Samsung Syncmaster 225BW
+ More Options
Posts
  • retiredcaps
    • Apr 2010
    • 9271
    #521
    Re: Samsung Syncmaster 225BW
    Originally posted by nmjwolf
    that stamping is real hard to read...from what I can make out it is 64GN T005322p.
    I'm not having luck finding such a part?
    Can you clean up the chip with a bit of isopropyl alcohol and try reading it again?
    Do you have a magnifying glass or jewelers loupe?
    Or use a camera with a good macro mode?
    Meter is just a fluke 87.
    I'm jealous.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      #522
      In this same megathread, this picture
      https://www.badcaps.net/forum/attach...3&d=1260133724
      shows 3 lines of letters. I think I can make out OZ964. See if yours is the same. Or it could OZ9938.
      • nmjwolf
        • Jan 2012
        • 17
        #523
        Got some better light here are the details:
        OZ964CN
        T01053 2P
        0633C
        • retiredcaps
          • Apr 2010
          • 9271
          #524
          OZ964CN
          OZ964 is the pwm chip. Datasheet is at
          http://pdf1.alldatasheet.com/datashe...TC2/OZ964.html
          Refer to datasheet for pin numbering.
          Pin 5, VDDA, is the supply voltage. Pin 6 is ground. (Page 2).
          Measure the DC voltage on pin 5 using pin 6 as ground. The recommended operating range for VDDA is between 4.6V and 5.5V.
          • chez71
            • Jan 2012
            #525
            Originally posted by Konesky
            Hey Chez,
            Sorry it took so long to get back to you. Some of your caps look bad to me from the pictures but it's hard to tell. In the last picture, the ones in the bottom left look bad.
            What you're looking for is for the end of the capacitor to be bulging out a little or even for a brownish (in this case) fluid to be leaking out. It should be noted that even if a capacitor does not exhibit external signs of failure, that doesn't mean it hasn't.
            It's cheaper to order parts from digikey and install them yourself however if you don't have a soldiering iron laying around and you're not completely comfortable replacing them, it may make more sense to order the replacement board off of E-bay and save yourself the trouble.
            Here are some examples to help guide you:
            http://www.instructables.com/id/Fix-...Bad-Capacitor/
            http://www.stevenjohal.com/lcd-scree...wer-no-signal/
            These caps are good:
            Hope that helps, GL!
            -Konesky
            Thank you very much for the info! I think I'm gonna be lazy and just buy a complete new power board because I'm way to busy to learn how to replace caps right now.
            I was planning on buying this power board from eBay as it is the cheapest new one available, however the layout is slightly different and it is marked 225BW Rev 0.2. Will this be compatible with what I have? http://www.ebay.com/itm/New-Samsung-...#ht_3166wt_986
            Thanks again.
            • nmjwolf
              • Jan 2012
              • 17
              #526
              i measure 4.96VDC to gnd.
              • retiredcaps
                • Apr 2010
                • 9271
                #527
                Okay, the pwm is getting power. Now check pin 3 (ENA). According to the datasheet, the IC is enabled when voltage on pin 3 is > 2V.
                Also, pin 15 and 14 have something to do with dimming the ccfls. I'm not sure though what is 100% and what is 0%.
                • nmjwolf
                  • Jan 2012
                  • 17
                  #528
                  4.96vdc chip is enabled
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #529
                    That looks good. What about the DC voltages on pins 14 and 15? Also pin 2 (OVP)?
                    PS. My local ad shows a working 225 BW on sale for $15 (a good price IMHO). If I didn't have working lcds and a few waiting for repair, I would probably buy this.
                    PPS. Well, I knew it wouldn't last, the 225 BW has been sold.
                    • nmjwolf
                      • Jan 2012
                      • 17
                      #530
                      I suppose at this point I should stop being so cheap and buy a set of CCFL's
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #531
                        Well, I personally would like to see the voltages on pins 2, 14, and 15 before you spend any money. If pin 2 comes back with OVP enabled, then you know it is the ccfl OR the wiring is burnt away and not making contact with the ccfl bulb. This is the farthest I have helped someone in this pwm area. I feel like a starting pitcher in the 8th inning and trying to complete the entire game!
                        The pwm IC works as "all or nothing" (in lay terms). Either all the bulbs work or none at all.
                        Sometimes you can find a working monitor (like my example in the above post) for cheaper than a new set of ccfls.
                        • nmjwolf
                          • Jan 2012
                          • 17
                          #532
                          The measurements are:
                          pin 2 0V DC
                          Pin14 2.35V DC
                          pin 15 0V DC
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #533
                            pin 2 0V DC
                            Pin2 (OVP) is not enabled. It would be at 2V if it were.
                            Pin14 2.35V DC
                            pin 15 0V DC
                            For pins 14 and 15, I don't know if that is correct for the brightness or not.
                            Anyway, other than pin 14 and 15, I think most of the electronic components on the inverter board are functioning. That leaves you to check the ccfls.
                            • nmjwolf
                              • Jan 2012
                              • 17
                              #534
                              Datasheet shows OVP going into the fault protection logic...so I assume if this is 0V then that part of the circuit is not enabled...ie chip is not faulted.
                              Thanks for your help.
                              • Konesky
                                • Jul 2010
                                • 7
                                #535
                                Thanks again.
                                It looks similar but there is just no way for me to tell. I suspect the different revisions are compatible but I cannot confirm that so perhaps for the sake of a couple bucks, you may want to match it with your current revision. Good luck!
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #536
                                  Sorry, my wording is a bit confusing.
                                  From reading the datasheet, if OVP were "tripped", it would be around 2V DC. Since it is 0V, my interpretation is that OVP is not "tripped".
                                  • nmjwolf
                                    • Jan 2012
                                    • 17
                                    #537
                                    my interpretation as well. CCFL's it is.
                                    I appreciate your help.
                                    • Konesky
                                      • Jul 2010
                                      • 7
                                      #538
                                      I received my replacement power board from china (e-bay purchase referenced above) and it doesn't seem to power the backlights at all. I haven't had time to play with it, just plugged it in quickly to see if it would work but alas no luck.
                                      Are there any known issues/differences between Rev 1 and Rev 2 boards? I'm replacing a Rev 1 with a 2.
                                      More info: this particular monitor had the caps replaced 2 years ago. Lately it started flickering. To isolate the problem, I swapped a known working powerboard out of another of my 225BW's and it corrected the problem. This tells me it was a problem on the board.
                                      I plopped a replacement board in, hit power and I get nothing on the screen, it doesn't even fire up for a second displaying the Analog/Digital box in the top left. I haven't had time to look close enough to see if there is a picture on the LCD using a flashlight, more later on that.
                                      The power button lights blue, no image comes, the power button then goes to blinking blue.
                                      I'll investigate further but off the top of your head (Bill or others) do you know of any material differences between the revisions of the boards and if they are compatible with each other?
                                      With the board installed,
                                      • termit
                                        • Feb 2012
                                        #539
                                        do u know what size of ccfls do i need? or where can i get CCFL LAMPS FULL ASSEMBLIES for Samsung Syncmaster 225BW?
                                        • jetadm123
                                          • 2169
                                          #540
                                          Try ccflwarehouse.com. Email them if you can't find what you're looking for. They're very helpful.
                                            09-07-2024, 05:50 AM
                                          • soopacrucial
                                            Samsung Syncmaster 740BF repair
                                            by soopacrucial
                                            Hi folks,
                                            I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                                            Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                                            10-29-2024, 02:40 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
