Aoc n20wb
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Aoc n20wb
I have connected the backlights to tester one at a time and all light up and stay on .
The resistance is 0.46k ohms
the resistance between pin 1 and 7&8 on both mosfets checked in the 200k range.
If you put the red lead on pin 1 and the black lead on pins 7/8 you get 21,7k but if you reverse the leads i:e black lead on pin 1 and red lead on pins 7/8 the resistance slowly rises to 55.7k.Comment
Re: Aoc n20wb
I cannot find the spec for the transformer either, so 460 Ohms may be or may be not normal.
The MOSFET did show shorts between S and D so they may be OK since all we can test is the resistance not full function testing.Never stop learning
Re: Aoc n20wb
I do not know, may be it should be removed and inspect the bottom side to see if it has any burn sign or not.Never stop learning
Re: Aoc n20wb
It does look OK.Never stop learning
Re: Aoc n20wb
budm do you think ron could use one of these if needed and will it be easy to find the connection points for the wiring?
https://www.ebay.co.uk/itm/Universal...wAAOSwu4BVu1OWComment
Re: Aoc n20wb
that a lot of the time does mean a faulty ccfl or transformer, whats the best price you can get a replacement transformer for? also i use a old ccfl tube with connector on the end out of another old monitor/laptop and just plug it into one of the connectors on the psu too test for a faulty ccfl if then my temporary tube plus the monitors back lights stay on it proves the one tube i have disconnected is faulty inside the lcd assembly if that make sense.Comment
Re: Aoc n20wb
Yes that does make sense .
But unfortunately i do not have a used ccfl tube that i can use ? I think the transformer is maybe ok and that it is probably more likely to be one of the cclf tubes ?
I think i read some where that you can use a old energy saving bulb or something like that ?Comment
Re: Aoc n20wb
yes budm posted a sticky on top of one of the threads i will see if i can find it
here it is
https://www.badcaps.net/forum/showthread.php?t=19987Last edited by vinceroger69; 04-08-2018, 06:25 AM.Comment
Re: Aoc n20wb
ron i sent the transformer seller on ebay a message asking if the knew the the winding readings this was there answer and bear with me ron once back at home i will look and see if i have some spare test ccfl tubes with leads/connectors if so i will post you one as these was free to me anyway out of cracked screen sets.
Hi. Primary resistence around 0.7 to 1.0 . Secondary resistence around 600 ohm i dont know if budm will cofirm if this sounds right as this was from the Chinese sellerComment
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM -
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by momakaLooking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
When I saw the Craigslist post, I wasn't...-
by sew333My pc:
10850K stock 4800mhz stock Kraken X73 good temps
2x16 GB DDR4 GSKILL 3000mhz XMP
Seasonic Tx-850 Ultra Titanium
Gigabyte Rtx 3090 Gaming OC
Aorus Z490 Pro Gaming
1 TB SSD
4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
Power... -
by triplefourTCL 75S421
PSU BOARD: 40-L402H8-PWD1CG
it shows not even a flash of backlight when powering up.
but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
with mb connected, PSON... - Loading...
