Fujistu-Siemens LCD Color monitor B17-1 strange problem
    Re: Fujistu-Siemens LCD Color monitor B17-1 strange problem
    I'm quite hopeless, so I would be glad for any suggestion.
        suggestions???
          Originally posted by teppei View Post
          So ..... I did just a beautiful mistake ....... but proceed with caution.
          Having 3 monitors identical (the same brand and model) and having one repaired successfully thanks to your support to try to repair this one I felt so proceed, namely:
          Removed the card working power and put under another monitor I'm trying to fix and everything works fine.
          I did this test to see if it was a problem of lamps or the video card, but fortunately it is only a problem on the Power Supply board.
          I reinstalled the power supply board monitor in its original and does not work!!! and as if trying to turn on but it goes in a loop and feels ta ta ta .....
          What have I done??
          thanks
          If this the board with the electrolytic caps from China in the top left corner near the heatsink - what make were they?
          Does it now not work in either monitor?
            friends .... now one of the 3 monitors that worked quietly, has a problem that turns itself off.
            the power back and with variable time goes ....
            What do you advise me to recheck??
            thanks
              hi, i have a fujitsu b19-2 lcd monitor; the screen started to became black just about 3 second (under a light is possible to see that the pixel still working). The power board is the same model that was posted by budm on 10-24-2012 in this tread (https://www.badcaps.net/forum/attach...6&d=1351093232). I found on the power board two HERMEI LZ capacitors in the are of the inverter of the lamp, 150uF 25V purple color. I change them with two Rubycon ZLJ, but the problem remained. Then i changed the four capacitor in the top right position, two rubycon yxg 16V1000uF and two nippon ky 16v470uF with two couple of Sanyo WE-AX.The lcd has the same problem.
              All the capacitor that i changed did't present bulge or burns are, and using a multimeter i verified that that the capacity is correct. Anyone has this problem after a repair work?
                Hi Please can you update your profile with country and mains voltage.
                There are many reasons for 2 seconds to black - read the attached guide by
                retiredcaps.
                https://www.badcaps.net/forum/showthread.php?t=10419
                Start at post 19.
                Welcome to the forum-
                We can often help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                Examples of what is needed
                https://www.badcaps.net/forum/attach...7&d=1280167246
                https://www.badcaps.net/forum/attach...6&d=1280167246
                https://www.badcaps.net/forum/attach...4&d=1280167246
                  On the left of the Board there are 4 transistors around two Blue caps.Suggest you check those, as failure of one or more of those transistors will give you the fault you have.You should check for short circuits on their pins,
                    Good evening to all,
                    I have a B17-1 lcd color monitor with the same problem, i could solve the problem thanks to the advice i've found on this forum.
                    Thanks to all
                    Joseph
                      Hello everybody! I want to share my different problem and solution with this model B17-1, in case somebody else is dealling with it:
                      The monitor was starting, showing the Fujitsu Seimens logo, and staying block on that image; only on/off button worked.
                      The problem was one of the buttons from the control board that was in short when not pushed. It was a very strange situation.
                      So I just removed that button and the monitor started normally.
                        I had the same problem (black screen) in my P17-1
                        I replace the four capacitors as describe in previous articles.
                        It's working now!
                        Many thanks to the members of this forum
