going to increase even more when it lights.
    The A/C voltage is being droped from 240vac to around 13vac to supply the diodes which then outputs 18vdc.
    So you need to find a regular 60~100 watt Incandescent lamp
    Ive connected 60w bulbs to both places now and when i power it up i hear a clicking noise and one of the bulbs flickers which then changes to a buzzing sound. Voltage at filter cap is still only 15v
  • R_J
    replied
  • roadrash
    replied
    Originally posted by stj
    are you sure the rest of that cable is good?
    you should see about 340v dc across the main filter cap
    Yes that cable ok now because if t wasnt the bulb that is replacing that big resistor woulnt illuminate.
    That is the resistor that kep popping if you remember and is what we were trying to diagnose..
    What would cause a low voltage at that filter cap?
    I just tested it again and I am getting 18v DC.
    replied
  • roadrash
    replied
    I just checked a couple incandescent lamps, these are 120vac 60 watt = 16Ω. (Christmas light) 120vac 7 watt = 189Ω, Appliance lamp 120vac 40watt = 27Ω
    Sorry for delay getting back to you both but was in hospital yesterday getting steroid injections into my spine and boy was I was I very sore today.
    Right well got all the bulbs now working as they should and when powered on the only bulb illuminated is the one across where the resistor R801 was. The bulb where L803 was does not light up.
    The voltages now are now as follows:
    At filter cap C803 it fluctuates between 6.5v DC and 16v. Although when first powered on it reads 6.2v DC and slowly rises the longer its turned on.
    On T801 at pin 2 the voltage fluctuates between 9.5v and 13v DC but If I set the meter to AC I get a steady 30v which makes me think its AC and not DC voltage there.
    Pin 4 it again fluctuates using DC scale between 8.5 and 13v but if tested using the AC scale I get 30v.
    At the pins 4 & 5 of the LOPT again the DC voltage fluctuates and its impossible to get a steady reading. If I measure it using AC scales Pin 4 still fluctuates a little buts around 13v and Pin 5 its the same slight fluctuating but up to 15v.
    According to your schematic RJ I should be using the DC scale to measure these voltages. I am taking the DC ground/negative from the C803 Cap on the side of Q803 & R803 & Q805 which according to your schematic RJ is the the DC ground.
    So it seems I am not getting rectified voltage or am I doing something wrong still?
  • roadrash
    replied
    I just checked a couple incandescent lamps, these are 120vac 60watt = 16Ω. (Christmas light) 120vac 7 watt = 189Ω, Appliance lamp 120vac 40watt = 27Ω
    You are not going to believe this but that length of 3 core flex i was using had a break in it and after i cut 6 inches of each end it now works. What are the chances of that.
    I didnt think to check the cable as it looked like it was good. Anyway i now have the bulbs iluminating as they should. I will have another go at it later now to see if i can make any sense now over what we checked.
  • R_J
    replied
    replied
    it's really strange that you see a resistance but no life - be interesting to do an autopsy and cut the metal cap open!
  • roadrash
    replied
    strange, you should see some voltage and some life from the lamp.
    Well I just wired one of those ever ready bulbs to 240v mains and it doesnt light up. They all seem to be the same. They are nor open circuit and show a resistance but dont iluminate with 240v ac. I think these bulbs are what are fitted into ovens etc but surely they should light up. I will go andf buy some more of the bigger ceiling type bulbs tomorrow and have another go. No wonder we havent been getting anywhere.
    replied
  • roadrash
    replied
    What do you have in place of the resistor? if there is nothing there, You will not get any voltage across the capacitor because you are not getting any AC to the diodes.
    I put this bulb ain place of the resistor maybe i need a bigger bulb? It measures 72.5 ohms.
  • R_J
    replied
  • roadrash
    replied
    At filter cap C803 there is no AC voltage. This is correct! IT IS DC VOLTAGE!!!!
    Yes thats right. No voltage at filter cap. I am right measuring accros the 2 cap contacs (+and -).
  • R_J
    replied
  • roadrash
    replied
    This is the a/c path and where the 4 diodes (in a bridge configuration) convert to DC. After that it gets more complicated as the STR54041 IC takes that DC and switches it, at HIGH FREQUENCY (around 20KHz) into A/C to drive the transformer.
    Hey RJ thats really helpful of you. Sorry been a delay in getting back to you as ive been unwell all week with my MS. Anyway what yiou did there makes it a lot more plain where the AC and DC changen and where I take the measurements from. Going by your Shematic I now find I am getting no readings where I had some before.
    At filter cap C803 there is no AC voltage. (before I was using one off the AC inputs as a pole but now if I measure across the capacitors 2 contacts -+ there is no voltage reading and I checked fuse again and its ok. Should be a voltage across the 2 poles of C803?
    I will have to look in to this further because there is something amiss here. Now I use your schematic RJ, I am getting no readings where I was getting something before.
    I will sleep on it and start again tomorrow with a fresh start when I am not so fatigued.
    thanks again..
  • R_J
    replied
  • roadrash
    replied
    after the mains input diodes - it's all DC
    Ok I will have to use my other automotive meter for voltage checking. I am a little confused here. I know you said that everything after the mains input diodes is DC. The mains input diodes are these the diodes marked 4700 500V x4 on the schematic? It might be easier for me for the time being until I learn a bit more if you could give me the positions as to where to take the reading from. Sorry its a pain I am still getting to grips with the stage where AC is coverted to DC and the place where DC & polarity +- takes effect.
  • roadrash
    replied
    I have just realised there is a fault with my multimeter as its only showing 160v and not 240v. This would mess the things up a bit. Ive had a lot of problems with meters going wrong like incorrect reading of resistance and now on this meter its voltages that are wrongly measured. Can you reccomend me a good reliable digital meter on Ebay thats not going to coast a arm and leg.
    For examle I have a really nice USpro EM129 automotive meter here that for some reason gives incorrect resistance readings but there isnt any information about how I can calibrate it, if thats possible. The meter I have been using to test this monitor is a XL830L I bought from Ebay only about 6 months ago and is my 2nd one to go wrong now.
  • roadrash
    replied
    Thank you both for that help and its spot on as usual. RJ I know exactly what you mean about the meter beep. It's not a accurate way of checking for continuity as how many times has my meter beeped a short when its just a low resistance. You got that right too STJ I forgot we isolated the PSU so using any part our of that area to take a measurement is not going to be valid. Why did I not think of that. I am learning loads here and a lot more confident working on things like monitors now than I was when I would be reluctant to delve around in one if it was playing up. And it would get dumped eventually. I am going away for a week so wont get anything done now until I get back but I am more and more confident that with your help we will get this thing sorted now like we did before.
    At least you will get a break from me for a week lol.
    Speak again when I get back. Cheers!
    replied
    the input is isolated, for testing the psu the ground must be on the same component.
  • double_DD
    How can I be sure that my EC chip is dead?
    by double_DD
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
    03-12-2025, 07:47 AM
  • disorder
    ps5 edm-033 dead after hdmi/usb ports destroyed
    by disorder
    hello guys,
    i need help to repair a edm-033 ps2
    history : as always hdmi port and usb ports destroyed after unplugged
    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
    so i changed it
    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
    i don't see any projection of liquid metal on pcb.
    01-14-2025, 12:48 PM
  • zunasthegreat
    Chieftec GPS-450-AA with dead 20N60C3
    by zunasthegreat
    Hello everyone hope all doing well!
    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
    09-01-2024, 07:12 PM
  • Beton
    Finding a dead short component
    by Beton
    Hi guys!
    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
    I have a bench PSU and if I try to inject voltage the voltage...
    12-10-2021, 01:05 PM
  • FiguringITout
    MSI Raider GE75 - Not posting, probable dead CPU
    by FiguringITout
    Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
    Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
    07-25-2024, 07:27 AM
