Issue with Westinghouse 19" LCD Monitor (large pics)
  • retiredcaps
    • Apr 2010
    • 9271
    #281
    Re: Issue with Westinghouse 19" LCD Monitor (large pics)
    Originally posted by spaceman
    I could be wrong, but I'm not quite confident that it would fit. If someone else with more experience says it will, then giddy up, but otherwise, any other ideas?
    Post a clear focused picture of where the 1000uF 25V caps have to go. Post following this instructions.
    https://www.badcaps.net/forum/showthread.php?t=1868
    --- begin sig file ---
    --- end sig file ---
    • alexanna
      • Mar 2010
      • 1346
      #282
      Originally posted by retiredcaps
      Panasonic FM 1000uF 25V series does come in 20mm height. See
      http://ca.mouser.com/ProductDetail/P...wWEhzvqOZDM%3d
      The diameter is 12.5mm. Do you have enough space for the diameter?
      If this power supply is a dac-19m005,The 12.5mm 20 should work fine you might have to lay the small ce101 a little bit to the side.
      I am eye balling this board right now.
      Al
      • spaceman
        • Jan 2009
        • 52
        Not a problem. And although I encourage helping new members, you don't have to worry about me. Though some rules do seem to vary.
        • retiredcaps
          • Apr 2010
          • 9271
          #284
          Wow, I don't think I have ever seen anyone post a picture with a caliper before!!! Good job. I just use a tape measure and eyeball it.
          Anyways, I'm confident that the 12.50 diameter will fit and here is how we will make it fit.
          The left most cap doesn't have to sit 100% flush to the board so you can lean it towards the edge of the board. The cap will work just fine leaning a bit just like the other components on your board.
          The cap at CE101 MAY come in smaller sizes with the correct uF and V. Please list the uF, V, diameter, and height value at CE101. We will try to get a smaller one so that the other cap above can occupy some of it space.
          If there is no smaller cap size for CE101, we can lean the other cap as well.
          • Krankshaft
            • Jan 2007
            • 2328
            While personally recommend against inline pics (attachments are much better) if you must use them resize them properly so we all don't have to side scroll for the entire thread page please. I removed the pics since you had attachments.
            • spaceman
              • Jan 2009
              • 52
              Thanks!! I use it whenever I can...to say I did. heh heh
              The CE101 is 220uF, 25v, and 18mm tall with an 8mm diameter.
              Even though I stated that you don't need to worry about me following forum rules, I still referenced the link that retiredcaps left just to be sure and followed the guidelines. If you feel like I didn't do a good job, I'd appreciate it if you could modify the guide so that there's no problems with future newbies. And do you have javascript disabled? Your Highslide JS was working fine for me for resizing.
              • Krankshaft
                • Jan 2007
                • 2328
                On your pics the resizer wasn't working for some reason. Maybe it was just a browser glitch on my end if so sorry about that.
                It seems that Firefox and Java still have problems playing nice with each other on occasion.
                • spaceman
                  • Jan 2009
                  • 52
                  It seems that Firefox is a bit picky with Java.
                  S'all good. If you find some glitch with some odd combo like firefox, highslide, and say a particular format, please let us know.
                  Otherwise, I'll stick with Opera (shameless plug).
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #289
                    Well, I looked through mouser, digikey, and here and I cannot find anything smaller than the 8mm diameter that is on the approved/recommended list. I found a 6.3 diameter cap, but it is unsuitable for this application.
                    On mouser, they list a Panasonic FC 220uF 25V cap at 6.3mm diameter, but when I looked at the FC datasheet, it looks like Mouser has it entered wrong on their ordering system.
                    Just lean both caps away from each other (CE101 and the one on top) and you should be fine.
                    This youtube video shows someone replacing caps and at the 8 minute mark, you can see he ordered caps too tall and his solution (which I don't recommend).
                    http://www.youtube.com/watch?v=Ul5LhuCT1y8
                    Why he didn't get the right caps to fix such a nice monitor is beyond me.
                    edit: I use opera as well.
                    • spaceman
                      • Jan 2009
                      • 52
                      Sounds like a plan. I just grabbed a few EEUFC1E102's that should hopefully be in next week. Thankfully, my other attempts at cap replacement thus far have worked out, but I got those from the CapKing. I get equivalent capacitance and all, but just why did he use such large ones? Just to act smart?
                      And um, I made a typo in my last post. The 220uF caps are actually 12mm tall. I'll change it to reflect that. Maybe one will come up on a search now.
                      The only project that wasn't a huge success was with a Dell Optiplex SX280 that had overheated the lower caps and that's only because I wasn't satisfied with just replacing them (which went well). I had to be a loser and try to splice a small fan from the hard drive power cable. Well, the splice didn't hold completely and shorted out what I think is a voltage regulator, but that's for another thread.
                      edit: or I guess I won't. I didn't realize that there was an edit deadline here.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #291
                        I searched for diameter previously and there is no cap smaller in diameter than 8mm in a low ESR 105C format. So the difference between 18mm and 12mm doesn't factor in.
                        • spaceman
                          • Jan 2009
                          • 52
                          Good to know. Thank you for looking.
                          • hoadle
                            • Jul 2010
                            • 174
                            #293
                            Here website will help you & follow the steps
                            http://www.ccl-la.com/blog/index.php...repair/#more-3
                            • dabone
                              • Aug 2010
                              • 30
                              #294
                              Ok, I've got a DAC-19M005 from a acer 19" that I've been working on.
                              It had the following bad when I got it.
                              C204 and CE101 were swollen.
                              F200 was open.
                              The 40T03GPs were not shorted, But I was erring on the side of caution and replaced.
                              and I've tried the following.
                              Replaced every cap except for CE107 and CE108.
                              Replaced the transistors with 40T03GP's from ebay.
                              Replaced F200 (Was open) with a fuse from a bad video card, it's labeled 3.
                              The monitor powers on when I plug it in, but give no backlight. The fuse doesn't blow, and the monitor will power on and off correctly.
                              I've checked every fuse I can find, F100, F102 and F200.
                              I've also checked every 0 ohm jumper I could find on the board.
                              I've also tried plugging in a different panel to half the circuit. (I've got a 17" panel with 2 good bulbs, so I would leave 2 of the 19" bulbs in circuit and sub the 2 17" for test), Still no backlight.
                              Any clue what next?
                              Thanks,
                              later,
                              dabone
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #295
                                What model Acer?
                                Does the backlight flash on even briefly? If you shine a flashlight to the screen, can you see the display?
                                Any clue what next?
                                Post clear focused pictures AFTER reading
                                Please do not post pictures inline as they slow down the loading of pages.
                                For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
                                Here is an example of the pictures we want.
                                https://www.badcaps.net/forum/showpo...94&postcount=1
                                After we see pics, we can make more suggestions. So far, good job of eliminating a lot of potential causes.
                                • alexanna
                                  • Mar 2010
                                  • 1346
                                  #296
                                  F200 was open.
                                  Any clue what next?
                                  Thanks,
                                  later,
                                  dabone
                                  try searching for this thread[ Westinghouse L2046NV Mosfet 40T03GP Wanted] by Equevarae.
                                  There are acer and westing house monitors that use this dac-19m005,And there is alot of good information on common problems they are having. there is also annother fuse on back you have not listed it is F101 near the 16 pin connector to the vidio board
                                  Al.
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    Al.
                                    EGuevarae, not eQuevarae. I don't mind, but .....
                                    Back on topic, you say you replaced all the caps, but you did not say with what ....
                                    And I second the "no inline pictures suggestion"
                                    There are 10 kind of people in this world: those that understand binary, and those who don't.
                                    • ASUS ROG Maximus IX Code
                                    • Intel Core i5-7600K 3.8GHz
                                    • 16gb GSKILL TridentZ RGB DDR4-3200
                                    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                                    • Windows 10 Pro x64
                                    • GeForce GT1050
                                      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                                    • spaceman
                                      • Jan 2009
                                      • 52
                                      Okay now, I swapped the caps a little while ago and I guess I just got caught up in using it and forgot to post. Thank you again for your help.
                                      As far as the 12.5mm vs 10mm, you were right and it wasn't a problem. I just had the leave a little more of the leads on there and bent them out of the way.
                                      Also, I found that a three slot letter holder makes a perfect small motherboard holder while soldering. Though I'd make sure that the weight of the board is placed on something sturdy like the power plug.
                                      Now, onto trying to fix a HP dv1000 laptop.
                                      • kahless
                                        • Sep 2010
                                        #299
                                        when the boards keep blowing fuses check the diode and 4 pack of transistors below F200. Q204 shorts between pins frequently and R209 and R210 go out of tolerance and that tanks the whole cluster.
                                        • jetadm123
                                          • 2169
                                          #300
                                          Good info to know. To save my eyesite, would you know offhand what the part number of Q204 is?
                                          • Cuboy
                                            HP probook 4510s mosfet issue
                                            by Cuboy
                                            I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
                                            I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
                                            I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
                                            03-16-2024, 10:29 AM
                                          • ebyte64
                                            Lenovo IdeaPad 330 laptop mosfet issue
                                            by ebyte64
                                            Good day everyone.
                                            I have been scratching my head with a Lenovo laptop I got in today.
                                            The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
                                            Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
                                            Would anyone...
                                            06-27-2023, 10:19 AM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                          • DqMagetz
                                            Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                                            by DqMagetz
                                            Good day!
                                            I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                                            Here are the voltage readings:
                                            • Input – 19V (stable)
                                            • +LCDVDD – 3.3V briefly, then drops to 0V
                                            • EDP_HPD – 3.3V briefly, then drops to 0V
                                            • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                                            • EC BKOFF# – 1.8V briefly, then drops to 0V
                                            • PANEL_OD_EN – 0.3V
                                            Is it possible that the EC chip is corrupted or damag...
                                            07-12-2025, 09:37 PM
                                          • wattage
                                            by wattage
                                            Hello Badcaps Community,
                                            07-13-2025, 04:41 PM
