Laptop ccfl lamb vs monitor ccfl lamb
  • ahmedsamir
    • Jul 2018
    • 8
    • Egypt
    As I am a beginner, I have a question.
    Comparing laptop ccfl lamb with one pair of wires (red-white) , with pc monitor's ccfl which have two pairs (red-white) , (black-white) wires.
    Could I use the laptop ccfl lamb with one pair of wires instead of the monitor lamb which have two pairs.
    I'm using the laptop lamb only to prevent the protection circuit form Kick in.
    Is the LCD monitor two ccfl pairs are for two lambs ? Or it has two pins for each side, not like the laptop ccfl that has one pin for each side resulting in just two wires not four?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Laptop ccfl lamb vs monitor ccfl lamb
    yes that should work fine
    • ahmedsamir
      • Jul 2018
      • 8
      • Egypt
      Thanks for quick reply,
      So what is the difference between them , laptop lamb and monitor lamb?
      Why the first has just one pair of wires while the latter has two?
      What is the role of each pair of the monitor’s ccfl, if the laptop ccfl works fine with just one pair of wires red-white ?
      • ahmedsamir
        • Jul 2018
        • 8
        • Egypt
        Could I use the laptop 15.6 lamb on the 22inch monitor without a risk.
        If YES , could I use the monitor if that situation works, for operation mode not just for testing?
        Many thanks in advance.
          • 31217
          it will be overdriven and not last long.
          get an led kit instead.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Most 19-24" LCD monitors have 4 lamps: two at the top and two at the bottom - hence 4 sets of wires.
            Meanwhile, laptops usually have only one lamp, and hence only one pair of wires. The color of the wires don't matter. Only that in each set of wires, one is thick and the other is thin. The thick one is the High-Voltage (HV) one and the thin one is usually just return - i.e. close to ground voltage (but not exactly, as it's used for current detection going through the lamps.
            For testing only - yes, maybe.
            As a long term repair - no. (Lamp will be over-driven as stj mentioned and so it would not last long.)
              by momaka
              03-15-2023, 10:17 PM
            • DanPoka
              Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
              by DanPoka
              I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
              Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
              This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
              02-15-2025, 05:05 AM
            • wattage
              AOC AG493UCX 49-inch monitor - Firmware request
              by wattage
              Hello Badcaps Community,
              The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
              07-13-2025, 04:41 PM
            • ant3202
              HP 27es - LED monitor - Monitor Flashing On - Off
              by ant3202
              Hi Everyone
              Lately I am experiencing the deja-vu incident on one of the led monitor like this.
              https://www.badcaps.net/forum/troubl...lashing-on-off
              The monitor is HP 27es LED Monitor
              https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
              The monitor will randomly blackout and display no signal and will recover again.
              Sometimes need to power and off again to restore the display but...
              03-20-2025, 07:30 PM
            • Rick_1234
              LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
              by Rick_1234
              Good evening, gentlemen.
              I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
              To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
              https://drive.google.com/file/d/1L6S...ew?usp=sharing
              Things I tried
              - Bought a new AC adapter thinking that was the problem but the problem...
              06-22-2024, 04:44 PM
