Issue with Westinghouse 19" LCD Monitor (large pics)
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Issue with Westinghouse 19" LCD Monitor (large pics)
    Originally posted by Welchs101
    Thanks for the info. You might be right. I called the company today and they were still out and did not know when they would be getting any in.
    I did have another question.
    Regarding the MOSFETS:
    I could not find the "40T03GP" in mouser but i did find the following as a replacement. Is the following a good replacement?
    NTP45N06LG (from ON semiconductor.....MOSFETs- Power and Small Signal 60V 45A N-Channel).
    Dave
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=370166175275
    That's where I got replacement MOSFETs for a unit just like mine. I don't know about the fuse, as now that I remember, it is still bridged with solder (something I have to take care of...)
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
    • Welchs101
      • Sep 2008
      • 979
      Ok, i have been working on this monitor off and on for some time now.
      Where i am today:
      The fuse F200 KEEPS blowing open when ever i try to turn on the monitor. I have trouble shooted as best i can but i am at a loss as to what to try next.
      I thought about replacing the BIT3713 and someone was kind enough to find a location where i can buy a replacement but i recieved word back from the manufacturer that pin 13 might indeed be gnd so now i am thinking its not the BIT3713.
      Since i cant buy a replacement board DAC-19M005 i am stuck trying to fix this board again. As i said above i am not sure what to do next. The only thing i can think of is shorting out the fuse F200 and touching components to see if they are hot.
      Does anyone else have any ideas? Sorry to keep this thread going so long.
      dave
      • PlainBill
        • Feb 2009
        • 7034
        Where i am today:
        dave
        Way back in the old days we would take a variable power supply, hook it up, then gradually increase the voltage until the current started to increase. If a 2Amp fuse was blowing, we'd raise the voltage until the current reached 2 amps, then Carefully!! feel for something getting warm.
        Another 'trick' was to measure the voltage drop between the power supply and various components pulling power from the supply. The one causing the biggest drop was most likely to be bad. Of course, this was made easier by the fact we had complete schematics, an ample supply of components, and professional reworkers to install them.
        PlainBill
        • Welchs101
          • Sep 2008
          • 979
          Plain Bill,
          Thanks for the tip. Unfortunately i dont have a variable power supply but i still appreciate the tip.
          Dave
          • EGuevarae
            • Nov 2008
            • 1336
            First, install the caps in a more proper way. The long legs increase the ESR or so I've read around here. Have you removed the transformer to check if it is shorted?
            • GeForce GT1050
            • Welchs101
              • Sep 2008
              • 979
              Hi, Thanks for responding.
              I agree that i need to put the caps in "better" but how they are put in now should not cause a short. I put them in this way thinking it was temporary and once i found where the short was located i would put them in correctly.
              Regarding the transformer.
              Not sure if this is technically correct but this is how i tested the transformer.
              Early on i did short out the fuse which keeps blowing and i placed one of the leads of my dvm over / on top of the transformer. With the dvm on frequence measurment i did record a frequency value from the transformer. I know this is not technically correct but i read this technique somewhere and i thought that if the transformer was shorted i would not read a frequency value.
              Does this make sense?
              Dave
              • PlainBill
                • Feb 2009
                • 7034
                I've just received the Acer 19" version of this monitor. So far I've seen 2 bad (vented) caps, a shorted FET, and a blown fuse. Interestingly, my new esr meter says that one of the bad caps still has a low esr.
                What is the value of F200. According to the only chart I could find, that is a 7 amp fuse?
                PlainBill
                • EGuevarae
                  • Nov 2008
                  • 1336
                  PlainBill
                  I've seen that unit too. It's an Acer AL1916W. Same PSU as the unit on this thread and on the L2046NV of a thread I opened. In my case, it was a blown fuse (F200) and two caps (see attached pic). The fuse was replaced by another "F200" from a dead (and almost empty) same model PSU, but I have no data on the fuse's specs.
                  • GeForce GT1050
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    Crapxon strikes again.
                    I'm seeing this more and more two of the inverter transformers in one assembly. As in the board pic above.
                    Is it cheaper to produce them that way or is it just quicker on the assembly line when inserting parts?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      I'd say both. The downside is that you have a slightly higher chance of a manufacturing failure because of the extra winding.
                      Boy, that picture looks familiar!! Right down to the same two caps popping their tops.
                      Has anybody analyzed this circuit? Is this just a case of the caps failing, the high ripple causes the FETs to overheat, and when they short the fuse blows?
                      PlainBill
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        PlainBill
                        A friend of my dad, who is an old school electronics tech, said that very same thing to me after seeing pics I sent him. The caps failure overheat/overwork the MOSFETs, and when they short, the fuse blows to protect the board from more damage.
                        • GeForce GT1050
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Thanks for the confirmation.
                          PlainBill
                          • jepongski
                            • Mar 2009
                            • 3
                            #113
                            i have found something that might be useful about the "Fuse thing" . i dont know if this is the same as the "f200" we're talking..
                            the fuse labeled "M" or "W" is 5A.
                            • jepongski
                              • Mar 2009
                              • 3
                              #114
                              i have overlooked the markings description "M' =4A.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Hmm, note to PlainBill. " Chinese make M that looks like inverted W." 4 Amps is very reasonable; thank you very much.
                                PlainBill
                                • Dgtech
                                  E. Technician
                                  • Apr 2009
                                  • 1462
                                  • Steeler
                                  #116
                                  After viewing this thread plus one other thread on this site, I have concluded that there are too many of these same power supply failures. I bought a Westinghouse monitor cheap from craigslist and it had this failure. So far I've replaced about 9 caps(2 bulged), shorted out the fuse (F200 - on solder side of board), and I will change out the 2 mosfets as soon as they arrive. These posts have been great. Although I'd like to see a schematic of it all, It saved me tons of time researching the posts. I now know that this board is used in many models and brand names :
                                  These are the ones that I know of so far...
                                  Acer
                                  ViewSonic
                                  Westinghouse
                                  No wonder why they want you to buy the extended warranties at electronics stores. The product manufacturers obviously buy the cheaper parts to sell to the customer. Some units last. The ones that dont last either get trashed or fixed by techs or in few cases, get sent back by way of the protection of the limited or extended warranty. In every case, the company makes tons of money!!!
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    Acer
                                    ViewSonic
                                    Westinghouse
                                    I've seen the same PSU/Inverter model in Acer and Westinghouse units personally. Bad MOSFETs, blown fuse on solder side and badcaps in all of them.
                                    • GeForce GT1050
                                    • bcuda
                                      • Jun 2009
                                      • 7
                                      #118
                                      I am new here and to repairing LCD's. I have tinkered with a lot of other things though. Great info here. Thanks in advance!!
                                      I too have a Westinghouse L1975NW with no backlight. But mine has a different board that the original one in this thread. It has two dual Mosfets parts number P605. Also about half of the caps are Capxon and the other half are Taicon. Only 4 of the Capxon are bulged. Should I replace the Taicon caps also or are they okay? Where is the fuse on the solder side you guys are talking about? The main fuse is good as the LCD panel works. I'll replace the mosfet's along with the caps as they look pretty overheated.
                                      I'll try to attach a couple of pics.
                                      Thanks,
                                      Bob
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        Thanks,
                                        Bob
                                        Welcome
                                        Replace all the caps while you are there. For the fuse, post a bigger picture of the underside to see if we can see if any fuse is there.
                                        • GeForce GT1050
                                        • Nama
                                          • May 2009
                                          • 127
                                          #120
                                          your board has crabs.
                                          ^Learning to walk on rice paper without leaving a trace,
                                          • Cuboy
                                            HP probook 4510s mosfet issue
                                            by Cuboy
                                            I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
                                            I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
                                            I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
                                            03-16-2024, 10:29 AM
                                          • ebyte64
                                            Lenovo IdeaPad 330 laptop mosfet issue
                                            by ebyte64
                                            Good day everyone.
                                            I have been scratching my head with a Lenovo laptop I got in today.
                                            The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
                                            Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
                                            Would anyone...
                                            06-27-2023, 10:19 AM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                          • DqMagetz
                                            Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                                            by DqMagetz
                                            Good day!
                                            I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                                            Here are the voltage readings:
                                            • Input – 19V (stable)
                                            • +LCDVDD – 3.3V briefly, then drops to 0V
                                            • EDP_HPD – 3.3V briefly, then drops to 0V
                                            • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                                            • EC BKOFF# – 1.8V briefly, then drops to 0V
                                            • PANEL_OD_EN – 0.3V
                                            Is it possible that the EC chip is corrupted or damag...
                                            07-12-2025, 09:37 PM
                                          • wattage
                                            AOC AG493UCX 49-inch monitor - Firmware request
                                            by wattage
                                            Hello Badcaps Community,
                                            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                            07-13-2025, 04:41 PM
