Issue with Westinghouse 19" LCD Monitor (large pics)
+ More Options
Posts
  • bcuda
    • Jun 2009
    • 7
    #121
    Re: Issue with Westinghouse 19" LCD Monitor (large pics)
    Crabs?
    Anyway, I didn't know if the Taicon caps were better Quality or not since none of them are bulged. I took some more pics of the back of the board. let me know what part of the board and I can take very close shots if I can't find it myself.
    Thanks,
    Bob
    • Bobdee
      • Jun 2008
      • 461
      #122
      I can see 2 fuses
      F200 on first pic, at bottom in middle
      F102 on fourth pic, top left with a M or W on it
      suspect there may be a third possibly F101 (not sure about that)
      • EGuevarae
        • Nov 2008
        • 1336
        Originally posted by bcuda
        Crabs?
        Thanks,
        Bob
        He refers to the 8 legged ICs near the transformer.
        If you can, replace those Taicon for Panasonics as a preventive measure.
        And check the fuses Bob describe. On the model discussed here before, with the different PSU from yours, F200 was the culprit. Check them both, F200 and the "W"/"M" one ...
        There are 10 kind of people in this world: those that understand binary, and those who don't.
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • 16gb GSKILL TridentZ RGB DDR4-3200
        • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
        • Windows 10 Pro x64
        • GeForce GT1050
          2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
        • Bobdee
          • Jun 2008
          • 461
          #124
          Nama could have at least drawn a couple of eyeballs on stalks on the end of them, and made it easier to understand
          • EGuevarae
            • Nov 2008
            • 1336
            They are undercover .....
            • GeForce GT1050
            • Nama
              • May 2009
              • 127
              #126
              look at the chips they have crabs on them. Or am I mistaken>>>???
              I have a untested board for your monitor. Maybe you want it or parts off of it?.
              ^Learning to walk on rice paper without leaving a trace,
              • Wizard
                • Mar 2008
                • 2296
                #127
                That's Realtek logo. Not that one. This is microcontroller (aka minimalist cpu with few control outputs and few inputs).
                The IC they were referring is FET drivers in 8 pin DIP package (on the inverter/power supply board). Black square, dot or notch for pin 1, with 4 legs on each side in parallel.
                Cheers, Wizard
                • telebrake
                  • Jun 2009
                  • 13
                  #128
                  hello I need help, where can I found the service manual for this LCD monitor
                  • EGuevarae
                    • Nov 2008
                    • 1336
                    Diffucult task. What problem do you have?
                    • GeForce GT1050
                    • telebrake
                      • Jun 2009
                      • 13
                      #130
                      I have an acer AL1916Wa LCD monitor, and it does not turned on. The power sorce and the controller card are the same
                      I have a monitor that has exactly the same source and the same control card, as yours, but mine does not turned on, I check the voltage of the source 13.8v and 5v are ok. what can I do.
                      • bcuda
                        • Jun 2009
                        • 7
                        #131
                        I tested the two fuses. F102 is good. F200 is bad. It has a #3 on it as best I can tell. Where do I get one of those and how do I know the value of it?
                        A parts board would be great but I hope all I need are the caps, chips, and the fuse. I already ordered the mosfets off of Ebay.
                        Thanks,
                        Bob
                        • telebrake
                          • Jun 2009
                          • 13
                          #132
                          • Nama
                            • May 2009
                            • 127
                            #133
                            I would suggest starting a new thread. even if you barrow bcuda's pictures. It gets very confusing for people to reply to multiple questions from multiple people in the same thread.
                            • EGuevarae
                              • Nov 2008
                              • 1336
                              Open a new thread with the Acer model ....
                              • GeForce GT1050
                              • EGuevarae
                                • Nov 2008
                                • 1336
                                Thanks,
                                Bob
                                F200 as in our models ....
                                Get new caps, MOSFETS and I think the fuse is either 3 or 4 amps (that info is around this or the L20146NV thread that I started). Mine is bridged with solder.
                                • GeForce GT1050
                                • bcuda
                                  • Jun 2009
                                  • 7
                                  #136
                                  Just an update, The caps and fuse are in. Waiting on the chips to come USPS. I thought they would be here today but not luck. Maybe Monday.
                                  Bob
                                  • bcuda
                                    • Jun 2009
                                    • 7
                                    #137
                                    Got the mosfet's in today. The monitor works great!
                                    Thanks for all of your help guys!!
                                    I will be checking back here frequently.
                                    Thanks again,
                                    Bob
                                    • EGuevarae
                                      • Nov 2008
                                      • 1336
                                      Congrats !
                                      • GeForce GT1050
                                      • cclla
                                        • Feb 2009
                                        #139
                                        The fuse on the bottom of the power supply board is a 4amp surface mount fuse. Mouser.com carries them, they are part number
                                        652-SF-1206F400-2
                                        We have repair many of these units and every time its the caps, mosfets and the fuse.
                                        Buddy
                                        • EGuevarae
                                          • Nov 2008
                                          • 1336
                                          652-SF-1206F400-2
                                          Buddy
                                          Agree : caps going south kill the mosfets, that in turn blow the fuse.
                                          And I recall seeing the part # and amp rating somewhere around here, just can't remember where. Thanks for the info, man!
                                          • GeForce GT1050
                                          • Cuboy
                                            HP probook 4510s mosfet issue
                                            by Cuboy
                                            I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
                                            I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
                                            I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
                                            03-16-2024, 10:29 AM
                                          • ebyte64
                                            Lenovo IdeaPad 330 laptop mosfet issue
                                            by ebyte64
                                            Good day everyone.
                                            I have been scratching my head with a Lenovo laptop I got in today.
                                            The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
                                            Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
                                            Would anyone...
                                            06-27-2023, 10:19 AM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                            Westinghouse L2210NW LCD monitor - bad caps repair
                                            by momaka
                                            Here's another LCD monitor repair: Westinghouse L2210NW.
                                            Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                            I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                            Pictures of the monitor outside/case after a brief...
                                            01-11-2021, 01:14 AM
                                          • Nooy
                                            VGA MOSfet permanently shorted and loss of MOSfet pad
                                            by Nooy
                                            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                            02-14-2024, 02:26 AM
