HP LCD 2009F No Power Almost Done. but After 15 mins Backjob Always Short this Diode
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    Good Day to All Forum mates
    I have HP LCD 2009F No power.
    I trace the Problem i found D587 here the Image
    Credit to armand666 Picture
    i Edit and i Marking Arrow
    I replace Already. i test for Burn-test. after 15 mins. turning off the no power Again.
    i have a Stock these diode SR520. i Installed a New one. After a 30 mins Turn Off Again Same Problem.
    Any One can help Me to trace the this and Why Diode Always Broken.
    Update.
    i Experiment Put and installed SP1060.
    3 pin Diode
    also Broken Around 1 hour.
    Pin 1-2 Shorted
    Pin 3-2 Good.
    TIA
    Re: HP LCD 2009F No Power Almost Done. but After 15 mins Backjob Always Short this Di
    What is the ORIGINAL diode P/N?
    We need to pictures of the whole Bottom side of the board too.
    BTW, those two diodes look to be connected in parallel, so only ONE of them failed?
    • R_J
      • 9561
      I checked a different picture and they are in parellel, likely the other diode is damaged.
      I would try something like SB560
      Voltage seems low on SR520
      • lorins_core
        BlackSmith
        • Dec 2012
        • 551
        • Philippines
        Q: no1. What is the ORIGINAL diode P/N?
        A: it is 2 pcs of SR520
        Wait i captured again.
        Anyway I have A question for now. way D857 Always Short if i Install new and Good SR520 Diode?
        • lorins_core
          BlackSmith
          • Dec 2012
          • 551
          • Philippines
          i Update...
          I replaced the both Diode
          For now I try to Installed SP1060 diode
          Oh yes. have already Power up But only 3 Hours Used Only same Problem.
          Backjob....
          Pin 1-2 Shorted
          Pin 2-3 Ok
          Here's the Data Sheed of Diode : https://cdn.badcaps-static.com/pdfs/...241e775e6b.pdf
          • lorins_core
            BlackSmith
            • Dec 2012
            • 551
            • Philippines
            Originally posted by lorins_core
            i Update...
            Backjob....
            Pin 1-2 Shorted
            Pin 2-3 Ok
            Here's the Data Sheet of Diode : https://cdn.badcaps-static.com/pdfs/...241e775e6b.pdf
              Did the diode get very hot after running for a while before it failed in shorted out mode?
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                From the silkscreen on the board, you can see these two parallel diodes are installed in a spot where there was supposed to be a heatsink with a TO-220 rectifier mounted on it. If I had to guess, the manufacturer probably cheaped-out on the design and used the SR520 diodes, which may not be adequate, and over time, as components age, there may be something that is killing them.
                Make sure the output caps are good - if you have a capacitance + ESR meter, pull them out and check them. Otherwise, replacing them with new (good Japanese quality ones) might be the only safer way to go.
                Next check the resistor and ceramic capacitor right next to those SB520 diodes - I think this should be the low-side (output) snubber network (please upload a picture of the solder-side of the board so that we can check). If if is, and that ceramic cap is leaky, that could well be the reason why those diodes are blowing.
                Speaking of the SB520 diodes... their reverse (blocking) voltage rating (20V DC) seems really really low. I suggest going with 45V or higher rated Schottky diodes. Better yet, remove those SB520 diodes and grab something like a MBR2045CT, MBR2060CT, or BYQ28E (TO-220 rectifier) to put in place of them. Really, any 10-20 Amp schottky rectifier with a 45V or higher rating would be recommended here. If you have a small piece of aluminum to make a heatsink for the TO-220 part, that would be even better.
                Lastly, check the output voltage of the PSU once you get it fixed again, to make sure it is what it should be.
                • lorins_core
                  BlackSmith
                  • Dec 2012
                  • 551
                  • Philippines
                  Thanks For Advice Master. I ll try later.
                  • asr
                    Finding replacement diode iPad Pro 3rd gen A1701
                    by asr
                    Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                    Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                    07-09-2024, 06:24 PM
                  • unimatrix93
                    TV backlight zener diode
                    by unimatrix93
                    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                    The led strips has 9 6V leds.
                    02-10-2025, 12:13 PM
                  • NicRac
                    monowheel repair,Is the diode the problem?
                    by NicRac
                    Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                    First of all, I am new here. Therefore I will shortly introduce myself.
                    I am Nico and currently I study Physics.
                    In my freetime I like to build and repair stuff. Especially big battery's.
                    A few years ago I got myself an electric unicycle, monowheel or however you call that.
                    The battery bms was broken so I replaced and resolder that. Nothing big.
                    I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                    07-26-2024, 06:13 AM
                  • dennis_elx33
                    NO BODY MARKING Diode
                    by dennis_elx33
                    Hello Everyone,
                    I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
                    While compared to the reading of another diode from the next channel it won't read at reverse bias.
                    Now the problem is; it does not have any body marking.
                    So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
                    What do you think is this diode?
                    Can you please suggest what part number can i use to replace this faulty diode instead?
                    Hoping that you...
                    06-14-2024, 12:36 AM
                  • eccerr0r
                    Electric lawnmower...purpose of diode...
                    by eccerr0r
                    I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
                    The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and...
                    08-27-2022, 12:54 PM
