Aoc n20wb
    Re: Aoc n20wb
    Originally posted by ronhayes
    MOSFET P/N are 4502c AA8 GAR.
    Yes the tester can test all four ,So i connected all four but i only used it on its lower volts
    Backlights came on and stayed on.
    What I am trying to find out is how your tester function if you only has one lamp connected. Will it still light up the lamp when only ONE lamp is connected?
    So did you check the resistance between S and D pins of the MOSFET?
    AF4502 MOSFET.
      Re: Aoc n20wb
      budm what was your thoughts on post 11 good or bad? as i couldnt find any specs on the transformer
      I think his reading of 0.46 Ohm may be an error for the high Voltage winding, may be it is 0.46K Ohms?
      • ronhayes
        TV Engineer
        • Mar 2014
        • 458
        Re: Aoc n20wb
        Hi budm
        any more info on these mosfets ?
        • ronhayes
          TV Engineer
          • Mar 2014
          • 458
          Re: Aoc n20wb
          I have connected the backlights to tester one at a time and all light up and stay on .
          The resistance is 0.46k ohms
          the resistance between pin 1 and 7&8 on both mosfets checked in the 200k range.
          If you put the red lead on pin 1 and the black lead on pins 7/8 you get 21,7k but if you reverse the leads i:e black lead on pin 1 and red lead on pins 7/8 the resistance slowly rises to 55.7k.
            Re: Aoc n20wb
            So your tester does not have protection circuit for open connection, the inverter circuit in the monitor will go into shutdown if any one of the lamps is bad or not connected, your tester will keep on driving the lamp and stay on even though only lamp is being tested.
            I cannot find the spec for the transformer either, so 460 Ohms may be or may be not normal.
            The MOSFET did show shorts between S and D so they may be OK since all we can test is the resistance not full function testing.
            • ronhayes
              TV Engineer
              • Mar 2014
              • 458
              Re: Aoc n20wb
              So does this point to the transformer being at fault ?
                Re: Aoc n20wb
                I do not know, may be it should be removed and inspect the bottom side to see if it has any burn sign or not.
                • ronhayes
                  TV Engineer
                  • Mar 2014
                  • 458
                  Re: Aoc n20wb
                  Here is a picture of the transformer removed it looks ok to me i can't see any burn marks ?
                    Re: Aoc n20wb
                    It does look OK.
                    • ronhayes
                      TV Engineer
                      • Mar 2014
                      • 458
                      Re: Aoc n20wb
                      It measures the same out of circuit ?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #31
                        Re: Aoc n20wb
                        Originally posted by budm
                        It does look OK.
                        budm do you think ron could use one of these if needed and will it be easy to find the connection points for the wiring?
                        https://www.ebay.co.uk/itm/Universal...wAAOSwu4BVu1OW
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #32
                          Re: Aoc n20wb
                          ron when you first turn the monitor on do you get a quick flash of backlight like the 2 second too black fault
                          • ronhayes
                            TV Engineer
                            • Mar 2014
                            • 458
                            Re: Aoc n20wb
                            Yes Vince it does.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #34
                              Re: Aoc n20wb
                              that a lot of the time does mean a faulty ccfl or transformer, whats the best price you can get a replacement transformer for? also i use a old ccfl tube with connector on the end out of another old monitor/laptop and just plug it into one of the connectors on the psu too test for a faulty ccfl if then my temporary tube plus the monitors back lights stay on it proves the one tube i have disconnected is faulty inside the lcd assembly if that make sense.
                              • ronhayes
                                TV Engineer
                                • Mar 2014
                                • 458
                                Re: Aoc n20wb
                                Yes that does make sense .
                                But unfortunately i do not have a used ccfl tube that i can use ? I think the transformer is maybe ok and that it is probably more likely to be one of the cclf tubes ?
                                I think i read some where that you can use a old energy saving bulb or something like that ?
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  Re: Aoc n20wb
                                  yes budm posted a sticky on top of one of the threads i will see if i can find it
                                  here it is
                                  https://www.badcaps.net/forum/showthread.php?t=19987
                                  • ronhayes
                                    TV Engineer
                                    • Mar 2014
                                    • 458
                                    Re: Aoc n20wb
                                    I do have a tube that is in my magnifying glass would this do? it takes four 1,5v batteries to power it?
                                    • ronhayes
                                      TV Engineer
                                      • Mar 2014
                                      • 458
                                      Re: Aoc n20wb
                                      There are no markings on it but it shows in that link a update using a T5 similar to this ?
                                      • ronhayes
                                        TV Engineer
                                        • Mar 2014
                                        • 458
                                        Re: Aoc n20wb
                                        If this would be ok how do you connect it ? It looks like he has connected the wires on the crock clips and each crock clip connects to the two prongs at each end of the tube is that correct ?
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #40
                                          Re: Aoc n20wb
                                          ron i sent the transformer seller on ebay a message asking if the knew the the winding readings this was there answer and bear with me ron once back at home i will look and see if i have some spare test ccfl tubes with leads/connectors if so i will post you one as these was free to me anyway out of cracked screen sets.
                                          Hi. Primary resistence around 0.7 to 1.0 . Secondary resistence around 600 ohm i dont know if budm will cofirm if this sounds right as this was from the Chinese seller
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
                                          • ant3202
                                            HP 27es - LED monitor - Monitor Flashing On - Off
                                            by ant3202
                                            Hi Everyone
                                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                            https://www.badcaps.net/forum/troubl...lashing-on-off
                                            The monitor is HP 27es LED Monitor
                                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                            The monitor will randomly blackout and display no signal and will recover again.
                                            Sometimes need to power and off again to restore the display but...
                                            03-20-2025, 07:30 PM
                                            Wise Wing F199 19'' LCD monitor - recapped
                                            by momaka
                                            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                            When I saw the Craigslist post, I wasn't...
                                            08-24-2020, 10:58 AM
                                          • sew333
                                            Pc shutdown, monitor flickered with no signal after 10 seconds
                                            by sew333
                                            My pc:
                                            10850K stock 4800mhz stock Kraken X73 good temps
                                            2x16 GB DDR4 GSKILL 3000mhz XMP
                                            Seasonic Tx-850 Ultra Titanium
                                            Gigabyte Rtx 3090 Gaming OC
                                            Aorus Z490 Pro Gaming
                                            1 TB SSD
                                            4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                            Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                            Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                            Power...
                                            02-22-2022, 10:27 AM
                                          • triplefour
                                            TCL 75S421 has sound but no backlight not even a flash
                                            by triplefour
                                            TCL 75S421
                                            PSU BOARD: 40-L402H8-PWD1CG
                                            it shows not even a flash of backlight when powering up.
                                            but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                            testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                            unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                            i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                            with mb connected, PSON...
                                            11-17-2023, 09:54 PM
