Re: Issue with Westinghouse 19" LCD Monitor (large pics)
Ok, so here is my selection. I looked for FM at first, but FM was not available for 47uF 50v and 100uF 400v, so then I looked for FC and found 47uF. But it said FC's lifetime is only 1000 hours (?) or did they mean to say that it lasts 1000 hours if it has to work at 105 degree temp? Well, then TSHA seems to be the only one that matches the size and rating both. Pls let me know of any change since I did not place the order yet.
1 - P12927-ND CAP ELECT 22UF 50V FM RADIAL
2 - P12389-ND CAP 470UF 25V ELECT FM RADIAL
3 - P12379-ND CAP 1000UF 25V ELECT FM RADIAL
1 - P12357-ND CAP 2200UF 10V ELECT FM RADIAL
1 - P10321-ND CAP 47UF 50V ELECT FC RADIAL
1 - P6843-ND CAPACITOR 100UF 400V ELECT TSHA
That makes a total 9 caps. BTW, I can substitute one 1000uF 10v with a 1000uF 25v, right?
And thanks eguevarae. Do I need to take the mosfets off the board before checking for short?
yeah, in my original post#258 i misread the voltage somehow, that should've been 10v. What do you think about the last i.e. 100UF 400V ELECT TSHA? If that one seems okay to you guys, then I can go ahead and place the order.
Infact the idea of bigger ones has less chance to go bad influenced me to try skipping that one, but the major reason was the new replacement cap I got from digi-key has short and very thick legs, still I could use that attaching two little pieces of copper wires if I really had to. But anyway, my TV/Monitor started working again.
Thanks a lot retiredcaps, PlainBill, eguevarae. Just a little question. Is faulty capacitor the reason for electronic devices failure in most of the cases?
