Laptop ccfl lamb vs monitor ccfl lamb
  • ahmedsamir
    • Jul 2018
    • 8
    • Egypt
    As I am a beginner, I have a question.
    Comparing laptop ccfl lamb with one pair of wires (red-white) , with pc monitor's ccfl which have two pairs (red-white) , (black-white) wires.
    Could I use the laptop ccfl lamb with one pair of wires instead of the monitor lamb which have two pairs.
    I'm using the laptop lamb only to prevent the protection circuit form Kick in.
    Is the LCD monitor two ccfl pairs are for two lambs ? Or it has two pins for each side, not like the laptop ccfl that has one pin for each side resulting in just two wires not four?
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Laptop ccfl lamb vs monitor ccfl lamb
    yes that should work fine
    • ahmedsamir
      • Jul 2018
      • 8
      • Egypt
      Thanks for quick reply,
      So what is the difference between them , laptop lamb and monitor lamb?
      Why the first has just one pair of wires while the latter has two?
      What is the role of each pair of the monitor’s ccfl, if the laptop ccfl works fine with just one pair of wires red-white ?
      • ahmedsamir
        • Jul 2018
        • 8
        • Egypt
        Could I use the laptop 15.6 lamb on the 22inch monitor without a risk.
        If YES , could I use the monitor if that situation works, for operation mode not just for testing?
        Many thanks in advance.
          • 30953
          it will be overdriven and not last long.
          get an led kit instead.
            master hoarder
            • May 2008
            • 12170
            Most 19-24" LCD monitors have 4 lamps: two at the top and two at the bottom - hence 4 sets of wires.
            Meanwhile, laptops usually have only one lamp, and hence only one pair of wires. The color of the wires don't matter. Only that in each set of wires, one is thick and the other is thin. The thick one is the High-Voltage (HV) one and the thin one is usually just return - i.e. close to ground voltage (but not exactly, as it's used for current detection going through the lamps.
            For testing only - yes, maybe.
            As a long term repair - no. (Lamp will be over-driven as stj mentioned and so it would not last long.)
              by momaka
              03-15-2023, 10:17 PM
            • DanPoka
              by DanPoka
              02-15-2025, 05:05 AM
            • ant3202
              HP 27es - LED monitor - Monitor Flashing On - Off
              by ant3202
              Hi Everyone
              Lately I am experiencing the deja-vu incident on one of the led monitor like this.
              https://www.badcaps.net/forum/troubl...lashing-on-off
              The monitor is HP 27es LED Monitor
              https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
              The monitor will randomly blackout and display no signal and will recover again.
              Sometimes need to power and off again to restore the display but...
              03-20-2025, 07:30 PM
            • Rick_1234
              by Rick_1234
              Good evening, gentlemen.
              Things I tried
              06-22-2024, 04:44 PM
              Wise Wing F199 19'' LCD monitor - recapped
              by momaka
              Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
              I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
              When I saw the Craigslist post, I wasn't...
              08-24-2020, 10:58 AM
