Samsung Syncmaster 225BW
  • selldoor
    Slow Learner
    • 7870
    #601
    Re: Samsung Syncmaster 225BW
    Power off - do this test
    https://www.badcaps.net/forum/showpo...&postcount=128
    • jlk69
      Fix stuff
      • Nov 2009
      • 22
      OK did the test. Check out the files attached. Rar files have video files in them. When I first put probe on yellow contacts my readings were 1.7.X.X then started dropping slowly but then stabilized at around 1.3.x.x. The same happened with red contacts but readings started at 1.6.xx then dropped and stabilized around 1.2.8.0. Further readings looked like what you see in the videos (1.3.xx then dropping a little then stabilizing).
      I fix therefore I am.
      • selldoor
        Slow Learner
        • 7870
        #603
        Just the figures would do - they seem to be within 3% so ok.
        (never seen dots between each digit before.)
        You need to examine the ends of the ccls for burning/bad wiring.
        Do you have a spare bulb in another monitor or can you make one of these.
        https://www.badcaps.net/forum/showthread.php?t=19987
        • retiredcaps
          • Apr 2010
          • 9271
          #604
          @selldoor re the decimal point
          http://www.eevblog.com/forum/chat/re...900/#msg172900
          http://www.eevblog.com/forum/chat/re...909/#msg172909
          http://www.eevblog.com/forum/chat/re...979/#msg172979
          --- begin sig file ---
          --- end sig file ---
          • selldoor
            Slow Learner
            • 7870
            #605
            Hmm that could be interesting then. - perhaps OP should start on fixing his meter?
            • jlk69
              Fix stuff
              • Nov 2009
              • 22
              I only have 1 other LCD monitor but it is the one i am using right now a Viewsonic VA903b. Will try to set up something to test. I looked at where the ends of the ccls but have not disassembled any more. Is it easy to take out the ccls.
              • selldoor
                Slow Learner
                • 7870
                #607
                Not easy - they get very brittle but initial test is just by plugging something into the socket on the powersupply to see if one bulb or the wiring is causing a problem.
                As it is difficult to tell from the quick flash what bulbs are lit, another thing you could try is you disconnect all but one ccfl lead and see if it flashes then unplug lead 1 and plug in lead two and see if that flashes and so on.
                CARE - High Voltage 1200v - machine should be off when plugging /unplugging
                • jlk69
                  Fix stuff
                  • Nov 2009
                  • 22
                  OK, made a test lamp. I tried out on monitor with everything plugged in including the 3 other CCFL's. Lamp lit up for a few seconds then shut off. I tried this test with all 4 of the sockets and got similar results. I started with cn5 socket then did cn6 then cn4 and finally cn3. Each time the lamp stayed lit for a shorter amount of time. Did I do the test correctly? Should I make up another test lamp?
                    I would make one more test lamp since there is possibility of having two bad lamps.
                    • jlk69
                      Fix stuff
                      • Nov 2009
                      • 22
                      Made a second test lamp. The first few tests the lamps would stay on for a while but would flicker and a buzzing sound was coming from something but I could not figure out exactly which component. After trying several different combinations I only get a short flicker from bulbs when power is applied. Not sure where to go from here. Video of part of the test when stayed lit for a while.
                        That second big lamp is too big and it is trying to draw more current from the circuits, you need to make one more curly lamp.
                        • jlk69
                          Fix stuff
                          • Nov 2009
                          • 22
                          OK, set up 2 small test lamps (the exact same 13 watt bulb). Did tests again. The lights always go out after 10-15 seconds max. Some time they only flicker. What does this mean? Seams to me that the CCFL lamps are good on my monitor. Is this a correct assumption? Please advise what the next test I should perform.
                            So the way you test it, you put two test lamps in two lamp sockets (other two sockets have the LCD's panel lamps attached) that are sitting next to each other then turn on the monitor with having hooking up to running PC, then it goes out after 10~15 seconds? Then you move the two test lamps to the other two sockets instead, and the LCD's panel lamps attached to the two sockets that had the test lamps attached, turn on the monitor with having the running PC, then it also goes out after 10~15 seconds.
                            Lamps turning off after 10~15 seconds sounds like the monitor goes into standby mode due to no video signal detected.
                            • jlk69
                              Fix stuff
                              • Nov 2009
                              • 22
                              Well after several tests I got the lamps to stay on for a while after hooking it up to VGA port by itself. First couple of times lamps only stayed like a few seconds. Both test lamps and display are flickering badly. Several minutes have now passed with lamps still on. I can see dim image on screen. Lamps went out after maybe 10 minutes but can still see image on screen with bright light on.
                              • selldoor
                                Slow Learner
                                • 7870
                                #615
                                Is that 10 minutes with its own lamps lit or both/one of the test lamps. Have you narrowed it down to just one or two faulty ccfls. I think you should just run the test for a minute or two at a time.
                                • jlk69
                                  Fix stuff
                                  • Nov 2009
                                  • 22
                                  That was with both test lamps on one side. Additional test show lamps turning off after a few seconds. According to the guide there are more tests to run but I don't know the location of the components.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #617
                                    OK so now you have a pair of bulbs that stay on -yes?
                                    So on the other pair use just one test lamp and one bulb
                                    and then one test lamp and the other bulb, to try and narrow it down further.
                                    Can you tell on the panel where the bulbs that light are - top/ bottom
                                    one side or whatever.
                                    Until it is established whether the bulbs and transformers are good
                                    there is no point doing other tests yet.
                                    • jlk69
                                      Fix stuff
                                      • Nov 2009
                                      • 22
                                      No, test lamps lit for 10 min then shut off on one test only. After that lamps went out on all tests after a few seconds.
                                      • S0und
                                        • Sep 2012
                                        • 4
                                        • Hungary
                                        #619
                                        I got a quick question, it's kinda stupid/obvious tho.
                                        How important is the Life Time @ Temperature when i choose a cap? Should i go for 10k hour one? My friend told me that it's not that important.
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #620
                                          If it is placed where it getting hot Temp is critical.
                                          Lifetime usually suggests a good cap.
                                          I dont know what is available in Hungary - try to stick to leading brands - panasonic
                                          rubycon- nichicon- There is lots or info on here re series or look at what brands
                                          /series are sold on the forum owners site
                                          https://www.badcaps.net/kits/ then look at full stock.
                                          Care if buying on ebay - lots of fakes about.
                                          EDIT
                                          I see you have posted similar before - the list you gave panasonic FM and FC are good for the purpose
                                          Just check the physical size is ok.
                                          • nh2
                                            Samsung SyncMaster 215TW buzzing / lightning in power board socket
                                            by nh2
                                            This is my first post here. I just fixed my first 2 broken displays by replacing broken capacitors (Samsung SyncMaster 226BW, and Samsung SyncMaster 213T). But I have a third one I'm unable to fix, and am eager to fix as well:
                                            My Samsung SyncMaster 215TW makes a buzzing / hissing sound when turned on.
                                            The sound is louder the brighter the monitor is, e.g. in the "Game" preset is is even louder than in a softer preset.
                                            Opening up the monitor and unplugging the small socket cables that run from the power board to the LCD, I can see a small blue...
                                            08-31-2021, 02:23 AM
                                          • Gau_saha
                                            Troubleshooting samsung syncmaster 2333 BN44-00297A schematic
                                            by Gau_saha
                                            Sir,
                                            Do anybody have IP4L23D CODE BN44-00297A schematic of samsung monitor ? I need the schematic .Please share with me if anybody have it.
                                            Thanks.
                                            i
                                            10-04-2023, 04:47 AM
                                          • rattlesnake
                                            Samsung SyncMaster 955DF dim image fix
                                            by rattlesnake
                                            This display looks a bit dim but the image is otherwise fine. I already set the contrast to 100 and the brightness to 50 (more than that is counterproductive, it becomes hazy).
                                            To enable extra tuning, I have to enable the "Highlight Zone" function and stretch it to full screen. That way it looks really bright/intense and really good! I wish I could set it permanently like this, but as soon as you change the display mode/resolution or you turn the monitor off, you lose the "Highlight zone" config and you have to manuallly activate it again. Also, the manual says...
                                            08-12-2023, 07:03 PM
                                          • dreyjey1993
                                            Samsung Syncmaster S23A550H flicker, no input
                                            by dreyjey1993
                                            Hello all together,
                                            I have been having a problem with my Samsung Syncmaster S23A550H monitor for some time now. It first started with flickering errors when moving the mouse in the left margin (in 10% of the width from the left approximately) and ended with the monitor not recognizing either an HDMI signal, or a DVI signal. Before no more signal was detected, the flickering (horizontal lines across the entire screen) has gotten worse. Since I have the same monitor a second time, I naturally tested the power cord of the other monitor on it. The error remained unchanged. Another...
                                            01-22-2022, 08:00 AM
                                          • jason123
                                            Samsung SyncMaster T24B350
                                            by jason123
                                            Hello there,
                                            I had this TV for years plugged in connected to an old xBox. Went to turn it on today, and I noticed standby light is off, and not turning on.
                                            Opened it to find the Corner Cap (for 5V standby I believe) is bulging and replaced it. Still no standby light. won't turn on
                                            Measured voltages going to the main board, and with the connected to the main board in place, the 5V, PS_On, and 13 V pins were jumping all over the place. When I disconnect the cable to main board, the 5V reads 5.2V, the 13 V, reads 11.8V, and the PS_ON is 3.12 V and the backlight...
                                            10-14-2023, 06:21 PM
