Westinghouse 22w3 DAC 19M009
  • bvamunds
    • Jun 2015
    • 25
    There are a few threads on the forum which talk about bad caps in the 19M009. Initial issue in July 2015 was a bad rectifier which was replaced along with the main 120uF 400V cap. Since C200 and CE103 were questionable bulging they were also replaced with Nicicon's from Digikey in July 2015.
    In July 2018 the monitor stated going black after about 3 to 5 MINUTES. There is also a momentary buzzing/chirping sound when the monitor first starts until an image is displayed and when it goes black. I've opened the unit again and pulled the DAC. There are no obvious bad caps. Notice the heat discoloration around U202 and U203, it was there before the repair also. When powering the unit the temp on U203 runs about 92 F while U202 is 105 F. I've read that these P605's are like the HOT of the inverter and can generate a lot of heat. Should they be running different temps? But they seem to check ok with resistance in circuit. I have a 19M008 schematic, not a 19M009 but I believe the layouts are similar and only the component labels are slightly different.
    I'm not sure where to start. Should I test voltages with digital VM?
    Looking for help on this reliable daily user from my spouse. She is using a Dell 19" 4:3 in the meantime and misses her wider 16:9 screen. Happy wife is happy life, and my wife is not happy right now... So any help is appreciated.
    Cheers, BrianA_MN
  • CapLeaker
    Leaking Member
    • 8116
    Re: Westinghouse 22w3 DAC 19M009
    put the thing back together and turn the back light's as low as they go and let it run. See if it takes longer for the back lights to go off.
    • bvamunds
      • Jun 2015
      • 25
      Do this to determine what? In other words, what does this test? I'd like to learn. BTW - Happy New Year, I'm surprised anyone is on the board tonight! Cheers.
      • CapLeaker
        Leaking Member
        • 8116
        this trick is used on LCD and LED sets. Less brightness requires less power. Less power used, less heat produced.
        On a LED set it means bad LEDs in the back light.
        On a LCD set it could be cold solders, bad CCFL transformer etc.
        You didn't provide too much information on what exactly goes out. So I figure, that the monitor stays on, but the back light goes out.
        I did see cold solder joints on the PSU. Basically resolder anything that is under heat, transformer, heat sinks, the 2 IC's...
        Measure the output of the CCFL transformer winding on both transformers and compare them. If they are more than 3% apart, well... then one is toast. The bad transformer will run hotter than a good one. Looks like the transformer on the outer edge is a bit dis-coloured. That may explain why U202 runs hotter than U203.
        Hope that helps you to get started.
        • bvamunds
          • Jun 2015
          • 25
          Re: Westinghouse LCM-22w3 DAC 19M009
          On a LCD set it could be cold solders, bad CCFL transformer etc.You didn't provide too much information on what exactly goes out. So I figure, that the monitor stays on, but the back light goes out.
          This is an LCD screen with 4 CCFL's. It is a great suggestion. Sorry I forgot to test with the flashlight. It is now tested and indeed it is only the backlights which are going out, not the whole power. I can see the image when shinning a LED flashlight into the screen and moving it around I can see the image is present.
          If I change the brightness to nearly off, then the backlights stay on longer. Now I'm not sure if that eliminates the CCFL's as being the culprit, or if it simply means that one or more is starting to fail and with highest brightness will fail totally soon?
          Does the buzzing indicate that a transformer may be going? I saw a listing from 2009 that also suspected the yellow glue of the transformers has becoming conductive and possibly needing to be removed?
          Can you suggest a specific area of cold solder joints? This is an older board and while they look tarnished, I don't really see cold joints. But then maybe resoldering can't hurt?
          They ohm out the same. I don't think they are bad, but maybe the buzzing is coming from one of them? I'll have to look through my spare CCFL's or make the 11W test lamps suggested in two minutes to black tutorial and see if I can up the brightness and figure out which CCFL is bad.
          Thanks for the on-going suggestions. Cheers, Brian
          • CapLeaker
            Leaking Member
            • 8116
            I don't think it is more. I would say either one CCFL or one transformer or these blue caps etc.
            That brown glue remove always on sight. It just spells trouble. A bad transformer always runs hotter.
            Right on. Resolder everything. The connectors, the blue caps, the transformers and the little ICs. Sometimes you do not "see" cold solder joints with the eye.
            Well, my guess is that the transformer that buzzes is getting driven by that little IC that runs hotter than the other one. I can see from the picture that the buzzing transformer must be the one on the outer edge, because it is a little discolored = running hotter. The 11W CFL trick is a good idea. Usually faulty CCFL's are black on the edges and when they are on, they give a pinkish tint, not really white.
            You are learning fast!
            • bvamunds
              • Jun 2015
              • 25
              So in this monitor it appears a CCFL set is failing after further testing. The failing unit is probably the top set because the screen is not as bright on top. I had a spare old twin lamp set, which I plugged in to replace the top set. I then turned up the brightness to 90/100 and the monitor stayed on in excess of two hours. The interesting thing is if I turn the brightness down to 30/100 and the contrast up to 90/100 the lamps will still stay on in excess of two hours also. My wife tends to have her monitors blank-out after one hour.
              I'm still trying to figure-out the chirping. There is still a chirp when powering up or the monitor goes to sleep even with the replacement set in place. If I touch the outer lamp transformer in the dark I do see a discharge between my finger tip and the winding, which I don't see with the lower transformer. Perhaps the transformer is reading correct resistance but failing only under higher voltage demands and the internal short finds my finger or maybe I should attempt out-of-circuit measurements?
              This Westinghouse LCM-22w2 (note corrected model) has a Chi Mei A220Z1-H01 LCD screen assembly. It uses a Chi Mei M220Z1-L03 lamp set from CCFLWarehouse dot com. The lamp set is made of 2 lamps with total length of 490mm including silicon end caps.
              This monitor is the similar to both ACER2216W or ViewSonic VX2235W. I have used the available online service manuals to help, along with CapLeaker's help of course.
              • R_J
                • 9535
                Brightness and contrast have no effect on the backlight, they only adjust the video signal to the lcd itself. You would need a backlight adjustment in the menu and if its not there you can't turn it down without modifying the circuit. Placing your finger on the transformer and looking at the corona is not going to tell much, It could indicate a slightly higher voltage due to less current draw by the lamps, If one set of lamps is bad the other set is on its way out also.
                As for the chirping, it may be a weak capacitor in the power supply, remove and check them or try relacing them.
                • bvamunds
                  • Jun 2015
                  • 25
                  R_J, thanks for the information, although it has confused me. CapLeaker's recommendation was to lower the brightness and testing seem to prove it prevented the CCFL's from shutdown. Doesn't the brightness control the high voltage sent to the CCFL's, otherwise, why would turning down the brightness affect the time to black? Also it certainly seemed that when I turn up the brightness, the spare lamp set became brighter to my observation. So what is causing the CCFL power circuit to shutdown when brightness is set higher than 70/100? Just want to learn and hope you can better explain
                  • R_J
                    • 9535
                    It looks like the brightness Does control the diming of the backlight. I checked the schematic for a different board and it does have an Vadj pin from the main board to control the bit3713 drive ic
                    • bvamunds
                      • Jun 2015
                      • 25
                      Thanks for the clarification. I too was checking the DAC-19m008 schematic
                      Code:
                      http://monitor.espec.ws/files/delta_dac-19m008_198.pdf
                      (which is closest that I can find on Internet to the DAC-19m009) and indeed on the page 6 schematic shows the Vadj input and page 3 describes the voltages for ignition and low and high brightness. Thanks again. Cheers. Brian
                      • bvamunds
                        • Jun 2015
                        • 25
                        I did find a cracked bulb on the upper, which was causing the screen to blank as if it was two seconds to black. Interesting that it was still lighting with a lower voltage. I order replacement bulbs from CCFL Warehouse. Actually found the correct bulb with leads in Closeout section. I replaced the two upper bulbs and now the top is brighter than the bottom! Probably means that the lower bulbs are starting to fail also, so I'll replace them next.
                        I'm also seeing a bright spot in the corners for the new bulbs, can that be the result of not getting the bulb in the right place behind all fresnels?
                        I also still have the chirping and an unsolved problem.
                        First the chirping. I'm going to try soldering any potential cold joints. But think the output transformer may have a issue. I'm just trying to figure out where to get a replacement, since the 19M088 uses one transformer not two?
                        The unsolved issue: When the monitor goes in to energy saving mode then on wake (by pushing the mouse) the image comes back but the image is shuifted left by 2 inches. On switching to VGA terminal mode and then back to XOrg mode the image shifts back to normal. The image shift doesn't happen with a Dell 1908 monitor. Is that a power issue also?
                        • R_J
                          • 9535
                          Have you tried using the AUTO button? it should auto adjust the screen and store the settings.
                          • bvamunds
                            • Jun 2015
                            • 25
                            The auto button has been used many times and it doesn't affect the image position.
                            • bvamunds
                              • Jun 2015
                              • 25
                              So I ordered replacement caps from Digi-Key for the ones not previously replaced. I didn't want to tear down the monitor so relied on a listing from another site of the size for the caps and the Delta DAC 19M008 schematic parts list. The DAC 19M008 was built with 220uf 25v caps for c200, ce101 and ce108. But the same capacitors on the DAC 19M009 are all 330uf 25v as found when I removed the board.
                              So I need a little help. Can I use the 220uf or do I need to re-order to the 330uf caps?
                              These caps are all part of the power supply, but appear to be used for establishing power voltages. One friend who works more on timers, thought the 220uf would be ok but the ripple of the voltage wouldn't be as clean. Maybe that is one of the improvements Westinghouse requested for this 19M009 PSU compared to ViewSonic and Acer monitors using the 19M008 PSU?
                              Thanks in advance.
                              • CapLeaker
                                Leaking Member
                                • 8116
                                Yes, you can. But it is a short term solution only, since they have to work harder. For me I'd do that in a pinch to get it going until the correct part arrives. In other words, reorder the correct caps and do the work once and right, unless you really have to cheat.
                                • bvamunds
                                  • Jun 2015
                                  • 25
                                  Thanks CapLeaker, I was looking at the 19M008 schematic and see that these caps are involved in the 19V circuit which feeds the hi-voltage circuit for the CCFL's and also with the 13.8 v supply which feeds the video card. One of them is in parallel with 2 1000Uf 25v caps. The one in the hi-voltage circuit actually is controlling the voltage going into the P605's, which might be why they look so overheated. None of the caps look exploded or bulged, but I just thought that age may have taken its toll and they are cheap enough to simply order, and the 220uf's can sit waiting for another project.
                                  PS Seems the 19m008 circuit is exactly the same layout as the 19m009 until you get to handing off the 19V for that circuit, then due to a single transformer the 19m008 circuit deviates from the two transformer 19m009. I wonder the 19m005 is closer for that section?
                                  I'll order the correct parts and do it right once instead of twice. Cheers
                                  • John Graham
                                    • Jun 2024
                                    • 16
                                    Cheers, BrianA_MN
                                    Hi BrianA_MN,
                                    I also have a Delta DAC-19M009. You mention that you changed CE103. Do you by any chance remember the value of the cap? I'm trying to repair my board but the glue that holds CE103 down stripped the value of the cap. All I can read is the voltage (10V). But I can see a 2 (then reading stripped) and F and 25V. The schematic I got for the 19M008 shows a 1KuF 25V. The photo you posted is the exact one I have of my PSU board including the Rev. I know this is an old post, but any help will be appreciated.
                                    Sincerely,
                                    John Graham.
                                    • bvamunds
                                      • Jun 2015
                                      • 25
                                      John, sorry about the delay in responding. I pretty much relied on the repair from a site ccl-la.com, which isn't online now, but I give them credit for creating the original repair.
                                      Check the picture for which capacitor you are trying to repair. The capacitors you need to replace are circled in the picture attached. Use solder braid and remove the bad caps and solder in the replacement caps. Be sure to replace them in the proper polarity, you will see a stripe on the side. The stripe is the negative lead. Just reinsert the new caps with the stripe going the same direction as the old ones come out. The DAC-19M009 and DAC-19M005 are the same, one has the audio and the other does not. The values and part locations are listed here:
                                      220uf 25v – Number 1,3 and 7
                                      1000uf 25v- Number 2 and 5
                                      1000uf 10v- Number 6
                                      2200uf 10v- Number 4
                                      330uf 25v – Number 8
                                      Cheers, BrianA_MN
                                      • John Graham
                                        • Jun 2024
                                        • 16
                                        Cheers, BrianA_MN
                                        Hi BrianA_MN,
                                        Thank you very very much on identifying the capacitor locations.
                                        BTW: I got the capacitor values from https://www.badcaps.net/forum/troubl...-19m009-inside - Post #1 but wasn't sure about the "(2) 25v 1000uF ( one is also on its side)" identified in the post - you just confirmed it.
                                        There are a couple of PSU boards for sale from AliExpress and fpscomponents.com (both are the DAC-19M005 but they don't have the audio section)..
                                        I thought that a PSU replacement with the same (CapXon) caps (which will fail again) would be the easiest (and lazy) way to go (for $18), it beats the de-soldering and re-soldering effort, but I think that I might as well bite the bullet and replace the caps with good caps (Panasonic and/or Rubycon and/or Nichicon). I usually don't remove the residual solder that bridges the thru-holes of components after they are de-soldered, I use a high speed drill (0.5mm to 1mm depending on the component leads - the caps on this board have 0.5mm leads - except for the ripple cap which is 0.85mm) and drill (5000 rpm) out the residual solder which is minuscule. From experience, I find that using solder braid sometimes bridges tracks and I need to use it again. A de-soldering pump works well but the ones I have end up getting their nozzles clogged. Using a bigger nozzle makes positioning the nozzle and the fine tip soldering iron a juggling act.
                                        Thank you again.
                                        Sincerely,
                                        John Graham
                                        • Nicktronic
                                          Westinghouse W55UW4620 No Video
                                          by Nicktronic
                                          Ok, so I know I know, it's a Westinghouse....lol It's got the backlights but no video. Likely the panel, but I'd like to take some measurements on the buffer board with help from you experts to confirm. See the attached pictures. In pic #1, there's a nice pin reference to use to take some measurements. The large IC in pic #7 gets up to 60degC when the TV is on.
                                          So, backlights, no video, go! 🙂...
                                          06-03-2024, 03:21 PM
                                        • EBW
                                          Help Request - Westinghouse 32" Smart TV (Model: WD32HBR105)
                                          by EBW
                                          Westinghouse 32" Smart TV (Model: WD32HBR105) . Originally stuck on logo with no response from remote and no firmware file available to flash via USB. Westinghouse Support stated it would require service but that wasn't a cost effective option. I used dental floss to remove the motherboard processor heatsink to identify what make it was (Mstar). Unfortunately that knowledge didn't help with a solution. After the heatsink removal it only displayed a completely white screen. I then decided to replace the motherboard with a universal 3-in-1 board but the white screen problem continued. This...
                                          10-27-2022, 06:32 PM
                                        • Seville
                                          Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
                                          by Seville
                                          Hello all!
                                          Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
                                          I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
                                          10-10-2022, 07:31 AM
                                        • JayPoorJay
                                          Westinghouse Roku WR58UX4019.To be or not TV,,, That is the Question
                                          by JayPoorJay
                                          Hi All... Me again. Begging for help. The guy who now believes it's possible to fix a TV (one of the millions) one can find on the streets of NYC. I hate hate hate waste...
                                          Thanks to y'all's help I fixed and am happily watching a 70inch Sharp Aquos. Perfect. Learned a lot, replaced LEDs. Pulled screen/panel. Proud.
                                          This is a newer set. It's a Westinghouse Roku WR58UX4019. It was RIGHT outside my place literally, and I couldn't resist. 58in. 500$ new, but I'm not a rich man. So, I want to try.
                                          There is sound. It turns off and on. Screen is black. I can...
                                          03-17-2022, 05:27 PM
                                        • flashcoder
                                          Westinghouse DWM40F1G1 backlight blinks and turns off
                                          by flashcoder
                                          I got this TV (Westinghouse DWM40F1G1) that did not came on one day, blinked for a split second and turned off. I looked at it closer with flashlight and figured that the TV actually works, its just the backlight that does not.
                                          There is one PCB board - all of the components are on it: TP.MS3393.P85
                                          I took my oscilloscope and looked what is coming to the MOSFET that is switching current to LEDs - I could see that the PWM signal comes in but it cuts off almost instantly. I thought its the driver chip OB3350CP and so I replaced it.
                                          After that the...
                                          11-16-2021, 02:12 AM
