Dell E173FPf
  • Bobdee
    • Jun 2008
    • 461
    Re: Dell E173FPf
    Hello guys
    ... Justin
    I agree with Eduardo, about opening a new thread, If you start again we can forget my boards and concentrate on yours, as it should be, I can sit on mine,no problem, less confusion, and forget that Dreaded IC,that has taken you off track,(my fault Im afraid), give as many details as poss, like the number of the board ect
    ...Eduardo
    Sorry again, NIL = .000 ohms, = fully conductive
    I fully agree with your observations,and thanks for your time, and input,
    bob
    • darkstar
      • Feb 2009
      • 12
      Re: Dell E173FPf
      Ok i can agree with that. What kind of details would they need? What numbers off the board do i need to give? I have a white sticker with numbers on it and a bar code and numbers printed down by the power plug and a set on the back. I also have the pictures i took in better quality i can email someone. The quality was sacrificed in order to post them on this thread.
      • darkstar
        • Feb 2009
        • 12
        Re: Dell E173FPf
        Thanks again Eduardo and Bob for the help
        • Toasty
          • Jul 2007
          • 4171
          Re: Dell E173FPf
          Any action on this, darkstar? Did you figure out why the LED is out when it was working when you started? Just poking about at the request of Eduardo.
          veritas odium parit
          • darkstar
            • Feb 2009
            • 12
            Re: Dell E173FPf
            No, I haven't yet. I got busy with some other stuff going on so i had to set it aside for a while. I am getting ready to get back at so. I kind of think it 1506-50 since I had such different reading then everyone else.
            • Metria
              • May 2009
              #26
              Re: Dell E173FPf
              I have one of these monitors with no power led as well. Trouble shooting led me to find that R852 a .2 Ohm resistor is open, and after removing Q850 and testing it with a meter, no matter what pins I go between I get no more than 1.5 Ohms of resistance. Also my shorts on the Circuit board seem to have gone away. I have ordered another AP2761-A on Ebay, and will let you know if repacing it and this Mosfet fix my issue.
              • Metria
                • May 2009
                #27
                Re: Dell E173FPf
                Just wanted to let everyone know that I got the replacement parts in today, and the monitor works perfectly!!!!!
                • EGuevarae
                  • Nov 2008
                  • 1336
                  Re: Dell E173FPf
                  Congrats man!
                  • ASUS ROG Maximus IX Code
                  • Intel Core i5-7600K 3.8GHz
                  • Windows 10 Pro x64
                  • GeForce GT1050
                  • ranaguru
                    • Mar 2011
                    #29
                    Re: Dell E173FPf
                    nic work bro.keep it up.Thanks
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      Re: Dell E173FPf
                      • GeForce GT1050
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • Thomasraud
                        Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                        by Thomasraud
                        i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                        QUOTED
                        -It works on charger (without battery connected-only charger)
                        -It works on battery (without charger connected-only battery)
                        -& it also works when plugged in battery & charger, but it's not charging the battery
                        //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                        and..
                        QUOTE
                        The IC cannot maintain the input current level
                        06-28-2022, 06:47 PM
                      • Akhlz001
                        by Akhlz001
                        09-20-2025, 07:15 PM
                      • master3112
                        by master3112
                        07-29-2025, 01:55 PM
                        Dell Thunderbolt Firmware
                        by SMDFlea
                        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                        The SKU is in brackets (****)
                        EDIT: NVM65...
                        01-26-2025, 06:22 AM
