Hitachi CM803u
  • Yatti420
    • Mar 2008
    • 130
    Hitachi CM803u
    Hi All,
    I recently inspected a ladies computer and noticed some bad caps.. Recapped the motherboard successfully (it wasn't completely dead just bulging caps) .. Posts and works fine at the moment.. A week ago is when I inspected.. Recapped last night.. Within the week her big Hitachi monitor died out.. I diddn't smell anything at first but when I was working on her computer and set it back down beside her monitor I can definately smell burnt chip or something..
    I opened up the Hitachi but can't see where the burnt chip is etc.. The monitor does power cycle and LED does stay green.. I'm not to sure where to go from here.. I don't really have the tools to diagnose much other than visually..
    Anybody have any experience with these and what board I should be looking at.. Every chip I can see so far looks ok.. There is definitely a burnt smell..
    I have the Hitachi service guide but its like chinese to me.. I don't really understand it.. Even following the troubleshooting diagram.. Any ideas?
    If the lady doesn't want the monitor back ill keep it around and maybe try and break it down and provide further information..
    Yatti
  • Bobdee
    • Jun 2008
    • 461
    Re: Hitachi CM803u
    Originally posted by Yatti420
    Hi All,
    Yatti
    Pictures of both sides of boards are going to be needed
    sounds like inverter problem
    shine a bright torch (flat to screen)when monitor is connected to comp that is up and running, preferably in darkened room (with monitor turned on) to see if you can see faint image of your desktop, this will eliminate mainboard if you see image, this will save time for you and help those who will assist you, there dont seem to be any info on this monitor in forum so pics are a must
    • PlainBill
      • Feb 2009
      • 7034
      Re: Hitachi CM803u
      This is a CRT based monitor.
      PlainBill
      • Yatti420
        • Mar 2008
        • 130
        Re: Hitachi CM803u
        CRT monitor indeed.. Should I still try and see faint image or is that for LCD only etc?
        Yatti
        • Bobdee
          • Jun 2008
          • 461
          Re: Hitachi CM803u
          Yatti
          Ouch, sorry info will not apply.
          Read enough on CRTs to know if not Quallified leave well alone, they dont just burn fingers
          • Toasty
            • Jul 2007
            • 4171
            Re: Hitachi CM803u
            Identical (or nearly) chassis as mine, here: https://www.badcaps.net/forum/showthread.php?t=6733
            That unit is well armored , as you will see when you get the back cover off. TAKE PICTURES! as you go into it so you know how it all goes back together and where the connectors go.
            The back is a full circuit board in itself and is plugged into the mainboard on the bottom via several edge connectors. The trick here is to keep it together enough so you can get to test it, while apart enough to get to items you need to test.
            Provide yourself a LARGE work area that you can work around, as you don't want to have to move this 40 pound monster.
            An isolation transformer is a MUST to work on this set as the whole left side (from back) of the bottom board is mains live. The 2 large caps on lower board (near left and center) need to be discharged with a 10k resistor. They will hold a substantial charge for days. Of course, getting the bottom shield off is a treat in itself. I warned you.
            Once you get it partially disassembled, look for an obvious burnt component(s) that you smelled.
            Be cautious of not damaging or crushing any components near the front edge on the lower board. The clearance is tight and the components are small and fragile there and very little "wiggle room" is afforded you due to cabling and connectors.
            Report back with some pics or findings.
            These were VERY expensive monitors in their day. Mine was over $1,200.
            Toast
            veritas odium parit
            • Yatti420
              • Mar 2008
              • 130
              Re: Hitachi CM803u
              Wow.. Im suprised to see that price.. Thanks for the info toasty.. I haven't really dissembled it much.. Just side panels and roof and took a look at the back.. I can't see the board closest to the back which I think is a big microprocessor (between the back pane and metal backing very small space to try and look).... Everything looks fine.. Powers on clicks and here the degauss like sound.. but no video or picture whatsoever.. Probably just going to reassemble and see what the owner wants to do etc..
              Yatti
              • Toasty
                • Jul 2007
                • 4171
                Re: Hitachi CM803u
                Look for what burned. That's the clue to the failure.
                Shame you're in Ontario...
                Toast
                veritas odium parit
                • Yatti420
                  • Mar 2008
                  • 130
                  Re: Hitachi CM803u
                  Hi toasty,
                  Ya I have been looking.. Still can't seem to find it..
                  Yatti
                  • weirdlookinguy
                    • Sep 2007
                    • 1638
                    Re: Hitachi CM803u
                    What is it about old CRT's taking a shit WHILE WE'RE THERE on service calls?
                    Last month I setting up a wireless repeater for a client, and while I'm configuring it on her old Gateway desktop... the monitor starts making snapping sounds, the picture goes crazy, and the stench of burnt starts wafting out of the monitor. While I was using it. I ended up loaning her a pretty nice Philips I had laying around while she looked for an LCD.
                    It was an 8 year old LG-manufactured monitor with a Gateway badge on it. Had a damn nice picture too before it went.
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      Re: Hitachi CM803u
                      An exactly same kind of monitor blew in front of me yesterday while I was adding two wireless clients on an office (not a service call, just a favor to a friend). He laughs at me because every time I step into his office, some old equipment of him just give up the ghost ..... I just lent him a 19" LCD that I just recently repaired, just as I lent him a wireless router, his dot matrix printer, his fax and some USB memory sticks. Now that I think of it, half of his office is mine, so maybe I'll end up being a firms associate.
                      There are 10 kind of people in this world: those that understand binary, and those who don't.
                      • ASUS ROG Maximus IX Code
                      • Intel Core i5-7600K 3.8GHz
                      • 16gb GSKILL TridentZ RGB DDR4-3200
                      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                      • Windows 10 Pro x64
                      • GeForce GT1050
                        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                      • Toasty
                        • Jul 2007
                        • 4171
                        Re: Hitachi CM803u
                        Nah. Charge him rental fee$$$$$$.
                        Toast
                        veritas odium parit
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          Re: Hitachi CM803u
                          Toast
                          Well, he's a lawyer. I'd rather put my feet on a bucket full of water and then chew on a working, turned on CCFL ... I guess it would be less painful
                          • GeForce GT1050
                            by momaka
                            03-15-2023, 10:17 PM
                          • ant3202
                            HP 27es - LED monitor - Monitor Flashing On - Off
                            by ant3202
                            Hi Everyone
                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                            https://www.badcaps.net/forum/troubl...lashing-on-off
                            The monitor is HP 27es LED Monitor
                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                            The monitor will randomly blackout and display no signal and will recover again.
                            Sometimes need to power and off again to restore the display but...
                            03-20-2025, 07:30 PM
                          • Rick_1234
                            by Rick_1234
                            Good evening, gentlemen.
                            Things I tried
                            06-22-2024, 04:44 PM
                            Wise Wing F199 19'' LCD monitor - recapped
                            by momaka
                            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                            When I saw the Craigslist post, I wasn't...
                            08-24-2020, 10:58 AM
                          • sew333
                            Pc shutdown, monitor flickered with no signal after 10 seconds
                            by sew333
                            My pc:
                            10850K stock 4800mhz stock Kraken X73 good temps
                            2x16 GB DDR4 GSKILL 3000mhz XMP
                            Seasonic Tx-850 Ultra Titanium
                            Gigabyte Rtx 3090 Gaming OC
                            Aorus Z490 Pro Gaming
                            1 TB SSD
                            4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                            Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                            Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                            Power...
                            02-22-2022, 10:27 AM
