Help with dead Commodore 1802
  • R_J
    replied
    Re: Help with dead Commodore 1802
    Originally posted by roadrash
    Its fluctuating between 50 & 69v DC.
    That is likely too low for the power supply to start.
  • roadrash
    replied
    Originally posted by R_J
    What is the voltage across C803, If this voltage is too low the circuit won't start
    Did you check that C806 did measure different with your meter ?
  • R_J
    replied
    Ok soldered in and still the monitor is tickimg and lilght bulb is flashing. So no change
  • roadrash
    replied
    Just a thoght and i think STJ mentioned it before, it couldn't be a transformer could it? Running out of things to test now. We could just replace all caps in psu.
  • roadrash
    replied
    They will be fine
  • R_J
    replied
    They will be fine
  • roadrash
    replied
    Hold them up to the monitor so I can see them I'm sure they will be fine, With newer technology they can make them smaller as long as the capacity and voltage is correct they will work.
    Check the new 2.2/160v capacitor [C806] on your meter just to see what it displays.
    Ok here is comparison picture. They are about half the original size.
  • R_J
    replied
    Originally posted by Agent24
    I'm guessing there isn't one, but that wasn't my point. Just figured I'd add the information as it may help someone in the future.
    I made an edit after you quoted me.
  • Agent24
    replied
    Can you point out the Optoisolator in THIS circuit?
  • R_J
    replied
    Optoisolators can degrade over time too, with the LED inside becoming dimmer like any LED does.
    I was talking about THIS ciruit ONLY it was not a ment to be a general comment, This monitors power supply does'nt us an optoisolator. Since the monitor worked befor it was stored, components like transistors, ic's, resistors, normally won't deterorate, but electrolytic capacitors can dry out.
    The crt will degrade over time also.
  • Agent24
    replied
    I would replace the caps, They are about the only parts that will deteriorate overtime, This is a crude switching circuit and if it doesn't operate properly it won't work.
  • R_J
    replied
  • roadrash
    replied
    I just repaired a monitor power supply that would turn on and off about 10 times before it would stay on. The power supply startup cap was a 22µf/50v. It's capacity checked 21.5µf. However the scope showed about 3~5v of high frequency ripple on it. replaced it and the power supply was working fine.
    C806: c=223nf = 0.22µf. On the schematic it looks like 2.2µf/160v
    I ordered the two caps as suggested and they arrived today. However I was shocked at how much smaller they are than the originals. WIll this be OK or should I find some others a similar or nearer size.
  • R_J
    replied
  • roadrash
    replied
    Check if you have ANY voltage on C814 or C812, if the power supply is ticking, it is trying to start but can't, either due to a short in the secondary or the primary can't start properly. I would start by replacing C806 and C825 and see if it makes a difference.
    C806 & C825 when tested give the following results:
    C806: c=233nf vloss=1.5% ESR=1.6 ohms
    C825 c=12.25uf vloss=0.7% ESR= 3.0 ohms.
    Will need to get some 10uf 160v if its no good as I only have 50v.ones.
  • roadrash
    replied
    Originally posted by stj
    what AC voltage at L802 ??
    input AND output side?
    I get 237v AC.
  • R_J
    replied
    replied
  • roadrash
    replied
    I would just use the 60watt lamp in place of the resistor R801.
    Ok i put the smaller bulb on L805 and when i power it up i still get the ticking noise and the 60w lamp flickering.
  • R_J
    replied
  • double_DD
    How can I be sure that my EC chip is dead?
    by double_DD
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
    03-12-2025, 07:47 AM
  • disorder
    ps5 edm-033 dead after hdmi/usb ports destroyed
    by disorder
    hello guys,
    i need help to repair a edm-033 ps2
    history : as always hdmi port and usb ports destroyed after unplugged
    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
    so i changed it
    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
    i don't see any projection of liquid metal on pcb.
    01-14-2025, 12:48 PM
  • zunasthegreat
    Chieftec GPS-450-AA with dead 20N60C3
    by zunasthegreat
    Hello everyone hope all doing well!
    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
    09-01-2024, 07:12 PM
  • Beton
    Finding a dead short component
    by Beton
    Hi guys!
    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
    I have a bench PSU and if I try to inject voltage the voltage...
    12-10-2021, 01:05 PM
  • FiguringITout
    MSI Raider GE75 - Not posting, probable dead CPU
    by FiguringITout
    Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
    Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
    07-25-2024, 07:27 AM
