Issue with Westinghouse 19" LCD Monitor (large pics)
+ More Options
Posts
  • Welchs101
    • Sep 2008
    • 979
    Re: Issue with Westinghouse 19" LCD Monitor (large pics)
    gfray,
    so i dont get threads confused. The power mosfets that were in my westinghouse board are now in the acer board (see this thread for measurement results).
    https://www.badcaps.net/forum/showth...632#post100632
    Currently there are "no" power mosfets in the westinghouse board. I took them out to try and trouble shoot the other board.
    • gfgray
      • Jul 2009
      • 15
      #222
      The FETs won't have to be in circuit to check for this short. Put one probe on the through hole for the gate of FET 1. Put the second probe on the through hole for the gate of FET 2. Is it zero resistance? Does it form a diode in either direction?
      Also, are you sure the caps are correctly polarized?
      • Welchs101
        • Sep 2008
        • 979
        see the link mentioned in previous post for measurements.
        Yes, i have double and triple check polarity of caps that i replaced.
        • rwikst
          • Apr 2010
          #224
          I'd like to thank you all for the information. I have the same Westinghouse 19 LCD. The power supply is slightly different, newer I guess. The part number was the same except it is a newer version (different caps with large heat sinks on the MOSFETs). I replaced all 4 caps on the board and plugged it in and back to life it came. Thanks to all of your info.
          • Wolfman
            • May 2010
            • 6
            #225
            Hey there. I came across this forum when I took the same monitor from a family member to see what was wrong with it. I can tell that the caps are bad as 3 of the caps are raised (blown). My simple question is this. I have never soldered before but can get my hands on a soldering iron. So with being a newb at this would it be better for me to buy the caps and attempt to fix the issue that way or to just buy a new board from Discount-Merchant? It would take about 4-6 weeks to get it from them. The only issue with that would be that it would still have the same CapXon caps.
            I believe the caps would cost be about $10 and the entire board from DM would cost $35+shipping!
            • retiredcaps
              • Apr 2010
              • 9271
              #226
              I was in your shoes about 1 month ago having never soldered and now I have repaired 5 monitors and counting.
              If you can borrow the iron, 3 caps will definitely cost less than $5 if you can get them locally or via online reseller.
              Just watch some youtube videos on how to solder. My favourite is (you don't have to buy the HD version)
              http://www.youtube.com/watch?v=I_NU2ruzyc4
              AND you get the satisfaction of fixing something.
              PS. Make sure you get the polarity correct when replacing caps.
              --- begin sig file ---
              --- end sig file ---
              • Wolfman
                • May 2010
                • 6
                #227
                Thanks! I will give it a shot. I just ordered the caps. Had to find replacements for the 470uf that were out of stock. I will post the results...been sitting on this for over a month now!
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #228
                  What brand caps did you order? Did you ensure the size fits your monitor since they come in different diameters and heights?
                  • Wolfman
                    • May 2010
                    • 6
                    #229
                    I ordered the caps previously mentioned on here by someone with the same board as mine.
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      Post back the results, my friend.
                      There are 10 kind of people in this world: those that understand binary, and those who don't.
                      • ASUS ROG Maximus IX Code
                      • Intel Core i5-7600K 3.8GHz
                      • 16gb GSKILL TridentZ RGB DDR4-3200
                      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                      • Windows 10 Pro x64
                      • GeForce GT1050
                        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                      • Wolfman
                        • May 2010
                        • 6
                        #231
                        i definitely will. The CAPs are on their way so I will work on it next week and let you know!
                        • r00t4rd3d
                          • Jun 2010
                          • 5
                          #232
                          Hey guys , new here but I have the same problem with my Westinghouse LV2046.
                          I found a guy on ebay that sells replacement boards for the DAC-19M005 :
                          http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
                          $45 bucks with free shipping is worth a shot to get my $350 monitor going again !
                          I have nothing to do with the seller but this might help the other soldering challenged people
                          I ordered one and it will be here tomorrow. Took 6 days from China to New York
                          Ill post back and let everyone know if it works. I have one small concern though. My power board has no audio , the replacement one does. Not sure if I have to remove that stuff or if I can just leave it.
                          • lucky13
                            • Aug 2007
                            • 412
                            #233
                            r00t4rd3d
                            It is probably OK if you leave the audio section on but you may have to unsolder the green jack so it does not interfere with the mounting.
                            I have seen this type of board has many versions. Just check if those pin headers on the right line up the same distance as yours.
                            • lucky13
                              • Aug 2007
                              • 412
                              #234
                              r00t4rd3d,
                              Why don't you try to repair your board? Could be much less that 45 bucks! Post a picture so we can ID for you.
                              Where is your location? Please update your profile so we can help you source parts.
                              • r00t4rd3d
                                • Jun 2010
                                • 5
                                #235
                                Thanks for the replies. I have a DAC-19M005. I tried desoldering the parts off it. I do not think I did a good job so I ordered the ebay board.
                                Here is what mine looks like :
                                • Krankshaft
                                  • Jan 2007
                                  • 2328
                                  Yup common issue FET shorted and took out the inverter supply fuse.
                                  Resolder all inverter transformer pins then replace fuse and FETs.
                                  Looks pretty banged up but still salvageable.
                                  On the lifted FET pad scrape the lacquer off the trace it connected to until you see copper then tin it with solder. When installing the new FET bend the pin right over the scraped tinned area and solder.
                                  I've restored traces obliterated by SMD devices shorting so I'm used to this sort of thing.
                                  You'll also need to repair that trace under the fuse that's ripped scrape on each side and solder a jumper wire be sure to bend it around the replaced SMD fuse and not go under it.
                                  As far as inverter boards go this one is pretty bare bones and straight forward to repair.
                                  • r00t4rd3d
                                    • Jun 2010
                                    • 5
                                    #237
                                    I am not planning on trying to fix that board. Beyond my abilities. A new one will be here tomorrow. If anyone wants my old board , the one pictured , Ill gladly mail it to you.
                                    • EGuevarae
                                      • Nov 2008
                                      • 1336
                                      I'm in..!!!
                                      • GeForce GT1050
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        I'm in..!!!
                                        • GeForce GT1050
                                        • r00t4rd3d
                                          • Jun 2010
                                          • 5
                                          #240
                                          Does that mean you want it ?
                                          Is it just me or does think forum stick alot ? If I click the reply button or post button it just hangs....
                                          • Cuboy
                                            HP probook 4510s mosfet issue
                                            by Cuboy
                                            I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
                                            I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
                                            I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
                                            03-16-2024, 10:29 AM
                                          • ebyte64
                                            Lenovo IdeaPad 330 laptop mosfet issue
                                            by ebyte64
                                            Good day everyone.
                                            I have been scratching my head with a Lenovo laptop I got in today.
                                            The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
                                            Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
                                            Would anyone...
                                            06-27-2023, 10:19 AM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                          • DqMagetz
                                            Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                                            by DqMagetz
                                            Good day!
                                            I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                                            Here are the voltage readings:
                                            • Input – 19V (stable)
                                            • +LCDVDD – 3.3V briefly, then drops to 0V
                                            • EDP_HPD – 3.3V briefly, then drops to 0V
                                            • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                                            • EC BKOFF# – 1.8V briefly, then drops to 0V
                                            • PANEL_OD_EN – 0.3V
                                            Is it possible that the EC chip is corrupted or damag...
                                            07-12-2025, 09:37 PM
                                          • wattage
                                            by wattage
                                            Hello Badcaps Community,
                                            Yesterday, 04:41 PM
